Question about Milwaukee Drills
Fix a broken chuck assembly on a Milwaukee 5303-20 rotary
On a lark I purchased a Milwaukee 5303-20 rotary hammer drill that was missing some parts behind the chuck. I am purchasing the missing parts, (collar, rings, ball bearings, springs, etc.) but now wondered if it is hard to assemble the quick change parts I just ordered. Would this operation require special tools or skills?
Thanks. The chuck itself is fine, just what it attaches to needs fixing.
  • 2,176 Answers
No hard at all go to Milwaukeetool.com and type in your model number and you can download a parts schematic for this showing the complete assembly directions.
Posted on Oct 02, 2009
Quick change clutch is locked
Push the rubber sleve off the drill bit and up the drill bit then the plastic ring. release the clip around the spindle. Slide the clip and chuck sleve forward and remove the ball sitting in the spindle. You should then be able to pull the bit from the machine. If it does not want to come hold the bit in a vice and tap the spindle off the end of the bit using a suitable punch. Rebuild chuck in reverse.
Jan 29, 2013 | Milwaukee Electric Tool Milwaukee 5359 -...
It has broken chuck slot, need to be replaced
You can purchase replacement chucks from Hilti. 800-879-8000. Just put the end of the chuck in the palm of your hand. with your fingers pull the sleeve towards the palm of your hand. Then just pull the chuck off.
Aug 07, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
How do I remove the sds chuck to fit the standaed chuck
The SDS chuck is an intergral part ot the rotary hammer drill assembly. You can get a standard chuck that has an SDS fitting on it and that will fit into your drill and give you standard drilling capabilities.
Mar 07, 2011 | Makita Garden
The chuck on my Hilti TE 24 hammer drill keeps falling off. I doesnt appear to be anything broken. Either there is a missing snap ring or I am just not putting it back on correctly. Any suggestions?
the header list 2 different drills, if yur chuck has a colllar with a quick release, I would suggest thoroughly cleaning and then using a lubricant, usually there are steel balls that lock into detents in the spindle and they might be stuck the collar should move freely.
Sep 25, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Put drill in revcerse and the chuck comes loose dropping the bit out
Yup, that is what happens. You can lessen that by really cranking it down, but it is an issue with most hand tightened chucks, and does not indicate a mechanical failure. I sometimes miss my old, heavy Milwaukee wrist-breaker with the keyed chuck. If it is just too much to live with, you could get a drill with the click in hex chuck or put a Jacobs keyed chuck on your hammer drill.
Anyway, I hear where you are coming from and share your frustration.
Regards, Farmerbear
Sep 09, 2010 | Dewalt 18 Volt Xrp Heavy Duty Hammer Drill...
I have a really old Milwaukee 3/4" rotary hammer, I don't know how to get the bit out, any help would be greatly appreciated
if it does'nt have a keye'd chuck, it may have arubber collar,spary some lube down into chuck and firmly push down,w handle agains't ground or other firm surface
Apr 20, 2010 | Milwaukee 3/4" Rotary Hammer Drill Heavy...
I am trying to buy a sds chuck for my milwaukee plh 32xe rotary hammer drill
you can buy an SDS chuck that gos into a normal drill chuck,, it cant spin in the normal drill chuck as its got a hexsy drive on it its a much cheaper way to go and will fit any other drill you have or will ever get
Feb 16, 2010 | Milwaukee Drills
I need a parts manual for a milwaukee 5316-21 rotary hammer drill , where can I get one?
Go to Milwaukeetool.com and look under parts manuals. Type in the model you need and all the electrical/parts drawings will come up. You will need the serial number as well to get the most current drawing.
Feb 12, 2010 | Milwaukee Tool Milwaukee Hammer Drills 1 -...
Remove broken drill bit
soak the chuck area real good with W/D40 or similar,position drill so lube doe's not drain .let sit for awhile, then turn upside down and gently whack it about, worked 4 me,
Oct 04, 2009 | Milwaukee Tool 1 - 1/2" SDS - max Rotary...
Stopped working in mid drill. squeeze the trigger, nothing happens
It could be a dirty switch connection in the trigger assembly , it happens to me on my electric sanders all the time , just open it up and try blowing it out with an air compressor
May 23, 2009 | Milwaukee 5318-21 1-1/2" Spline Rotary...
Drills Logo
313 people viewed this question
Top Milwaukee Drills Experts
Jim Thurston
Mike
Are you a Milwaukee Drill Expert? Answer questions, earn points and help others
