Question about Vehicle Parts & Accessories
Problem with a Scytek Astra 1000rs and my Saturn 2000 LS1 I paid an auto design busines to install this auto starter on my car, but they could not program the remotes to work with it. The remote does start the car but the alarm does not dis-arm and the doors and trunk dont lock/unlock. I want to know if my car is simply not compatible or if the installer just gave it to me like that because it was taking too long to trouble shoot.
doin12volt
  • 233 Answers
SOURCE: car starter not working
look under the dash for a small silver toggle switch....this is a disable switch for the remote start portion of the system..you may have kicked it / bumped it with your foot, causing the remote start portion to be deactivated. Just flip the switch the opposite way and try again..
Also, there may have been a pin style switch installed under the hood...Check to see if it is bent or broken, if it is, simply disconnect it and insulate the wire that was going to it.
This wire is used as a safety to keep the vehicle from remote starting while the hood is up..to keep people from being injured if the remote start is activated while the engine is being worked on.
Have whatever shop installed the system replace your pinswitch if that is the problem.
Posted on Dec 19, 2008
ltfrc
  • 227 Answers
SOURCE: how do auto remote car starters work?
Usually the car start system has a "Valet" switch hidden somewhere under the dash or in the glove box. This is used to disarm the system for when the vehicle is serviced. You will have to locate and turn the switch on, some units have a small push button. In either case it is a good dea to locate it for future use.
Posted on Feb 08, 2009
  • 5 Answers
SOURCE: i have a viper alarm with remote start the remote
the alarm is in valet mode .open a door press lock unlock lock on the remote and it should take it out of valet mode
Posted on Oct 09, 2009
SOURCE: Keyless Entry doesn't unlock my doors anymore
Did you get help? My problem is similar but not as bad. My viper550ESP no longer remotely unlocks the doors (well very, very occasionally it does). That is the only problem.
Posted on Nov 25, 2009
SOURCE: crimestopper keyless entry remote wont unlock or lock anymore changed battery still wont work
need to program a new remote to keyless entry system it is crimestoppper cs835 rke
Posted on Dec 16, 2009
Remote starter issue
the wire is crossed that activates the starting circuit. have a tech find the wire and swap them around remote start power wire should not be spliced into the other wiresd on the box at all so its a simple fix:)
Dec 05, 2015 | Saturn Cars & Trucks
Just replaced starter and 01 saturn L200 will not start
Search Results
    2001 L200 Cranks but won't start - SaturnFans.com Forums
    www.saturnfans.com > ... > Models > Saturn L-Series > L-Series Tech
    Nov 28, 2010 - 15 posts - ‎5 authors
    I have a 2001 Saturn L200 with 69K miles on the twin cam 16 valve 2.2 ... It will crank but will not start unless I put the gas pedal to the floor in ... Saturn L200 Cranks but won't start
    Mar 12, 2012
    2001 Saturn SC2 Cranks but does not start
    Dec 4, 2011
    2001 L200 won't start
    Dec 19, 2009
    Widow in need - L200 will not start - fuel pressure
    Nov 12, 2009
    More results from www.saturnfans.com
    2000 Saturn LS1, Starting Defect - YouTube
    ? 1:37
    www.youtube.com/watch?v=CBNU1IMqaRw
    Aug 9, 2009 - Uploaded by farmerinchico
    The anti theft system in the 2000 Saturn LS1, thinks you're trying to steal the car ... Once the security light is not flashing you canstart the car.
Oct 29, 2015 | Saturn Cars & Trucks
I have a 2000 Saturn Ls1. Won't start. I have spark at all 4 plugs, fuel is present at the fuel rail, fuses and relays appear to be good. What could be preventing it from starting now?
DO THE SPARKS HAPPEN AT THE RIGHT TIMING OF THE CRANK?
TRY TO START IT WHILE SPRAYING STARTER FUEL INTO THE AIR FILTER. THAT WILL NARROW THE SCOPE.
Jun 18, 2015 | Saturn Cars & Trucks
2000 saturn ls1 a/c wiring diagram
ALLDATADIY.......Great website. Use it.!
Jul 01, 2014 | Saturn LS Cars & Trucks
I have a 2000 saturn ls1 and i changed the starter alternator and the battery but it wont crank what the problem\
check the timing chain if the engine turns over but want start. coil pack and crank sensor.
Dec 06, 2013 | Saturn Cars & Trucks
Skytec astra alarm system keeps losing power
The batteries take a lot of power to send and receive data so you should get around 3 to 4 weeks per battery. If this is what you get it is normal.
Oct 01, 2013 | Scytek Electronics ASTRA200 Car Alarm 1...
I need to reprogram my car starter..where can I
Manual link found at the top right of the page: http://www.scytek.net/astra.php?pic=images/products/astra/a1000RS.png
Dec 12, 2009 | Astra Ast200 Auto Security 4-channel Alarm...
2000 Saturn LS1 dashboard battery light
the light is across one diode in the rectifier pack in the alternator, usually there are 9 of them, one of yours has failed, probably the failed diode is leaking current and draining the battery. In this instance the battery will be good (if drained) and the other 8 diodes will show a good charge.Get the current drain checked with everything switched off
Aug 03, 2009 | 2000 Saturn L-Series
Vehicle Parts & Accessories Logo
191 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
