Question about Nikon 15mm f/2.8N UW-Nikkor IC Lens
Nikonos v with Nikon 15mm f/2.8N UW-Nikkor IC... > for sale
I don't know what the camera ,15mm,28mm,viewfinder #nk10758,ekilite SB 150,helix close up tubes,nikonos close up outfit,and pelican case
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 149 Answers
Good lord! That's a NICE underwater system you've got. What type of help are you asking for? Just from your equipment list, if everything is in good condition, you've got at least 1500.00 worth of stuff! A new 15mm sells for $2,240, the camera, new, $750.00, eiklite flash system is up there, the extra close up gear ain't cheap either! And a pelican case--well, if yer gonna go snorkeling or scuba, you're all set! The 28mm can be used for land lubbing or underwater. To properly prepare the camera, the most important thing is to check the condition of the o-ring around the film door. If any doubt, replace it!! The same applies with any other o-ring seal. *Properly* greased, an O-ring in good condition simply looks wet. Use a good quality, pure, silicone grease all over the ring and don't blob it on--It can be purchased just about anywhere. Check the o-rings on all the other equipment--same rule applies. Salt water damage is u-g-l-y. Before opening up the camera after being in salt water, rinse all equipment in fresh water and dry completely. Don't detach any cords or lenses until all are rinsed and dry! (When cameras and salt water come together improperly, think horror movie acid bath results--and you won't be far off) I used 36-picture rolls of film so I wouldn't have to open the cam as much. Heh, in the excitement of photoing fish, yer gonna burn some film.Hope I assisted you!---Rick
Posted on Oct 02, 2009
AF Nikkor 28-85mm f/3.5-4.5 Below 35mm it can't AF and then no picture. It should only be below 28mm after pressing the button that only manual focus is function. Camera Nikon D90.
This looks like you have a broken ribbon cable in the lens. It will need to be replaced. It's a small job for a reputable repairer.
Nov 26, 2015 | Nikon Cameras
Which slave-unit to use for firing my Nikonos SB 103 underwater flash
Another SB103 they work together you have to set one to slave
The other in command mode
Apr 17, 2014 | Nikonos SB-105 UW TTL Speedlight Set 11202...
SB105 connector broken
Yes you are right when broken it does not work properly
Feb 10, 2014 | Nikon 2 Sets Of Nikonos Sb 105 Strobes
Repair loose shift on 28mm pc
hello,there is a very tiny screw on the barrel that you can nip up with miniature screwdriver,if your not too certain how to go about it,there are a few websites,esp in japan,that give detailed instructions,or contact -old timer cameras-based in Essex,they are also on the web,as they have every possible available instruction manual to repair cameras and lenses. hope that helps, cheers.
Aug 19, 2013 | Nikon AF 28mm f/3.5 PC-Nikkor Lens
I am using a Speedlight sb-800 on a Nikon D200. I cannot get the Zoom M function to change to Zoom. Any ideas?
Take flash out from hotshoe.
Can you set flash zoom manually?
When using Nikon Nikkor zoom & zooming, does flash zoom or hear motor sounds from head?
atdlee@netzero.com
Jan 16, 2010 | Nikon Speedlight SB-800 TTL Flash
I HAVE NO IDEA WHAT I HAVE HERE... I
Hey LELAH,
This lens is intended for a Nikon underwater camera which are branded as Nikonos cameras. These cameras are underwater 35mm cameras and this lens is and extreme wide angle lens to capture underwater scenic’s. This lens is rather expensive and of very high quality. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 17, 2008 | Nikon 15mm f/2.8N UW-Nikkor IC Lens
AF not working on Nikon D80
release the lens at smallest aperture then reattach....
Jun 23, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon 15mm f/2.8N UW-Nikkor IC Lens Logo
415 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
