Question about Sceptre X37sv-Naga 37 in. LCD Television
Power supply dead... is it fixable?
I'm mostly a computer guy myself, and I've never messed with soldering or anything that advanced, just the easy installations and stuff. Anyway, my LCD TV died a while back and just last week I found a fix:
Solution #1 here: (not my question, but the solution fit my scenario)
http://www.fixya.com/support/t2344092-sceptre_lcd_tv_power_come_but_no
It worked fine for a few days and now it stopped working. I tried using a thicker piece of plastic like it says but that didn't work either.
I decided to examine the board a little closer (keep in mind my little experience here) I had already noticed the scorch marks around about 3 or 4 pins on the bottom of the board (which led me to the above solution). I looked closer at those pins and they didn't look quite right, as if they were possibly no longer getting contact with whatever they need to. On a couple of the pins, if I hold the board up to the light, I can see through the board through small holes next to the pins (which didn't look normal to me) I also noticed the pins didn't all have the same amount of metallic substance (solder?) around them, which worried me as well.
When I power the board, I see a quick flash of electricity on one of these pins, and then the rest of the TV doesn't get power. (No standby power LED like usual)
My question is whether or not this is fixable or if the board is completely dead and in need of a replacement. I'm seriously hoping not, as the replacement would probably be $150+ and I currently have no money or job.
Here are some pics of the group of pins I'm talking about. Not the best pics, but perhaps they can give you some ideas:
http://img44.imageshack.us/img44/6640/61011685.png
http://img10.imageshack.us/img10/4076/95469746.png
http://img30.imageshack.us/img30/5230/61221001.png
http://img96.imageshack.us/img96/3318/70494395.png
  • morphinapg Oct 02, 2009
    Yes, I just googled Dry Joint and it looks like this is most likely what I have. It looks like it wouldn't be too difficult to fix as long as I could get someone I know to do it for me relatively cheap.
  • 11,361 Answers
I resoldered those pins on my, but you need to clean them real well first, this is common problem for this model. Any good repair shop should be able to resolder the board for you.
Posted on Oct 24, 2009
Testimonial: "Would this be expensive? I might know a friend or two that might know how but they might not be available to do it right away."
  • Bud Martin
    Bud Martin Oct 25, 2009
    If your friend knows how to solder and has 40watt soldering iron, he should be able to do it. I bent the leads of the old parts down before soldering to the copper pads to give more area for the solder to stick to. The NTC THERMSITOR that has poor connection because it used for soft start to reduce inrush current when the set is turn on so the TV will have less stress during turning on, the bad part is that the NTC Thermister will first get hot and the resistance will go down to let full current to be supplied to the power supply section, when you turn off the TV the NTC Thermister resistance will go up as it is cooling down. This is called thermo cycle and can put al ot of stress on the solder pads, causes poor connection and heat built up at the cold joints and finally goes open. If you remove the PCB and take it to the repair shop, they should be able to resolder for you for less than $30.
  • 75 Answers
Sounds like a dry joint, or adjoining pins are being shorted, will try and have a look at your pics
Posted on Oct 02, 2009
Testimonial: "Thanks for the info, it looks like this is probably the problem. Hopefully not too difficult to fix."
Horizontal hash lines until the set warms up then a picture with very little of the lines but still there...suspect a capacitor
Ya could be a capaciter on the power board, they take the most heat and fail most often. Easy to see a lot of the time the top will be swelled up like canned goods with botchalism, the good one are perfectly flet on the top. Had the same problem with two TV's, fixed 'em myself. I was a soldering guy at Apollo Computer, and Centronics Corporation before though. You have to be careful if you do it yourself, don't melt any of the copper tracing off the board, or you could end up screwed. But those horizontal lines are tell tail of a power transformer board capacitor.
Feb 20, 2014 | Toshiba Televison & Video
I have a 32 inch crosley flatscreen lcd tv when i try to turn it on it makes a screeching sound and turns right off is it fixable
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where.If otherwise, power supply board is dead, do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hoping this will help in solving the problem....
Jun 28, 2011 | Televison & Video
Power supply went out (at least I think thats what it is) on my Polaroid FLM-4034B 4-" HD TV, if I buy the new power supply, is it easy to install myself? Will I have to do any soldering? I am not any...
Hi Scott,
Replacing the power supply board is not quite technical, no soldering required. But before an attempt to do so, let stand the unit for 1 hour to drain the main filter electrolytic capacitor. Power supply board is where the power cord directly connected. Pull-out all the cables connected from the existing power supply board and then put in the new board, re-insert the connectors and ensure that it is properly seat-in.
Click this link for the replacement or obtain it from your local Polaroid Service Centers.
Hope I helped you.
Thanks for using Fixya.
Jdvillanueva
Jun 05, 2011 | Polaroid FLM-4034B 40 in. LCD HDTV
I have an element TV with a MLT070A power supply board. I'm not an electrical guy, but a technician came out and showed me the bulged caps and said that was what's wrong with the TV. He said he...
power supply board is dead, if you know basic electronics' and soldering you can handle it ? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.
Good luck in solving the problem.....
May 17, 2011 | Televison & Video
55' sony grand wega will not turn on. The green light blinks 5 times and then red light blinks 6 times. red light cycles 6 times again. What is the problem? Can I fix it myself?
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care.....
Dec 07, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony FWD 42PV1 LED shows green light when powered on and switches to red after few seconds without showing anything on the display.
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your Tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care.....
Aug 11, 2010 | Sony Televison & Video
When i turn the power on the tv clicks for up to ten min before the picture comes on. is this fixable?
Yes,very fixables.Ur tv power suppply board have these parts call capacitors.They are dead and gases leakages,not total,but dying.These capacitors they alway bulges up on it top,puff up on it top,these capacitors are dying,that why tv still have power but it take up to ten min. clicking to recieve power to the rest of the tv.The power supply board,that the board where the power a/c cord plug into it.U have basic understanding of electronic's?U have tools,soldering iron,desoldering pump,solders?Take the tv aparts.U just looking,searches all around the power supply board and replaced these dead,dying capacitors that are bulges,puff up on it tops.Replaced these gases leakages capacitors,ur tv will have it power back to normal and work on the first click.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 04, 2010 | Samsung LA40A450 40 in. LCD TV
Computer won't start The voltage switch on the power supply was accidently changed to 230. Is it fixable
Most likely not, the power source is dead, replace it. It's a standard ATX source, any 400W one you can buy from all IT shop will do.
Apr 25, 2010 | HP Pavilion 7955 PC Desktop
Every time i switch on my tv, nothing happens. After i,ve powered up about ten times then it starts ok. this is,nt right surely!!!!!!
Ur tv power supply board have these dead parts call capacitors,they have leakages of gases,they bulges up on it top or puff on it top.These capacitors are dead,must be replaced to get the power supply board to be working normal again.U know basic electronic's,know how to do soldering?U have tools,soldering iron,solders?Seaches out these dead capacitors,that are gases leakages bulges up on it top or puff up on it top in the power supply board,that the board where the power a/c cord go into it,that the power supply board.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 04, 2009 | ViewSonic N4060w 40 in. LCD TV
Sceptre X37sv-Naga 37 in. LCD Television Logo
725 people viewed this question
Top Sceptre Televison & Video Experts
Henry  Thomas
Henry Thomas
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
