Question about Nikon F65 35mm SLR Camera
My n56 stopped working
I have no idea what caused this. I went outside for a minute, nothing got on the camera, but it was a little cold. I turned my camera off, and when I llooked at it again, the LCD was completely blank (It always shows the battery indicator and number of shots left. The whole camera isn't working now. I tried new batteries. I've let it warm up from coming back in. What happened???
  • vangrenquist Aug 21, 2008
    i had the exact same problem, although mine stopped working mid shot. i was about to capture this really good picture when i shot the shutter opened but i am yet to hear it close?? there is no longer any lcd image and will not operate.
    please help
    New Friend:
    Problem Solver:
  • 10 Answers
I've read recently of a slew of older Nikon amateur film cameras from the late '80's to mid-'90's that have electronics that have failed. Their prosumer cameras (8008, N90, F100, etc) don't seem to be affected as much as their amateur cameras (N2000, N60, N65, etc). You could try cleaning the contacts of both the camera body and lens - as well as the battery compartment, but if that doesn't work, you may be out of luck. The good news is that you can pick up another N65 for less than ten bucks at most camera shops, both online and brick and mortar.
Posted on Nov 19, 2017
SOURCE: E won't turn off
The "E" just means "empty". As in "no film". The "err" is different. It cold be anything. sorry i don't have a solution for that.
Posted on Feb 09, 2008
  • 121 Answers
SOURCE: Nikon D70 will not power on after the lens was changed~
Is this a new or different style lens? You may not have it all the way on and aligned - try removing it again. Just remember to always turn off the camera before removing the lens or the SD card. Malfunctions are sure to follow if that happens. Try resetting the camera by holding down the two buttons on the top with the green dots for longer than 2 seconds (that works with the D80) The camera will not come on if the lens is not "on".
Posted on Jan 09, 2009
  • 1223 Answers
SOURCE: Battery exhausted always showing on camera
pls call canon it may be linked to this problem ur model is different i know but i think problem is same and they are responsible for that repairs
pls remember to rate me FIXYA fo rhelp
Posted on Apr 13, 2009
  • 1223 Answers
SOURCE: Pictures taken all come out black
Call NIKON for Free Repairs it is a known manufac fault in thousands of cameras , dont worry just call them see this for info on this problem
Kindly Rate me WELL !
this applies to all products with same problem dont worry u r included just call them and tell them abt BAD CCD !
Good Luck !
Posted on May 23, 2009
  • 390 Answers
SOURCE: Camera turns on and focuses, but cannot see menu or take pictures
two things here, have you checked to see if the location to store the pics if it is placed to the intenal memory and the memory is full
also pls try to take a pic with another SD card may be that this card is either corrupted or damaged
Posted on Jul 23, 2009
Nikon d90 LCD screen
Not sure if you were outside in a cold environment, that could cause the problems. Change form warm to cold and back. That could have caused the problem. But is that was so, the camera should act normal when you are in house for a couple of hours. If the problems stays, perhaps something more serious could be going on. As ling as you can make pictures, you should be fine tomorrow, because I think you don't actually don't need the screen on a D90 (except for looking up the histogram). It could be the screen will cure in a little while. If not, think of it that it is already damaged and you have to go to the nikon repair centre anyway.
I wish you luck.
Nov 12, 2013 | Cameras
Hotpoint H2O error
Please check on the water flow to the drum, if the flow is low or if the inlet is choked the water flow in the set time limit can be low and so could trip.
secondly it can be due to problems in the level sensor, try and see if the pressure switch works outside.
Finally check on the program controller unit once again to see the triping. check the door switch for loose connection.
check this link for tips:Washing machine
Jun 25, 2012 | Hotpoint Washing Machines
Have a frigidare wall ac (FAA067P7A). Worked 1st year we had it but problems after. Only time compressor kicks in is when we hit reset button. Then cold air comes out for couple minutes then compressor...
The compressor is stopping on overload. There is either a weak breaker or an electrical problem causing the overload to open the circuit and stop the compressor. It has to be taken apart to determine what is or is not going on.
Aug 03, 2011 | Frigidaire Compact Air Conditioner
Turned on AC was running fine. 30 minutes later began to hear a strange noise. Opened AC/Furnance closet & heard a sound best described as air letting out of a tire. It seemed to be coming from...
This means that the condenser fan motor (outside unit) failed, this caused to build hi pressure and either activated a safety valve to release the extra pressure or blew a line and R22 Refrigerant escaped from system.
The fix is to replace motor fan and capacitor find the leak and refill system with R22 Refrigerant Gas. It is safe to turn on the Fan Only mode on the Thermostat until a HVAC Tech arrives.
To perform this job parts and labor included will cost: about $300 -.$400. Look on the Yellow Pages for a Tech in your neighborhood.
Good Luck!! Don't forget to Rate this post!!
Aug 13, 2010 | Goodman CKL42AR42 Air Conditioner
Hello All - I'm hoping someone here can give me a few ideas. My 92 toyota celica st has sit for about 5 days - for the last 3 days the temp outside has been in the single digits. Went to go start today and...
You can try this.
Turn on the key and listen for the fuel pump to prime.
It will sound like a gentle hum. when it stops, turn the key off. wait a few seconds and do it again. Do this three or four times, but don't try to start it. after the third or fourth time you turn it off, try to start it. It may not be priming the fuel injectors fast enough.
Dec 13, 2009 | 1992 Toyota Celica
2001 Chevy S-10 AC stops after about ten minutes
Sounds as if there may be a vacuum leak somewhere, possibly behind dash causing it to switch back and forth from hot to cold and vise versa
Sep 04, 2009 | 2002 Chevrolet S-10
My flip video camera wont turn on....
Have you tried resetting the camera? Hold down the power button and the red button simultaneously until the camera shuts off (takes about 10 seconds). Then, just press the power button again and the camera should turn back on. I had the same problem; when I pressed the red button to stop recording, the camera froze, and the red light remained on. I tried resetting it like this, and it seemed to work.
Jan 19, 2009 | Pure Digital Flip Video Ultra Camcorder
New battery but car still won't start also it really cold outside
First you should check the wire to the starter. If the horn or lights work but nothing hjappens when you start starter or starter solenoid is bad. I hope this helps you.
Dec 24, 2008 | 1997 Honda Civic
Nikon F65 35mm SLR Camera Logo
186 people viewed this question
Top Nikon Photography Experts
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
