Question about Mach Speed (PM9MS) Motherboard
I need to download a multimedia audio controller. I have a machspeed MSNV 939 motherboard if that helps
    President:
  • 1,335 Answers
You can get the drivers for your motherboard at:
http://www.machspeed.com/specs/viper/MSNV-939.html
Please rate this solution. Thanks.
Posted on Oct 02, 2009
Testimonial: "relatively helpful. except the links on the webpage he sent me to are only for vista and I need xp "
  • Bob Kitaji Oct 02, 2009
    The XP drivers are on the Specs and Drivers page. Please update the rating. Thanks.
  • Bob Kitaji Aug 07, 2010
    The Machspeed site has been changed and you can not get the drivers directly.
    Go to the machspeed.com site and find your motherboard. Check to see which audio chipset you have on your board.
    The chances are the manufacturer is RealTek. The RealTek support site is realtek.com.
    To check all you drivers, you might consider a program like driveragent from Phoenix. Driveragent will scan your system to identify the manufacturer of the audio controller on your board and provide the correct download version.
Will it run 64 bit os?
Visit http://tiger.tv/more_info/?288 for more on this great motherboard. Mach Speed's new MSNV-939 motherboard
Nov 05, 2011 | Mach Speed (MSNV-939) Motherboard
My cd is broken
I have given a link below .On this link you will find the option of :Detailed Specs and drivers.when you click this link , here you will find a pdf file. Here on the second page you will find the link to downlaod the drivers . Just go the version option in this table on second page. Hold the control key and click on that . you will get the drivers
http://www.machspeed.com/specs/matrix/P4M890.htm
Apr 27, 2009 | Mach Speed Motherboard, Geforce6100,...
Need manual for MSNV-939 MB
Hi hickoryhi138,
The motherboard your referring to is made by Mach Speed.
Click on the link provided & scroll to the bottom of the link to download the manual; http://www.machspeed.com/specs/MSNVspecs.pdf
Drivers are also listed on the link.
For the manual (Only), click on the next link; http://www.machspeed.com/manuals/MSNV-939manual.pdf
Go to page 19, Header for Front Panel Facilities: JPANEL1
Knowing what wire color is positive & which is negative varies from case to case. Check the group of front panel wires. Most likely one wire from each 2-pin connector will share the same color. Like the color white which is common for ground/negative. Other colors, blue, green & red are commonly positive. The only exception is the speaker wires. Mach speed only uses two wires across four pins. Black is most common for ground & red is for positive.
Good luck hickoryhi138!
Thanks for using FixYa.
Need more information? Post here.
Mike
Don't forget to vote.
Mar 14, 2009 | Computers & Internet
Mach MSNV-939 motherboard - RAID 0 - How to setup?
im in the same spot... di anyone found this sol. ?
Apr 10, 2008 | Mach Speed (MSNV-939) Motherboard
Very slow booting
If you're going to plug-in a video card you need to turn off the onboard video chip. Otherwise It sounds like a cold problem, you could heat areas of the motherboard with a hairdryer to find out..
Oct 18, 2007 | Mach Speed (MSNV-939) Motherboard
Consistent hard Drive BOOT ERROR after an upgrade to MSNV-939 motherboard
You can run a disk manager for your drive however, I'll bet you will find its windows boot.ini. It may read just fine for a dual boot system but think about this. Windows can get confused real quick. I'm talking about the regestry. Take the time and do a fresh install of your Linuex and than re-install windows "clean install". I'll bet everything works out just fine. When 1 changes MB's there is a whole list of new drivers PCI devices loading into windows. Your system will run better with one copy of drivers for your new board and windows will not carry a list of old drivers and PCI devices of your old board.
Oct 17, 2007 | Mach Speed (MSNV-939) Motherboard
Mach Speed (PM9MS) Motherboard Logo
386 people viewed this question
Top Mach Speed Computers & Internet Experts
David
David
Abhinandan  Patil
Abhinandan Patil
Iqbal Husain
Iqbal Husain
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
