Question about GE Spacemaker JVM1640SJ Microwave Oven
GE SpacemakerXL, model #JVM1330BW 002, does everything but run
I have a GE SpacemakerXL, model #JVM1330BW 002, made in 1996. Everything works - timer, clock, fan, lights - except for it won't start when the "start" button is pressed. The cook timer counts down, so it doesn't appear to be a door switch issue. Could it be a fuse, or something worse?
    Prodigy:
    An expert who has answered 500 questions.
  • 547 Answers
On some ovens, it can be a door switch. I've jiggled a few doors over the years and had some ovens start running. In this situation, the switch assembly is usually out of adjustment. Or the door is not activating the switches properly.
Posted on May 03, 2016
    President:
  • GE Master
  • 1,922 Answers
It could be a defective thermal fuse,h.v. cap,h.v. diode or the magnetron tube are defective
Posted on Oct 02, 2009
Solution-GE spacemakerXL microwave oven model:JVM16505H01 mfg.date:feb.2005
Sounds like you have a bad smart board, you can try unplugging the unit for five minutes and then back in, if you are lucky this may correct the problem...good luck
Feb 18, 2014 | GE Microwave Ovens
GE spacemakerXL JVM1840CD 002 F3 code showing up
This code will most likely occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
You can purchase that part at Reliable Parts:
http://www.reliableparts.com (USA)
http://www.reliableparts.ca (Canada)
Aug 26, 2013 | Microwave Ovens
I have a GE SpacemakerXL microwave that stopped working after I heard a loud pop. Everything else works, but it does not heat anything. Help?
From the descriptions it likely the magnetron has failed. If you have a digital multimeter post me a comment and I will give instructions to do a rough test.
Jun 06, 2012 | GE Profile Spacemaker Over-the-Range...
GE SpacemakerXL Microwave Oven
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpacemakerXL Microwave oven clicking noise
Spacemaker t/t motors are very easy to change. Removed the screws from bottom of microwave. the bottom panel will found towards wall. Mtr is in very center of unit. Should have 2 wires going to it
Nov 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpacemakerXL Microwave Model JVM1450 It's been working great. Then put somethingin,turn it on. It ran 30sec. made a growling sound,like it was straning or slowing down,then Blew the fuse.I replace the...
SOUNDS LIKE MAYBE HIGH VOLTAGE RECTAFIER SHORTED MIC ARE VERY DANGEROUS THEY HOLD VOLTAGE EVEN WHEN UNPLUGED YOU MAY CONSIDER PRO ON THIS SORRY
Nov 06, 2009 | GE Microwave Ovens
The microwave doesn't have power
Sounds very much like the magnetron is at the end of its life , if everything else on the oven is working but you don't get that familiar hum as the magnetron kicks in and I am afraid they can cost as much as a new oven especially with the repair cost , time to go to the store and get a new one it will probably be cheaper ... Regards Vortash
May 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Mar 21, 2009 | GE JE1540 Microwave Oven
Sounds like you've had a failure in the microwave portion of the unit.
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Jan 24, 2009 | GE JE1540 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
701 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
