Question about Dishwashers
Ariston afa250 green light is flashing and nothing else happening it has only done a rinse then light came on flashing
2 Suggested Answers
  • 32 Answers
SOURCE: The 4th green light on
You did not mention what model number that you had but this is what I found after a little digging:
From http://servicetechhelp.com/discus/messages/2801/6823.html?1205974228 :
For future reference, the technician who replaced the control board for me gave me a complete list of flashing LED fault codes for the Ariston LL65 (which are same as Ariston LL64):
001000 Float Switch: Water in Base Pan
001100 No Drain: Dranin Motor Disabled, Filters Clogged, Dramin Hose Blocked
001010 Main Motor Presure Switch Blocked Filter
100100 Control Board: Software of Control Board not Recognized.
000100 Water Valve: Water Valve Diabled <--- This one sounds like your error
000110 Fill Fault: Water Valve Disabled, Turbine Disabled or Control Board
000101 Heating Element disabled or High Limit Open or Control Board
000010 NTC defective or not positioned or control board
000001 NTC defective or not positioned or control board
KEY: 0 = LED off
1 = LED flashing
I also found this for a different model:
http://www.diybanter.com/home-ownership/89945-resetting-controller-ariston-dishwasher.html
No Program Code Fault condition
1 Heavy wash 1000 Operation of flood
protection system
2 Normal wash 0100 Heating
element/Thermistor/Thermostat fault
3 Rapid wash 0010 Drain pump fault or drain
blockage
4 Soak wash 0001 Not filling to correct
level within 6 minutes
Posted on Mar 02, 2011
Ariston l63 is not rinsing proper cycle but instead flashing 12hr light
Error messages,
Your dishwasher is equipped with a safety system which is able to detect any operating anomalies. These anomalies are reported by one or two wash cycle indicator lights "G" flashing rapidly.
24463930-0h3kxpflbez5mdeb5anq3st4-3-0.jpg Flashing LED diode above the mark 12h (drying) indicates faulty NTC thermistor. So, could be faulty: thermistor NTC, wiring between NTC and control board, control board.
Dado
May 20, 2014 | Ariston Technologies L63 Free-Standing...
Indesit WIXL143 stops part way through program
Technical Jargon error F02 Motor jammed / tacho detached: check motor & module connections
Basically the strong possibility of a faulty Motor
Mar 21, 2010 | Washing Machines
Power light and extra rinse rapidly flashing
Sounds like a cold water supply fault which could be the solinoid valve, the water turned off, a kinked or twisted cold supply pipe or a wiring fault. Check out the error code sequence here. You never said what make or model you have (the error codes are only for Hotpoint, Creda and Indesit machines)
Mar 20, 2010 | Washing Machines
Ariston Elixia LI68 Duo dishwasher will not start
Same problem , i fixed by opening the door compleet then cleaning the bottom of the door with a kitchen cleaning paper that may do it afther that disconect the power compleet whait 1 minut connect it al again and it should work , don't ask me why this cleaning action i just found it out
Feb 05, 2009 | Ariston Technologies Dishwashers
Ariston a1636 washing machine
I have the same problem, did this get solved for you?
Jan 08, 2008 | Ariston Technologies AW149NA Washer
Ariston 6kg washing machine
Do you have the "easy iron" feature on? If so, the clothes will stay in water until you manually rinse it.
Oct 07, 2007 | Ariston Technologies AWD 121
Dishwashers Logo
207 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
