Question about Scuba Diving & Snorkeling
MY COMPASS HAS AN AIR BUBBLE IN IT, IS THAT NORMAL
  • 121 Answers
You don't mention what make or model..
There are a couple of brands that tried the bubble idea to allow you to level the compass while reading but not to much success. So my guess it's a fault with yours.. Hopefully it's either in warranty or not an expensive one to replace 'cos generally they're more expensive to repair than replace..
Either way, the bubble is bad because it will affect the bearing..
Posted on Oct 09, 2009
Testimonial: "It is a Zeagle, the bubble is about the size of a dime. Thanks for the info."
How to get rid of a large bubble in my compass
Very difficult. See the annual index of Wooden Boat Magazine.
Jul 09, 2014 | Silva Ranger Series 515 Cl Compass
Air bubble in Steel boat compass
Most compasses have a port that allows you to refill the chamber with oil. The oil dampens the movement of the card inside so the right weight oil is needed. Contact the maker of the compass to get the weight needed and find out where it leaked out, probably that same port. The seals go bad after time, sun and elements.
Mar 17, 2014 | Cars & Trucks
Air bubbles in fuel tank
Can you be a bit more specific, perhaps? You might just be hearing it slosh around, this is normal.
Oct 13, 2013 | Volkswagen Cars & Trucks
When is a compass in need of repair?
    • 1.
      When there are cracks in the dome.
      2. When fluid levels are low,
      creating a bubble or fluid is all together empty.
      3. The dial or card is
      discolored or yellow.
      4. When the dial begins to stick
      * follow these steps to test dial.........
      While dockside take note of the compass heading. Hold any magnetic object
      to the compass so that the original heading is deflected about 10degrees.
      Remove that object, and see if the dial returns to it's original
      heading.
      Repeat this several times deflecting the compass to both sides.
AdChoices
Jul 09, 2012 | Camping, Backpacking & Hiking
2011 jeep compass vibrations when stoppped in drive
This worked for me
Hey all. I had the same issue with my wifes 2010 Compass. I figured it was the same thing as most everyone else, bad mount or torque converter. I saw a post about the rubber stops under the hood and adjusting them didnt really help. I checked the top/side mount, lower front mount and lower rear mount and they were all intact. I figured it might just need a tune up so I decuded to change the oil, 4 spark plugs, and the air filter. One of those worked!! Honestly I think it was the air filter. it was very dirty. I suspect that the car was struggling to get enough air and it was causing the car to shake more than normal. Anyways I hope this helps someone. Good luck!!
Jan 08, 2012 | 2011 Jeep Compass
Why is my reserve radator tank bubbling ? 1996 honda accord 4cyl. not manual
Normally, when air is trapped in the cooling system the radiator cap will vent the air out into the recovery tank, mostly when the engine is off and cooling down. That is completely normal. However, if you see bubbles continuously while the engine is running you may have a blown head gasket or worse, a cracked head.
Aug 25, 2011 | 1996 Honda Accord
I have purchased a Brunton hand transit, it has no marks, dings,dents or chipped paint. All glass is intact without any scratches. But, the needle acts like it is stuck, sometimes it moves and other times...
Is there a circular level on the face plate with a bubble in the interior. The needle should move when the bubble is in or near the center of the level. Some of Bruntons have a locking pin. Make sure the pin is in a raised position, the pin should pop up when you open it. Hope this helps, Pete
Jun 25, 2011 | Brunton International Transit, 0-360...
An air bubble has developed in my Ritchie kayaking compass. How do I remove it?
I contacted Ritchienavigation.com over the web and they told me that the compass would be replaced since it is under warranty.
Dec 29, 2009 | Sport & Outdoor - Others
Looking for a new compass bubble level
Go to Home Depot or Lowes. They have very small bubble levels. Also any well stocked hardware store will also sell them.
Nov 11, 2009 | Meade 114EQDH4 (36 x 114mm) Telescope
Airbubbles in Mares compass
It is Completely normal... i have had 8 computers (all by Mares, or Aries) and all Dive compasses that i have seen have had a bubble.
Apr 20, 2009 | mares Nemo Air Compass Assembly -...
Scuba Diving & Snorkeling Logo
1,309 people viewed this question
Top Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
