Question about Canon EF-S 17-55 f/2.8 IS USM Lens
I have a Tokina lens which says SD 35-200mm 1:4-5.6. The serial # is 8508870. What can you tell me about it, like what camera brand it fits?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 149 Answers
Hello. The SD stands for Super Low Dispersion glass. It's a type of glass which is supposed to correct a lot of common light-transmission errors that naturally occur with optics used in this manner. All companies use "special" or "proprietary" methods of producing their respective high-quality lenses. The 35-200 tells you the focal length(how much zoom capability) you have. In other words, 35mm is considered a mild wide-angle lens while 200mm is approximately equal to a 10x pair of binoculars. Tokina makes lenses for a wide variety of cameras. There should also be a letter designation stamped on the rear of the lens mount. "O" for Olympus, "M" for Minolta, "N" for Nikon, "P" for Pentax, etc. Sometimes, there are 2 letters showing that the lens will fit cameras from 2 different companies.---Rick
Posted on Oct 02, 2009
Need adapter tokina 100-400 f/4.5 minolta to Canon Digital SLR
You need a Minolta to Canon adopter. Because the Tokina was made for the Minolta in the first place. Be aware that even with the adopter, there is a very great chance you always have to focus manually, because the lens can be fitted on the camera, but the electronics will not be compatible.
That is one of the things you almost aways lose, when using lenses from a different make.
Apr 06, 2014 | Tokina 100-400mm f/4.5-6.7 for Nikon
Tokina lens problem
Try gently cleaning the contacts between the lens and the camera.
Sep 20, 2017 | Tokina 12-24mm /f4.0 for Canon
Is there an adapter for Tokina Rmc 1 3.5-4.5 35-135mm Zoom Lens to fit to panasonic gh2 m4/3?
Perhaps. Tokina makes lenses with a variety of mounts. If the lens already has an m4/3 mount then you won't need an adapter at all. Some Tokina lenses take the "universal" T-mount. In this case remove the current mount and put on an m4/3 mount. If it has some other fixed mount, m4/3 adapters are available for some of them. It all goes back to the mount already on the lens.
Jun 20, 2012 | Tokina Rmc 1 3.5-4.5 35-135mm Zoom Lens...
Can I use TOKINA lens 28mm-210 lens with this Nikon body or can I use with other NIKON body D 700?
Tokina makes their lenses with a variety of mounts. A lens with Canon mount, for example, won't fit onto a Nikon. Assuming you get the lens with a Nikon mount, then yes, you can use it with a D70 and with a D700.
Apr 16, 2011 | Nikon D70 Body Only Digital Camera
I have the tokina atx 280 pro lens but no hood, where can i get a replacement hood? or other brands that can fit in my lens. thanks
Most good camera shops and even some online camera stores should be able to help you
Part# BH775
also look here and contact this site as as long as it fits the lens size you have a variety of shapes.
http://www.jsteven.net/tokina-lens-hood/
you can make your own see this page
http://www.lenshoods.net/hoods/Digital-Lenshood-Tokina-AT-X-280-Pro-AF-28-80mm-f-2.8.php
Please rate my help++++Thanks for using FIXYA
May 19, 2010 | Tokina AF 28-80mm f/2.8 AT-X Aspheric Pro...
I have a tokina SD 35-200mm it fits my nikon F301 will it be compatable with a nikon D 3000 dslr
Only one way to find out for certain, try it and see!
It will certainly fit onto your D3000 without causing it any harm but it probably won't work properly either. There's also the little problem of crop factors: your D3000 has a smaller imaging surface than your 35mm film camera. As a result, it only uses the middle of the image produced by this lens; it will appear as if the camera has a 50-300mm (52.5-300mm to be really accurate) lens fitted instead of the 35-200mmm.
Feb 28, 2010 | Canon EF-S 17-55 f/2.8 IS USM Lens
I just bought the Tokina SD 12-24 F4 (IF) DX wide-angle lens for my D70, and it does not autofocus. I'm being told by the company I bought it from that i am past their 2 week return policy. Does this lens...
Only the MkII version of this lens has an autofocus motor built in, the MkI relies on a motor in the body of some Nikon AF SLRs to autofocus. The D70 does not have an inbuilt AF drive motor, so if you have the MkI lens then you can only use it in manual focus mode on your camera.
Aug 03, 2009 | Tokina 12-24mm f/4 Pro DX for Nikon
What camera does this lense fit
These were made to fit many different cameras and the same lens was often branded as a Tokina in most worldwide markets.
Have a look around the mounting plate, there is normally something printed to indicate which camera it's for. e.g. C, Ca, or Can means Canon; N/Ni/Nik = Nikon, P/K = Pentax, O/OM = Olympus, CY = Contax & Yashica, L = Leica, X = Fujinon X (very rare). If there is a screw thread mounting then it's most likely an M42 mount as used on ancient Pentax models and by former Soviet Bloc makers like Praktika and Zenit.
If any of the above have AF added to the code then it's an aurtofocus version of that mounting.
If all else fails take it to a camera dealer, they should be able to tell you.
Apr 20, 2009 | Cameras
I have a tokina 500mm f8 lens with a P/K mount
This will depend on the lens you have now.
Some Tokina lenses have a universal fitting, with a separate adaptor mount for each camera body they fit. Its usually the last 5 - 10mm of the mount, and its identifiable by a second release button, which allows the specific fitting to be changed. If you have one of those, you just need the Nikon fitting.
If the P/K mount is an integral part of the lens, you have a couple of choices.
(1) You could get an engineering shop to alter the mount. This costs a lot and probably isn't worth the hassle. (It might be better to sell your lens and buy the nikon equivalent).
(2) You could use an adaptor. These are readily available on eBay.
For example:
http://cgi.ebay.co.uk/Pentax-PK-K-Lens-to-Nikon-AI-AF-F-camera-mount-Adapter_W0QQitemZ150400359906QQcmdZViewItemQQptZUK_Photography_CameraLenses_Lens_caps_hoods_adaptors_ET?hash=item23048f5de2
Note that just because it has the right (i.e. Nikon) fitting, it doesn't mean that it will necessarily have full functionality on the body you intend to use with it.
Some Nikon bodies are "extremely fussy" about which lenses they can use, and it might be worth evaluating whether your proposed solution would work with the camera body you have in mind before committing to any sort of expenditure.
Feb 15, 2009 | Tokina Cameras
What does my zoom lens fit?
The lens fits in vivitar, pentax,cosina cameras
Mar 10, 2008 | Vivitar V3800N Zoom 35mm SLR Camera
Canon EF-S 17-55 f/2.8 IS USM Lens Logo
1,054 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
