Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Readyheater portable forced air 170,000btu/hr
The heater shuts down after starting up but shuts down in about 5 seconds, I replaced the air tube and the pressure is 6 psi filter CAN YOU HELP
  • 2 more comments
  • ALTO Dec 31, 2007
  • Highflyer172 Jan 04, 2008
    I have replaced the tranformer,safety switch, motor starter, all filters, and sparkplug and the heater still trips out on the safety switch after just a few minutes. The heater will run if I prop up the rear of the cover about an inch but as soon as I put the cover back on it shuts off.
  • Anonymous Jan 26, 2008
    I am using home fuel oil in unit. Unit starts fine, runs about 30 sec. & then shuts down. I've replaced intake, output. &fuel filters with success yet.
  • Anonymous Jan 30, 2008
    my ready heater has elictic incniter that nose not work
Reset switch my heater did the same thing after 5 sec of running
Posted on Jan 23, 2008
If you just changed the air filter. you may need to change the fuel filter as well
Posted on Dec 21, 2007
My 150,000btu readyheater starts then two sec.later a puff of smoke it runs for a few minutes and then shuts off. After it is unpluged for a few minutes it will start and do the same thing again.
Posted on Mar 10, 2009
I need a psr t for my portable forced air heater it's a old one the best I can tell It's a 35/50 70000 BTU/HR. ware would I be able to get parts
You can call Allparts Equipment and Accessories at 1-877-475-5660 they have one of the largest supply of DESA parts still available.
You can also go to
Jan 04, 2011 | Desa International Kerosene Portable...
R100 reddy heater, low pressure forced air heater. the heater ignites, motor runs for 30 seconds then shuts down. photo cell good, filters clean, no ignition board, pump pressure unknown.
The R100 is a kerosene heater and the RLP100 is a propane heater so I am not sure when one you have.
If it is kerosene then you may need to check the pump pressure. Also the Safety swith can give you a cut out after 30 seconds.
If the unit is Propane then you could have a bad control board or a flame sensor.
You can call our service department at 1-800-475-5660
Oct 21, 2010 | Reddy Heater RLP100 Portable Forced Air...
My reddy heater 115 pro starts, but shuts off after about 5 seconds of running , i replaced the filters and nozzle about 2 years ago
Here is a service manual:
If the flames actually starts but the unit shuts off after 5 seconds you need to check the pump cover on your heater to make sure you have no cracks in the rear cover.
This could be from low pump pressure but most often this problem is caused from a defective control board.
Oct 03, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
My heater will shut down after running for about 10 mins. there is lots of propane, and all the connects seem to be tight and secure. i've checked the gap in the sparking unit (spark plug) and its around...
Hi check the flame sencer is clean check tubes to pressure switch ,jump out presureswitch , check fan control switch is clean, agian jump this out see if it works then .
Feb 27, 2010 | Reddy Heater RLP100 Portable Forced Air...
Eden pure heater starts to heat then elements shut off i replaced thermostat and heat sensor any other suggestions what to try next
yes u have overheatsensors that shut the strips down if they get too hot these may be going bad and getting weak and shutting off prematurely
Feb 20, 2010 | Reddy Heater R70 Portable Forced Air Space...
Reddy heater 165,000 runs for approx 15 to 20 min. I unplug wait 5 min. it restarts again and runs for another 15 to 20 min. and so on ....and so on purchased approx 1 year ago
There is a sensor in the tube that is a safety feture. it is a snap disc it maybe faulty, it is reading that the tube is to hot and shutting down, it cools and works again, check snap disc and also they need pleanty of fresh air.
Jan 13, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Kerosene Portable Forced Air heater comes on, runs awhile
The unit should have a fuel & air filter. Check that both are clear. Inside the burner tube, there will be a photo-cell, if the lense is dirty it will shut the flame off. The photo-cell needs to see the flame. You can carefully and gently, clean the lens with a tissue, soft cloth, or Q-tip. Please let me know how its coming along.
Feb 09, 2009 | Desa International Reddy Heater R115DT...
Wont stay running
Reddy suggests: 1. Propane supply may be inadequate 2. High surrounding air temperature causing thermal limit device to shut down heater 3. Restricted air flow 4. Damaged fan 5. Excessive dust or debris in surrounding area solutions are: 1. A) Refill tank B) Provide additional and/or larger tanks. 2. This can happen when running heater in temperatures above 85° F (29° C). Run heater in cooler temperatures 3. Check heater inlet and outlet. Remove any obstructions 4. Replace fan. 5. Clean heater. could not get manual for your exact model but if you want manual for RLP 125 then; appears to be the same beast. Hope helps :)
Feb 27, 2007 | Reddy Heater RLP100 Portable Forced Air...
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
1,122 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
