Question about Panasonic Toughbook 28 Notebook
Toughbook LCD is Dark.
I have a CF-28 Toughbook (1) and today the LCD went dark. I tested the LCD on another CF-28 (2) and the LCD works perfectly on it. I also checked the second Toughbooks LCD screen on the First on and it also was dark. To summarize; Both LCD screens work on Toughbook 2 but niether work on Toughbook 1. I can see and image on Toughbook 1 but I need to shine a light on it to do so.
Any ideas?
Thank you.
    Novelist:
    Scholar:
  • Panasonic Expert
  • 112 Answers
On all Panasonic Toughbooks, any model pre-2008/2009 would have the older LCD screen with an "inverter". The new screens are called LED because there is no inverter.
The inverter is like the "ballast" on a fluorescent tube lighting fixture. The tube could be good but if the ballast is blown then the tube will not "light-up". This is also true of the inverter.
You can also tell when the inverter is about to burn-out when you first start your toughbook in the morning and the screen is initially "red" and then turns white after the unit warms-up for a few minutes.
Good Luck to you.
Regards from Richard, Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989.
Posted on Nov 02, 2017
5 Suggested Answers
1234s282
  • 144 Answers
SOURCE: keyboard installation for CF-52 toughbook
Here you , this is a step by step disassembly guide with pictures
Its for a Toughbook CF-50 but it should be similar as theres not too much difference in the model number
http://www.machinaelectronics.com/store/library/article.cfm?f=key_type_k17
Posted on Jan 04, 2009
  • 36 Answers
SOURCE: My panasonic toughbook cf 28 memory issue
i'm not sure what your configuration was in the computer before you tried installing the extra memory, but here's some common problems i see.
-it might exceed the maximum amount of memory that can be recognized in each slot or total for the computer
-it might have be installed in matching pairs (if it is a 2 memory slot machine which most are).
-it might not take that exact speed/rating
hope that helps
Posted on Jan 16, 2009
Geekman
  • 32281 Answers
SOURCE: Color Display on Panasonic Toughbook CF-28 is dull
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Jun 02, 2009
1alexh
  • 484 Answers
SOURCE: upgrade hard drive in panasonic toughbook cf-50
1 - Using a stack of DVD RW blank disks, or a large capacity USB Flash/Jump Drive, back up your Laptop computer completely. If necessary, Use WinZIP to ensue that everything has been compressed into the smallest capacity possible.
2 - When you are certain that you have backed up the drive completely, remove the older drive
3 - Line up the new drive and the old drive and ensure the jumpers are set to the same settings as they were set on the older HDD.
4 - Once you are sure, you then restore everything from the back-up drive for the old hdd to the new disk drive.
5 - Test to ensure that everything from the old drive has been backed up from the old drive to the new drive.
6 - If you are comfortable that your backup has been completly restored from the backup meda to the new, larger hard drive, then be certain that you have restored from the older drive to the new drive, tighten all screws and cables, then close all ports and ensure that everything has been done properly by and for you.
7 - Be certain that you have created the same user accounts in the new drive as you had on the older drive.
8 - Now, power off the new drive while in the laptop. Wait about 30 seconds to one minute, then restart the new hard disk drive.
9 Test everything, to be sure that everything works properly. Go through everything from the top of the menu to the bottom of the menu. Try all accessories, try all applications. Ensure that all works right and that the applications work as they used to work, when it was on the old drive.
10 - Remember, you have a warranty on the new HDD, so be sure that you have tested everything to ensure that it all works properly, before you sign off on this new drive.
11 - Once you are certain that it all works correctly, you can then be sure that it is working properly and competely, because only you know if things are working correctly as they should be.
12 - Then you can sign off and you can be sure that things work properly.
13 - As carpenters say ... measure twice; cut once. You can only do this one time, so if you measure it more than one tim, you can be certain that you will get it done correctly and be happy that you did it right. from beginning to end.
Have fun. Don't be too serious about it, but do be careful, and get it right. Remember, get it right the first time, and you will be pleased with the results at the end.
Posted on Jun 22, 2009
I have a CF-30 toughbook and my screen lights up for about 4 seconds and then goes dark everytime I open the the lid. I can see the screen is still on but not lit up, it will relight if I close the screen...
It could be loose wiring.
1. Take the screen bezel and LCD board off and reseat all the connections. In other words, unplug and plug it in again.
How to: CF-30 toughbook LCD replacement video
2. If that doesn't solve the problem, then you must replace the LCD inverter.
Best Regards,
Embraced Support
Fort Lauderdale Computer repair
Sep 05, 2011 | Panasonic Toughbook 30 Laptop
Swapped lcd screens on my cf-48 toughbook
Maybe you mess some connection of the lcd. Is the lcd has the power indicator? If yes then maybe u can some keys functions such Fn to make display out.
Jan 25, 2008 | Panasonic Toughbook 48 Notebook
I have a Panasonic Toughbook CF-28 Mk III P3 1Ghz 512Mb Ram , I have installed a brand new DVD rom Drive in the MP Bay it reconises in bios also reads upon first post however, will not boot from any os cd...
Some bios menu allows you to boot from USB. (Some are locked this option by makers.)
Run safety mode and try again to see whether your DVD rom is working.
Best way will be go to device manager; go to properties of DVD rom; go to driver and click roll back driver.
If this is not working (in case), uninstall driver and reinstall it.
May 29, 2011 | Panasonic 30gb laptop hard drive for...
I have a CF-29 with a touchscreen, and the screen just went extremely dark. I can just faintly see the desktop. Using the Fn/F1/F2/F3 makes no difference.
Hi
Thank you for your query
The problem you are experiencing is a fairly common problem with laptops, it would seem that if plugging the charger back in doesnt make any difference then the screen inverter will need to be replaced
Please plug in the charger to see if this makes any difference and if not you will need to book the toughbook in for replacement of the inverter
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again - shauqatm@yahoo.co.uk
Feb 24, 2010 | Panasonic Toughbook 29 Touch (P/N...
Dark screen........
dell is a good laptop. its ur bad luck simply.
Aug 23, 2009 | Panasonic Toughbook 50 Notebook
Jun 01, 2009 | Panasonic Toughbook 28 Notebook
Have a CF-28
The last three letters of that model number are unnecessary.
CF-28P3JP8QM has the following desription:
PIII 800MHz, 256, 30GB, 13.3"NON-TOUCH, FDD, 56k/LAN, CISCO WIRELESS LAN, PALM ANT, NO 56K, XP/2K
You can look up this info for yourself at
http://config.toughbook.com/
You will need to use Internet Explorer as other browsers don't seem to work on that site.
Mar 10, 2009 | Panasonic Toughbook 28 Notebook
hope that helps
Jan 16, 2009 | Panasonic Toughbook 28 Notebook
Panasonic Cf-48 toughbook pentium 4 windows
I don't know what version of windows your running but try first going into the bios on your laptop and disabling your adapter. Then see if you can boot windows to try and find out if it is a hardware or software problem. If you can boot windows after disabling in bios you have some idea now what to look for. Instructions for how to enter bios should be in your manual for your Toughbook or posted on Panasonic's web site for your machine
Feb 05, 2008 | Panasonic Toughbook 48 Notebook
Panasonic Toughbook 28 Notebook Logo
104 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
