Question about Garden
Pressure washer will not start. when I go to pull start, red light on the on/off switch flashes
  • 148 Answers
The light is an indicator of a "Low Oil" condition.
Check / Add engine oil as needed and try again.
Hope this helps!
Posted on Oct 02, 2009
GFWH1200DWW GE front load washer won't unlock red lock showing
From an article I found online:
See if manually opening the door will reset everything. Unplug the washer and remove the lower front panel like you're going to clean out the drain catch. Once you remove this panel you can reach up behind the upper front panel and pull down on the small plastic pull tab attached to the bottom of the door lock assembly. This will manually unlock the door so you can open the door.
Now once you have the door open, plug the washer back in and see if you can start another cycle.
Mar 06, 2016 | GE Washing Machines
Oil light flashing
oil light means loss of oil pressure.. not good ..check oil level fill to full if low..low oil pressure will cause fuel pump to be shut off..
Dec 08, 2013 | 2001 Ford Escape
1650 husky pressure washer starts and then stops
If you are not squeezing the handle to let the water out, it will shut off.
Nov 30, 2013 | Garden
I have a pressure washer with a hondaGC160 5.0 engine and i can't get it to start
1. make sure you have all fresh gas in the tank. 2. choke on 3. engine switch on (red thing on the side) 4 fuel switch on 5 make sure pressure is off hose (keep the trigger pulled) mess around with different choke positions and see if that works
May 15, 2011 | Honda Karcher G2400HH-R Pressure Washer
Hi! I have a Zanussi IZ12 washing machine. After I turn it on, the door will not open and start/pause button just flashes. (I can select program and press start/pause, it just beeps, but the machine do...
I've had the same problem. I removed the top lit and found some pressure transmitter and a pressure switch. I suspect that the pressure transmitter is use for measuring the waterlevel in the machine. I think the membrane loses its flexibility over the years.
I pulled of the hose from the transmitter and blowed and sucked a few times on the transmitter. After doing this the machine washes without a problem since then.
Hope it helps for you.
Jul 14, 2010 | Zanussi IZ12 Front Load Washer
Simpson ezi loader washing machine clicks 3 times then the end button lights up without even starting the cycle. does anyone have a solution for this?Solve this problem 1 2 3 4 5 6 7 This is a... Solution...
It sounds like a door switch fault see if the end light and the start/pause light are flashing count the flashes if end flashes 4 times and the start/pause once or maybe more this could be error 41, door switch fault.A door switch would cost about $ 20 but there may still be a problem with the main Programmer.
Good luck.
Apr 27, 2010 | Zanussi FS1455W Front Load Washer
Machine stopping mid cycle
Count the number of green flashes(1st number of error code). count number of red flashes(2nd number of error code).
Common codes are:
E10 or 11 water pressure faults.
E20 filter/pump faults.
E30 pressure switch/heater faults.
E40 door switch faults.
E50 motor faults.
E60 Heater faults.
These are some of the error codes but there are many variations on some codes depending on the model.Hpoe this has been some help.
Apr 24, 2010 | Zanussi ZWF10070W Front Load Washer
Machine fills w/water quits flashes lb? lz?
There is a water pressure switch that operates when the required water fills in the tub. this pressure switch in your machine is possibly faulty. In ur case the water keeps filling then it detects an error and stops that's when the lights start flashing. the pressure switch fails to detect the amount of water in the drum and so the machine doesn't move on to the next cycle
Oct 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Craftsman model 580.752020 electric pressure washer. First time I used it worked for about three minutes then the motor stopped. I cannot get it to start again. Plugged into a 15 amp gfi circuit which did...
turn off water and machine electrics.
remove high pressure hose from front of machine, this may be tight if there is still pressure in the system.
turn on water, when water comes out of machine hose outlet turn on machine. does the machine turn on and water flow increase, if so you probably have a blocked lance jet or trigger.
remove lance extension if fitted and fit hose back to machine, try again. If its ok then this proves you have a blocked lance jet, maybea poke about with some stiff wire will free the obstruction.
If this doesnt bring on the machine you probably have a jammed pressure switch on the pump.
this pressure switch turns on the pump when the trigger is pulled and switches the motor off when the trigger is released.
hope this helps.
Jul 16, 2009 | Electric Garden
Intake/drain light flashing
I have (had) the exact same problem with my Miele. Here is what (appears) to have fixed it:
1) Disconnect the inflow line at the water source. Its the connection that looks like a garden hose. Use a screw driver to remove the washer inside, the pull out the little filter with needle nose pliers. My was clogger with particles from the washer. Clean with soap and a tooth brush.
2) Disconnect the outflow line at the garbage disposal. My was moderately clogged with food (Note: my son overfilled the garbage disposal before running. It may have backed up).
This worked for now at least. Remeber, as irritating as red lights can be, it prevents the motors and pumps from burning out when you have clogged plumbing.
Kerry
Mar 10, 2008 | Miele Dishwashers
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
