Question about Samsung SPH-M610 Cellular Phone
I dnt know my user lock code all i want to do is format my sd card
    President:
  • 570 Answers
It is usually 0000 or 1234 by default.
Posted on Oct 02, 2009
When i try to format my micro sd card system shows remove write protect how can i format it
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
I hope this helps.
Aug 09, 2011 | SanDisk 2GB microSD Memory Card
I just recently got my HTC Wildfire and my SD card is not being recognised and it is in the read only format... Does any one know how to format it
Welcome to Fixya
Dear User ,
You can Format your SD card .Just insert your SD card to Card Reader in your PC.Dont forget to move Lock button in to Unlock Position.Then make a Fat file type Format...
Hope this Helped...Thanks for Connecting FixYA
Oct 14, 2010 | HTC Cell Phones
It locked its memory card i cant open it i dnt know the password?
Here is a tip that I wrote about SD Cards and how to unlock and lock SD Cards.
If you are getting a memory card locked message then check this out.
How to Unlock SD Card
heatman101
Oct 07, 2010 | Nokia 6500 Slide Cellular Phone
2GB Micro SD needs format code that I never gave it
You can format your micro-SD Card using a software which you can download by clicking this link. I uploaded it to my FTP site for you and it will be there for a limited time. Download that file and save it to your PC. Then unzip that ".zip" file.
If you format micro SD card connecting it to your PC via USB port, it may not ask for password. (I think your phone asks password to format.)
To format your micro-sd card:
- First plug in your micro-sd card into you PC.
- Run the downloaded "HPUSBFW_2.2.3_MASTER.exe" file.
- In the program menu window, select the device (your memory card).
- Select FAT32 as file system,
- Confirm that all the format options unchecked. (Uncheck the quick format option)
- And click the "Start" button to begin formatting.
Hope this helps you.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
May 12, 2010 | SanDisk 2GB microSD Memory Card
Memory card for motorola krzr k1
try formatting & inserting it again.......
it may solve ur prob
Dec 29, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Error 30
The "E30" error code indicates reading/writing data on a SD card has failed. Especially, the error code "E30" may appears when you tried to remove a SD card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the SD card with your camera Try to format the SD card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting SD cards. Also, please note that formatting a SD card will erase all data on the card. Once the SD card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the SD card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the SD card.
Aug 31, 2005 | Canon PowerShot SD300 / IXUS 40 Digital...
Error 30
Aug 31, 2005 | Canon PowerShot SD200 / IXUS 30 Digital...
Error 30
Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
Error 30
Aug 29, 2005 | Canon PowerShot SD10 / IXUS I Digital...
Error 30
Aug 29, 2005 | Canon PowerShot SD100 / IXUS II Digital...
Samsung SPH-M610 Cellular Phone Logo
152 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
