Question about Maytag 24 in. MDBH950AWS Built-in Dishwasher
I have a Maytag dishwasher Model MDB 7100AWQ. I
I have a Maytag dishwasher Model MDB 7100AWQ. I had a plastic spoon drop down under the basket and the heating element melted a hole in the handle. The dishwasher will now come on when push the light load button and start to wash but will only run for about 5 to 6 min befor the wash cycle stops the timer will continue to count down but nothing happens. After it stops I have to push the drain button to get the water pumped out. Can you tell me what I have to do to fix it? Thank you MrTLC
  • mrtlcdrapery Oct 02, 2009
    Thank you for your answer. Where would I check the amperage and votage of the motor.
    I can push the off button and then the drain button at any time and the timer will set to 2 min and the drain cyle will go ahead and drain the water out.
    Terry
    President:
  • 1,462 Answers
The motor on your model has a built-in thermal overload and will drop out if excessive amperage or motor temperature causes the overload to open. It takes a while for this to reset.
Does your dishwasher runs after leaving it for sometime..
Check the amperage and voltage of the motor, this must be issue with the motor..
Id it getting stopped exactly at the drain cycle or its getting stopped randomly..
Please leave my query as comment, and we may solve your issue
RNJ VINODKUMAR
Posted on Oct 02, 2009
  • Vinod Kumar
    Vinod Kumar Oct 02, 2009
    To check the amperage of the motor:
    First tof check and see what amperage the dishwasher is pulling, you need a good multimeter connected to the input of the motor to check this,
    RNJ VINODKUMAR
Plastic spoon dropped onto the hearing element. does element need to be replaced?
no you dont need to do anything but remove the spoon from the heater. the heater wont be harmed and will continue to work properly.
Jan 03, 2010 | Maytag 24 in. MDB6100A Built-in Dishwasher
Our Maytag Jetclean Dishwasher EQ Plus will not turn on (MDB9150AWS) and we cannot find a repair manual to troubleshoot through the problem. Maytag does not offer repair manuals on this model. Any...
Try this. From what I have found Maytag discontinued the Repair manual but it appears that all MDB and MDC models fell under this one repair manual.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47135
Oct 10, 2009 | Dishwashers
Need Instruction Manual for Maytag Dishwasher Type 776-0 Model MDB 8551AWB
Go to managemyhome.com and register. This is a FREE service. Once registered, log in and locate the "Owner's Manuals" link under the "Home Manager" drop down menu. Type in your model number and your owner's manual is available in a downloadable .pdf (Adobe) format. I hope ths helps you.
Jul 27, 2009 | Dishwashers
Maytag MDB-3 won't start, display flashes
Hold down the lighted "3" for five seconds to unlock the child safety lock
Feb 15, 2009 | Maytag 24 in. MDBH970AWS Built-in...
No water comes in to wash dishes.
sorry to sound obvious, but you will have pull the dishwasher out to get to it, just follow the hose into the inlet valve unit, they are located under the unit at the back.
Jan 27, 2009 | Maytag 24 in. MDB9150A Built-in Dishwasher
No power to Maytag Dishwasher MDB-8
no breaker on motor look at door lock ***. for power
Nov 03, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Maytag Dishwsasher Model MDB-9
The Switches do not oprate when you press them. What can be the reason?
Sep 27, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Three-year old Maytag dishwasher is making terrible buzzing sound while still squirting water. Wondering if disposal on unit is jammed, and if so, how to unjam it.
Got the washer fixed by removing parts until I got down to the chopper, which was jammed by a small, plastic ice cream spoon. Was relatively easy to fix. Keeping the screws with the parts they secured was helpful.
Aug 17, 2008 | Maytag Dishwashers
Maytag dishwasher mdb9600awb - loud pump
This has happened a few times to me as well.(VERY VERY LOUD NOISE AT THE BOTTOM)I have the same model It did stop.I did a little reading and came to the conclusion that it was the built in food disposer chopping blades were chopping up something like a cherry pit or peach pit and once an end of a wooden spoon that dropped down.If you look at your USE and care Guide on page 12 under trouble shooting "Dishwasher seems noisy"..I went through the same thing taking things apart.Its got to be it. Mine is 2 1/2 years as well. Hope this helps. ronkeachie@rogers.com
Sep 24, 2007 | Maytag MDB9600A Jetclean II Built-in...
Maytag 24 in. MDBH950AWS Built-in Dishwasher Logo
115 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
