Question about Kenmore Washing Machines
Doesn't move into the rinse or spin cycle - Kenmore Washing Machines
    President:
  • 267 Answers
Hi.
this is becasue of a failed timer device. simply replacing the timer control module will eliminate these issue.
thank you for using fixya,rate my answer,
vijay
Posted on Oct 02, 2009
  • 612 Answers
You have a bad coupler. This is very common but not to worry. This is a direct drive machine and there are very few things that go bad on them. One is the coupler, another is the water pump. Other than these, nothing else hardly ever goes bad on them.
Now for the coupler, It's located between the motor and transmission. You will need to remove the case. Once you have, you only need to un clip the water pump and then the motor. You will then see the coupler. If you haven't been inside one of these, you don't get in through the back. You will take a screw out of each end of the console. Pull forward and flip back. Now un clip the clips on each corner under the console. Unplug the wire under the console. Now pull forward on the case, tilting it toward you and pick up. You are now inside the machine. The water pump it at the bottom. Good luck.
Please rate solution
My Kenmore washer drains after the rinse cycle but won't spin at the end of it's cycle. If I manually set it to the spin cycle, it spins just fine. Desperate!!! The lid switch was just replaced about
Possible there is problem with the timer controller unit. It seems that the stepper motor is not moving to the next cycle until you manually move it to the spin. You can use some contact cleaners on the switch and also carefully try to see if the timer moves within , replacement is a costly issue and must be debated
Nov 20, 2013 | Washing Machines
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
My washer only runs until it's time for the rinse cycle and then it stops completely. It doesn't rinse or spin. What's going on?
hello, it sounds like a failed lid switch part #3949247 it wont rinse or spin with a bad lid switch. it also wont rinse or spin if there is no cold water to the unit.
Jun 08, 2011 | Roper RAS8445KQ Top Load Washer
Kenmore 80 series top load washer. In the permanent press mode the machine will stop when it moves to the rinse mode. I can manually move the time past the midpoint of the cycle it will run for a minute...
So it will spin and drain when put in the spin cycle right? More than likely it is your timer if you have to keep manually setting. I would check on timer prices and go from there.
Dec 28, 2010 | Kenmore Washing Machines
Spin/drain cycle won't start
If the timer gets to the rinse cycle and stops,
Check the lid switch for continuity. If no continuity replace the lid switch.
If the timer continues through rinse and spin without doing either, replace the timer.
May 21, 2009 | Kenmore Washing Machines
Does not spin in most cycles
It sounds like your timer is defective.  If this is the case you will have to replace it.
Oct 17, 2007 | Maytag Performa PAV2200
MACHINE DOESN'T CYCLE OUT OF RINSE
Does it spin if you move the timer manually? ist it being used on a delicate cycle@? if so it will stop in the last rinse water
Jul 10, 2007 | Ariston Technologies AWD 121
Washing Machines Logo
18 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
