Question about Garmin GXM 30 Antenna
Garmin GXM30 stopped working. what is the usual reason for this? Driving along in the morning, the sound started to sound'' fuzzy'', I went to try a different channel and immediatly lost all XM radio in my Garmin Zumo 550. I tried it in the car cradle still no XM or even recogniton that the antenna is hooked up. The lack of the Zumo seeing the antenna leaves me to surmise the antena died, and that it was not probably the wire connecting it to the Zumo but an electronic component inside the antena. It has in effect ceased to send any signal. Everything else about the Zumo continues to function perfectly.
  • Garmin Expert
  • 184 Answers
There is very little to those pucks. If you have tried it in two devices then the electronics have gone bad. Blame a solar flare or something but it will need to be replaced
Posted on Apr 25, 2017
SOURCE: no power
I had exactly the same problem with a 3 month old Zumo 550. Removed battery, waited a few minutes and replaced. System now poers on OK. All data on-board was retained.
Posted on Jan 04, 2008
  • 174 Answers
SOURCE: Garmin Zumo wired headset
I bought a wired motorcycle headset, which does works okay (below 50 mph), didn't like the wire so I switched to a BT helmet kit, manufactured by interphone, works like a charm.
Posted on Jun 09, 2008
  • 1847 Answers
SOURCE: Zumo 550
is the battery working fine.
Posted on Oct 21, 2008
  • 174 Answers
SOURCE: my zumo won't power on
This sometimes happens if the cradle is owered while you connect the zumo...i guess it hits some wrong contacts first and goes bonkers. I'd advise th zumo users to pack a small allen screw bit to unscrew the battery, just in case it freezes or blacks out again....better safe than lost in the middle of nowhere!
Posted on Oct 27, 2008
SOURCE: garmin zumo switch on problem
Use the allen wrench to remove the battery. Let stand for 5 minutes and replace the battery. It should start fine. Mine has done this 3 times since I purchased it.
Posted on Jan 30, 2009
It is also 7+ years old. in technology years that is like 140 years old. retire it and get a Nuvi.
Remember that time you went to start your car and it worked yesterday but today it would not start... bad stuff happens.
If you are holding out hope, try leaving it plugged into the car or outlet
try holding the power button for a long time (30 sec)
try plugging it into a computer and see if anything happens.
Mar 22, 2015 | Garmin GPS
I have a 2002 gmc yukon xl. While driving home at 50 mph, the abs light came on and then the message screen said low fuel, and then all the gauges stopped working. The vehicle just shut off, so i pulled to...
from the sounds of it it either had a voltage drop to the chassis or a ground connection fault, my guess is a the ground to chassis went bad, reason is grounds usually cause multiple systems failures, its time consuming to check the all , but first check all fuses
Apr 12, 2011 | 2002 GMC Yukon XL
I currently own a 1986 Ford Ranger 2.9 V6, RW Drive. Was driving like a charm!! I was driving it yesterday morning, no problems, I parked it after 10 minutes of driving... Last night I went to start it, it...
The cranking will usually sound different after the timing chain has slipped. Does it spit or backfire when you crank it? I suggest you rule out some easier things before going after the timing chain. If you are getting spark and fuel, then maybe I would take a peek at the timing chain to see if it has skipped on the sprocket.
Please see my tip at . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
Nov 25, 2010 | Ford Ranger Cars & Trucks
1999 Hyundai Tiburon losing complete power while driving
sounds like the alternator is going out sometimes it works sometimes it doesnt it will blow the battery up if not taken care of
May 03, 2010 | 2003 Hyundai Tiburon
My garmin nuvi 255W has been working fine. I
Try resetting your unit with the reset button on the bottom. If this doesn't work, slide the power button all the way to the left and hold it for 8 seconds.
Dec 30, 2009 | Garmin nuvi 255W GPS Receiver
Stereo stopped working along with speedometer
It's probably not a fuse. It sounds like your vehicle speed sensor went bad in the transmission. The reason your radio stopped working was because your radio is probably equipped with speed sensitive volume and it requires a speed signal to work.
Apr 10, 2009 | 2001 Ford Taurus
When i start driving my cd player will get all fuzzy
ok so your 1st problem is its a jenson.... known for common problems such as this... i would try connecting another cd/radio to the car and see if that solves any problems
Mar 19, 2009 | Jensen MP7610 CD Player
KVT-719 NAV button not highlighted unable to select
Well I see no help here, but emailed kenwwod and they told me:
The Garmin menu is not accessible from the main source select screen, only thru the V.Select which you have already discovered.
The reason why "NAV" is displayed as an audio source is if you were to add a GMX30 XM Radio/NavTraffic antenna, you would be able to access XM radio (subscription required). So unless you have the GXM30, you will never use that source key.
Jul 12, 2008 | Kenwood KNA-G510 GPS Receiver
99 dodge dakota jerky behavior
sounds like your fuel injectors, check and replace the injectors.
Jun 22, 2008 | 1999 Dodge Dakota
Garmin GXM 30  Antenna Logo
113 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
