Question about Hitachi 60UX54B/55K 60" Rear Projection Television
Hitachi 60" picture flashes on and off.
Can see picture when it flashes on. Checked inputs, everything is okay. Comes on for few seconds then off for few seconds. Power light stays on. Any thoughts?
  • 1 more comment
  • Anonymous Mar 28, 2008
    Same Problem any word
  • Anonymous Apr 13, 2008
    same problem, picture comes and goes in second intervals, red light stays on.....
  • timtaylor May 15, 2008
    My 60UX54B has the same problem. Screen flashes from clear pict to blank screen in 1 second intervals. Sound is clear during picture periods.
    I have not tried anything to repair at this point.
    Tim, Thanks in advance.
I've had the same set for many years happens every few year disconnect set power from wall wait 30 seconds plug back in fixed. If you look kin the back of the owners manual it's suggest the same fix for an apparent no power problem.
Posted on Mar 24, 2010
  • Richard Laramie Aug 27, 2012
    richol....Thanks a bunch...my Hitachi Ultravision 60" rear projection model 60ux54b/55k was doing exactly the same thing....unplugged it for a minute....plugged it back in and it is working like new again...it is a 1997 and it still works great with beautiful picture. Thanks again....you saved me a service call and likely about $200. I keep it in the basement for the kids to play games on so I didn't want to spend a bunch of money on it.
I've had the same issue although I don't unplug everything. I turn it off and then unplug it from the wall for 10 seconds then plug it back in. Seems ok after that. Has happened 4 or 5 times over the 10 years I've owned it.
Posted on Jul 20, 2008
I've had this problem before. I turn it off, disconnect everything, and unplug it for 24 hrs or so and it solved itself. No idea why…but worth a shot.
Posted on Jun 05, 2008
Tv has no picture
If you have lost your picture you can try a few steps. The first step would be to reset your receiver by unplugging it for ten seconds. If that does not resolve the issue, you will need to check the cable going from the receiver to the TV set. Start by making sure it's firmly connected. If the cable is a coax cable (screws on) tune the TV set to each of the following channels to see if you can get a picture: 3, 4, 60, 73 If you have a digital cable that just plugs into the receiver and the TV then you will want top cycle inputs until you receive a picture. To do this press the input or source button on the side of your TV you will see the name of the input flash at the top of the screen. Press the input button multiple times to change from one input to the next. Make sure to pause on each input for a few seconds to make sure the picture comes up. If this doesn't help you completely, please e-mail me at:Daniel.Busa@DISHNetwork.com
Daniel Busa
DISH Network
Customer Service
Nov 24, 2011 | Dynex DX-LCD37 TV
Do you take the back panel off to replace the bulb
No, you take the front panel off and you will see a small access panel. There is your lamp.
Dec 14, 2009 | Hitachi 60VX500 60" Rear Projection HDTV
Comes on with good picture. in a few minutes, the
Hold down the menu and the input buttons on the front at the same time for 5 seconds. Led will flash a 2 digit code repeatedly. reply back with this code. If the set has been unplugged after failure code will be erased.
Aug 29, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Hitachi 50v500 turns off, then back on.
shanerickp, how many flashes before the picture comes back? that could be your code for a lamp replacement. check your owners manual for that.
Jul 30, 2009 | Hitachi Televison & Video
Hitachi rear projection lcd lp500 series
It is likely the projection lamp is weak, causing the picture to cycle on and off. Take the lamp out and examine the reflector. If it is dull and cloudy, it's time to replace the lamp. A new lamp will have a reflector that is shiny and looks like a mirror. Be sure to rate this solution. Thanks!
Nov 08, 2008 | Hitachi 60V500 60" Rear Projection...
The tv turns on but no picture.
Mine did the same but no picture, just sound every few seconds for 1-2 seconds. I unplugged from the wall for 10 seconds and plugged back in, works fine now.
Jan 12, 2008 | Hitachi 60UX54B/55K 60" Rear Projection...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Televison & Video Logo
153 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
