Fan always running
My laptop is 3 years old, and a few months ago I noticed that the fan is almost always on. It seems the computer is overheating, as it's hot to the touch, which is why the fan is probably always on.
Is this something that can easily be fixed? I'm concerned that one of these days it simply won't turn on.
    Sergeant:
    Champion:
  • 255 Answers
Vacuum out air ports/power supply fan or use compressed air in a can to clean out dust.
yes this is bad, life is greatly reduced.
clean dust out once every other month or as needed.
Posted on Oct 02, 2009
Why doesn't my fan rotate anymore?
definitely sounds mechanical. try prying open the motor area and see if anything happens when you turn it on. i'm guessing it might be a short somewhere that's making the other parts have to compensate
also check into servos, relays, and whatnot
May 15, 2015 | Miscellaneous
Laptop sometimes switches off when moved.
Sounds like a loose connection where the laptop opens and closes hinge there are wires that run from the main screen to the main board. If you know how to take the unit apart it maybe a cheap fix if not then a new laptop maybe the way to go the prices have really dropped from 4 years ago
Jan 12, 2013 | HP Hewlett Packard Compaq 6720s Laptop...
The laptop screen flickersand turns grey, it also get hard to see. It gets worse the longer the laptop is on. The fan seems to be running much more and a load grinding noise came from the fan a few months...
You could try using compressed air to clear out the fan, but most likely your system is overheating and the longer you go without fixing it the worse and more permanent issues it will cause
Nov 16, 2017 | Toshiba Satellite A105-S4004 Notebook
My acer laptop is about 6 months old and was working great till few weeks ago , i had to format few days ago because it was lagging overheating missing files discont me on line every 2 mintues , wouldnt...
If your internet is not working properly then reset your router and configure again.
Scan your computer with updated antivirus.
Also check RAM memory is works fine.
If it over heat then put extran fan so it control heat.
let me know if you need further assistance.
Thanks.
Oct 30, 2009 | Toshiba Portege 7100 Notebook
Acer Aspire 4315, making noise near fan
You would need to open it, has the laptop been dropped? This is the only way I know that could cause this problem. I suggest you fix this problem because it will cause overheating of you chips, that will eventually cause failure. Opening a laptop is not for novice, unless you trust yourself you can do it, have it done in a shop that fixes laptops. Some electronic shop can do this for you at a resonable price.
Jun 30, 2009 | Acer Aspire 4315-2963 Notebook
Dell Inspiron 9400 display goes blank after a few minutes
If the issue occurs in the safe mode, then I'm suspecting a failure of the LCD backlight. (It warms up and quits) Also see if video stays on using an external monitor. If it does, then the LCD is most likely failing.
If video goes out on an external monitor as well, then the Video card is failing due to overheating. Make sure all vents are free of dust (Clean with canned compressed air) and the all fans are functional (Run the fan test in diagnostics) If fans check up, then video card is failure point. If fans fail diags, replace affected fan 1st
May 21, 2009 | Dell Inspiron 9400 Notebook
Laptop shuts OFF on it's own
Laptop fans DO NOT run constantly. They only turn on when booted up and once the laptop has reached a certain temperature. You should probably time how long for a shutdown, record your results. Let laptop cool for 10-15 between attempts. If it takes approximately same amount of time to shutdown between attempts it is very possible its overheating.
Other things like Viruses, software conflicts, and Harddrive problems can also be the culprit. take a look at the administrator event logs for any clue there. Event logs are in control panel under Administrator Tools.
I don't recommend trying to fix any overheating issue you may have, as that would entaiil disassembling your laptop. Unless you have a bit of experience in this, I would take it to a good repair shop.
Hope this helps you some. If so please rate my solution.
May 10, 2009 | Dell (6F858) Cooling Fan
Fan not going on and interface really slow
turn it off for an hour see if that works could be overheating
Dec 21, 2008 | Dell Latitude C400 Notebook
Laptop Overheating
i have read lot of same type of problems,with acer,if it is under warranty send it before end, there is fee of 449.00 for out of warranty notebooks. my 5100's have problems,very unhappy! with acer good-luck!
Jun 21, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
145 people viewed this question
David Payne
David Payne
