Question about Whirlpool Duet GHW9150P Front Load Washer
FRONT LOADER WREAKS LIKE MOLD...
I have used the HOTTEST of HOT washes with bleach, left the door ajar, etc... nothing helps.
  • pbcapp Oct 03, 2009
    OKAY - I got my head in the washer, pulled that rubber ring back and found a rotting sock and lots of mold. Have been leaving the washer door WIDE open to thoroughly dry out, too. Never new I should have cleaned there before and should do it after every time using the washer. The smell is much better... we will see how long it lasts!!! :)
  • 101 Answers
I had same problem eventually the thing wouldn't go through a full cycle,I found a small piece of cloth was plugging off just before pump and letting water stand at bottom of washer which is what caused the water to stink.
Posted on Oct 02, 2009
Clothes smell after washing cycle
Nice, or not nice?
To get rid of the mildew odor, run an empty machine on the hottest setting with bleach or Affresh ($8, homedepot.com), a cleaner that deodorizes a washer's interior. And after each load of laundry, leave the door ajar to allow the interior to dry.
How to Get Rid of Mold Smell in Front Loader Washing ...
www.wikihow.com > ... > Housekeeping > Cleaning > Laundry Jump to Preventing Smells in Your Front Loading Washing Machine - Part 2 of 2: Preventing Smells in Your Front Loading Washing Machine.
how to get rid of a bad smelling high efficiency washer ...
wholelifestylenutrition.com/.../learn-this-tip-say-goodbye-to-bad-smellin... Learn this tip and say goodbye to bad smelling HE washer machines forever! ... Not only did it smell moldy and musty but my clothes were starting to smell this ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Why Your Washing Machine Smells, and How to Clean It
laundry.reviewed.com/.../why-your-washing-machine-smells-and-how-t... Add this solution to your machine's detergent container, pour two cups of white vinegar into the drum, and run a normal load at high heat. The baking soda and vinegar should break up any residue stuck to your drum and kill any mold that might be present.
Washing Machine Smell on Pinterest ' Smelly Washing ...
https://www.pinterest.com/explore/washing-machine-smell/ Great tutorial on how to clean your front load washing machine, get rid of mold and mildew and prevent it from returning. I clean mine after every wash (a little ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Why Does My Washing Machine Smell Like Mildew? - Real ...
www.realsimple.com/home.../cleaning/.../mildew-smell-washing-machine To get rid of the mildew odor, run an empty machine on the hottest setting with bleach or Affresh ($8, homedepot.com), a cleaner that deodorizes a washer's interior. And after each load of laundry, leave the door ajar to allow the interior to dry.
Jan 09, 2016 | Washing Machines
I AM ALWAYS GETTING MOLD INSIDE THE LG FRONT LOADER. THE RUBBER SEAL IS ALWAYS MOLDY
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. If the growth is very high then try and leave the door open for 4-5 hours and let it dry and then spray the bleach+water (3:1) mixture on the seal. Let it dry for another 2-3 hours. You may need to change the seal in case of extreme growth of mold. Hope this helps...
Daniel
Aug 30, 2010 | LG WM-2077C Front Load Washer
I heard you are suppose to clean the washer once a month to prevent mold,is that true?
I have never cleaned my washer as i use bleach in with the whites when i wash. its up to you. they do make a cleaner for that.
Oct 31, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Duet washer is stinky.I leave the tub door and the soap dispenser door open when not in use. Even so, epecially after doing several loads in a row I have a very stinky machine There is mold growing on the...
are you on a well??
do you use bleach in with your whites??
some well water untreated can cause exceptionally stinky machines, especially if no or very little bleach is used during white washing..
usually if you use bleach in with your whites in normal amounts and leave the door open in between uses there should be very little stinky odor or mold growth.
the mold growing on the gasket is a sign of to little bleach or none being used, and/or a really damp environment for the unit to reside in.
they do make several cleaners designed just for stinky front loader washers..
they might help..
i've been using a front loader for 13 years, leave the door ajar between uses, and use bleach in every white load and have had no issues with stinky unless i or someone else doing wash forget and close the door for a couple days, then it gets stinky but goes away after white load with bleach and hot water..
hope this helps,
best of luck,
ttfn
Oct 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Mold and mildew in door deal of LG front loader WM
Barb,
This is a problem with all front loaders. We have used those cleaning tablets in a regular hot cycle per the directions on the box. You can also try placing 1 cup of crystal dishwashing detergent in the tub and fill the soap dispenser with bleach and run a quick cycle full hot.
Aug 09, 2009 | LG WM-2277HW Front Load Washer
I have mold growing where the rubber seal is around the door. I have a ine year old and I am worried about washing his clothing.
A nicely moist area,
...could try to kill all the mold with dilute chlorox (put some in a spray bottle--can also use on feet after the gym to prevent contamination from athlete's foot/feet)(or the shower mold killers which usually just have chlorox [sodium hypochlorite or similar]); then in future leave the door ajar when not in use so the area can dry (assume front loading), and if it is the large gasket style that still leaves a moist area behind itself--could put a wedge like a popcicle stick or few to allow air behind the gasket.
...any mold that is visible and therefor in contact with the clothes going in and out, should be easily removed...there should not be any mold in the washing compartment as the bleach and hot water used for whites would always kill the mold; so the only contact point is at the exterior (cleanable) when removing finished clothes.
..likely there is plenty of mold exposure in his environment beyond this----this is nothing like the problem with flood contaminated walls/floors and unseen mold that could spew forth significant amounts of spore load.
Aug 09, 2009 | Washing Machines
Black mold growing on gray rubber boot inside door.
Leave washer door slightly ajar after use to air out any moisture. Should prevent any future mold.
Apr 10, 2009 | Frigidaire Affinity ATF7000E Front Load...
Mold & Smelly in Washer
Wash on hottest and longest cycle with regular laundry soap and a bottle of vinegar. After cycle, wash again with soap on hottest/longest cycle. This will clean your washer like new.
Nov 21, 2008 | LG WM-2277HW Front Load Washer
Mold and mildew in the Maytag Neptune MAH5500
The new boot has an anit-mildew treatment and should resist any new mold. Also, you should always use the hottest water possible for your clothes, the hot water helps kill the bacteria that causes the odor. Also bleach will kill the bacteria and you should use bleach whenever possible. If you don't like to use bleach on your clothes, or have an allergy to it, then once a month, run the washer without any clothes on the normal cycle, hot wash, and put bleach in the soap dispenser and let the washer clean itself out. The boot is fairly easy to replace except for a spring that holds the boot to the tub front. The spring has a lot of tension, so it is difficult to hold both ends of the band and one end of the spring tight enough while streching it. I usually do it with a pair of vise grips and a pair of pliers, but I've replaced dozens of boots. You may need an extra hand to help with your first one. Other than that, if you pay close attention to how it came apart, and align the all the slots on the boot to the tabs on the tub front, and door shroud, than you shouldn't have any problems.
Jul 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
110 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
