Question about Whirlpool Washing Machines
Replaced motor cuppler with new and still have bad shakes and very loud while in wash and spin mode? I cant see any balance springs that are off on my roper what is going on
  • 612 Answers
There are three supports that if not on your machine will cause it to make loud noise and shake due to the outer tub riding on metal on metal. These are located on all three straight frame bars. Look at this sight and you will see the parts I'm referring to.
http://www.partselect.com/PartDetail.aspx?Inventory=334620&SourceCode=6
If these are bad or they are gone, replace them and your problem will be solved.
Please rate solution. Thanks
Posted on Oct 02, 2009
Machine goes out of balance & vibrates on spin cycle
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Mar 19, 2015 | Washing Machines
My neptune front loader shakes or start jumping like its off balance right from the beginning
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Mar 18, 2015 | Neptune Washing Machines
Bangs when it spins
usually the sign of a bad transmission spling or tub splines going bad, even a going bad motor coupler, a damaged counter weight.
try these LOUD NOISES IN washing MACHINE;
A worn drive block will usually have a pounding sound, like hammering metal, during spin when it first starts. If there is enough interlocking tab left on the drive block, you'll see it finally engage at top speed with an empty basket.
In a transmission lock up the holes get enlarged in the rubber isolator and the studs break off the motor and transmission couplers. This is usually caused by the abrupt motor reversal between the agitate and pump out functions. If you hear a loud bang every time the motor reverses, the coupler is getting loose. An obvious sign of a failed coupler is a pile of black rubber shavings under the washer. If the motor runs and the agitate and spin functions don't work, the studs may have broken off the coupler (old coupler design) or the coupler may have broken at the shaft (new design) and you need a new coupler kit. The coupler can also just crack around its center hole allowing it to slip on the motor or transmission shaft hampering those functions.
Mar 17, 2015 | Roper Washing Machines
During the spin time machine was so much shaking and jamb loudly. so what the problem
Support spring(s) have come off, load is badly out of balance, inner bowl is loose.
Mar 17, 2015 | Sanyo SW-1150T Washing Machine
Will not complete spin/rinse cycle - shakes big time
sounds like he just wants money? No spin, try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sep 04, 2014 | Whirlpool Cabrio WTW6600SG 4.6 Cu. Ft. Top...
Washer is loud when spinning out
Aug 20, 2014 | Whirlpool Washing Machines
TOP LOADER HEAVY DUTY SHAKES WHEN SPINS
Jul 14, 2014 | Whirlpool Washing Machines
Why does frigidaire fahe4044mwo shake bad in spin cycle ?
By the way my advice is free cuz God is good!
GRINDING NOISES:
The plastic drive is known as a splutch (splined clutch). One problem with these washers has been loosening of the nut that locks the pulley to the agitator input shaft. If it gets loose, the pulley drops and the teeth no longer have good contact with the teeth of the splutch basket drive gear in spin mode. The solution is application of blue locktite to the threads of the input shaft. There have also been a lot of failures of the actuator that operates the cam ring of the splutch which raises and lowers the basket drive gear. It is raised for agitate mode and lowered for spin. There is a spring between the basket drive gear and the gearcase housing that maintains pressure on the basket drive gear. There are cams on the cam ring that ride up and down on cams in the splutch cam (housing) as it is rotated by the actuator thus raising and lowering the basket drive gear. The gearcase has a planetary gear set in it.
Jul 02, 2014 | Frigidaire Washing Machines
Admiral Heavy Duty 22lb. 2 speed motor going off balance
Had Same problem. Replaced The 6 retaining springs and snubber.
$15.00 worth of parts.
Dec 22, 2007 | Admiral AW22 Top Load Washer
GE WSM2780W Stacked Washer spin cycle
With no clothing in the wash tub take the following steps:
1. remove the front cover from the wash tub
2. run a full cycle of laundry and observe the tub's behavior
Potential Solutions:
A. If the tub begins to shake wildly during a full wash cycle with no clothing in it then you will need to adjust the 3 large springs on each side of the tub until the unit is working in a more-balanced position. This is simple to do by hand. If the tub appears to be shaking too far forward, then unhook the 2 large springs in back so they are tighter. Then run a full wash cycle again with no clothing.
* note: there are smaller springs too - you don't have to adjust these to fix your issue
B. If the tub works fine with no clothing during a full wash cycle, then try to load your clothing in a more balanced fashion. For example: if your wash load is only a small kitchen or bath rug then when the unit spins it will spin off balance with a wet & heavy item on only one side of the tub.
C. If you'd like to replace the 3 large springs, I can get you the part numbers. There are specific springs for both sides of the wash tub and they are different part numbers. The full replacement of the 3 large springs can be done by hand.
thanks,
Chris I.
Sep 24, 2007 | GE WSM2780W Stacked Washer / Dryer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
