Question about Philips 60PP9363 60" Rear Projection HDTV-Ready Television
60pp9363h/17 tv has got convergence issues and a tech shop has it now but says they can't fix it, parts aren't available and what parts they have tried havn't worked so far?????
  • Philips Master
  • 3,459 Answers
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
60pp9363h/17 tv has got convergence issues and a - bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Oct 18, 2009
  • Philips Master
  • 1,210 Answers
You need to replace the small signal module. Also called the tuner and convergence IC board. You need to copy the model # and Chassis # on paper and call Andrews Electronics for a refubished board Phone# 1 800 274 4666 or PTS Electronics at 1 800 844 7871 to repair your present board. UCANDO...Good Luck the fix is there.
Posted on Oct 02, 2009
Convergence bad on my 60pp9363h what part do i need to order
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 01, 2011 | Philips 60PP9363 60" Rear Projection...
Magnavox 51mp3964H/17
You need to replace Both of your STK convergence ICs they are big black ICs will have part number on them STK392-110 ,ect if you can solder you can fix it your self ,TV repair shop m/b 300.00 also you will need Service Code to be able to enter into TECH alinement mode .Call Mats Electronics for parts 1-800-628-1118
Aug 18, 2009 | Philips Televison & Video
The projection bulb blew up in my Philips 60PP9363H/17. Repair man says this model takes no bulb/lamp. The shattered glass is in my tv from a bulb/lamp so it has to take one. I need to know what part...
Vendor nap.jpg Part Number 483513127193 Description Crt P16ltg Substitute Part n/a Estimated Weight 1 Lbs. Availability by Warehouse Atlanta, Ga 3 Las Vegas, NV 1 Baltimore, MD 1 Miami, FL 1
Total Availability 6 Estimated Ship Date in stock Core Price 0.00 Part Price 303.01 Total Price 303.01
There is something very bad if you have broken glass on the inside of this TV, it is a CRT rear-projection. The tubes might be available, but the labor will be over $300 plus the parts, plus, this TV may have issues in the future. I suggest looking for a 50" LCD or Plasma, Vizio is great because it is LG parts inside, but definitely get the extended warranty.
I hope this helps
Jul 25, 2009 | Philips 60PP9363 60" Rear Projection...
How do you get to the convergance menu on phillips 60pp9363h/17 tv
Here are two tips from www.TvRepairKits.com
"You must have the original remote. If so you can access the convergence screen by hitting the menu key"
Jun 04, 2009 | Philips 46PP9302 46" Rear Projection...
Phillips 60PP9363H/17 Picure warped and collor drifting
You have a convergence chip problem. You need to get a kit from www.TvRepairKits.com.
Note: The longer you run your set with a convergence problem the more problems you will have. Turn it off and get it fixed.
Nov 14, 2008 | Philips 60PP9363 60" Rear Projection...
Philips 60pp9363h/17
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Hope this helps,
Ed
Sep 09, 2008 | Philips 46PP9302 46" Rear Projection...
Phillips hd projection tv/ model 60pp9363h/17
thats a common problem with all projection tvs. You will need to replace both convergence Ics and 4 resistors. You will need two STK392-120 Convergence ICs and four 6.8 ohm 1watt resistors. You can get replacement parts at the following link and they provide free instalation instructions so you can do the repair yourself. heres the link.
http://servicemanuals.vstore.ca/
Sep 01, 2008 | Philips 46PP9302 46" Rear Projection...
Picture is warping and colors are seperating giving a picture that looks like a 3D picture without the glasses
you need to replace both convergence Ics. Post the model number of your set and I will post the correct IC numbers as well as alink where you can get replacements with free instalation instructions. Respond to this same post so I will have access to your symptoms when you post the nodel number.
Jun 30, 2008 | Philips 46PP9302 46" Rear Projection...
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jan 11, 2008 | Philips 60PP9363 60" Rear Projection...
Do you want a convergence board? I think it is the SSA module. You can get a new one from partstore.com or I have a used module from a scrap unit.
Dec 29, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips 60PP9363 60" Rear Projection HDTV-Ready Television Logo
308 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
