Question about Lexmark Wheelwriter 6 Series II Typewriter
Wheelwriter 6 keys strike paper but don't hit ribbon, ribbon doesn't rise up, no black letter on paper
  • TomIBM Dec 20, 2007
    It's an IBM. I don't know why it's under Lexmark.
  • TomIBM Dec 24, 2007
    I moved the cam on the right. It loosened up and it's working. You're a Fixya Master, DickyO! Thank you.
  • Lexmark Master
  • 3,594 Answers
You may need a ribbon motor or motor board, however on the older wheelwriters sometimes the gear mesh gets sloppy and gears jam tooth for tooth. Try moving the ribbon lift gear/cam on rt. side of the carrier by hand with the machine off if it won't move that's the trouble. Wiggle it back and forth and it may free up.
Posted on Dec 24, 2007
Keys strike paper but don't space
Is it all of the keys or just some of the keys don't space? Check to see if the lang light is turned on. If it is, hold down the control button (the button left of the spacebar) and hit the letter "X" and see if the light goes out.
Apr 14, 2014 | IBM Wheelwriter 6 Typewriter
IBM Wheelwriter 6 Typewriter - while typing, characters just quit printing on paper. Checked ribbon, machine etc. Everything checked out?? What could be the problem.
It is probably the print solenoid that has a broken cap. I have seen a few advertisers that sell the repair kit with instructions. It is fairly simple to repair.
Jan 02, 2014 | IBM Wheelwriter 6 Typewriter
IBM Wheelwriter 6 - Ribbon doesn't lift high enough for the key that's pressed to print on paper. Ribbon advances OK.
If theribbon dosen't lift at all see if the black gear on the R. side of the printer will move, if not w3iggle it and it should free up they get tooth for tooth with the motor gear. If it only lifts partually thereis an adjustment on the roll that works with the black gear. BE SURE TO CHECK THGAT BTHE PLATEN IS FULLY SEATED IN THE VSIDE FRAMES THEY DO GET LOOSE!
DickyO
Jun 30, 2012 | IBM Wheelwriter 6 Typewriter
Ribbon doesn't raise up enough to let the letters strike it. Is there an adjustment somewhere?
If it dosen't lift at all wiggle the large black gear bakand forth a few times they do get tooth for tooth.
DickyO
Ibm wheelwriter won't strike. Ribbon is good. Wheel is working. Carriage is moving. Just not striking. I dusted & cleaned as well as I can but to no good.
I HAVE AN IBM WHEELWRITER 6 TYPEWRITER THAT WONT STRIKE THE LETTER. EVERYTHING ELSE WORKS? CAN YOU HELP ME FIX IT?
May 10, 2010 | Office Equipment & Supplies
IBM Wheelwriter 6-Letters striking paper above
Put in a multi part form and type if the carbons come out OK the the ribbon isn't lifting, Wiggle the big black gear on the R. side of the carrier back and forth. They do get tooth for tooth when they get old. If the print on the copies id bad or not there you need a print solenoid cap. We sell them for 20,00 including instructiond and shipping.
DickyO
Cleveland Business Machines
216-241-0027
Feb 18, 2010 | IBM Office Equipment & Supplies
Keys are striking the paper but no black ink is printing on paper
If tou put in a two part form and it types on the second form the ribbon is either empty of not lifting up. If it isn't lifting up there is a large black gear on the rt. side of the printer, wiggle it back and forth they sometimes jam tooth for tooth.
DickyO
Dec 19, 2008 | Lexmark Wheelwriter 6 Series II Typewriter
KEY STRIKING PRESSURE
Try taking the ribbon out and looking at it see if there is one spot for each character on the ribbon or if they are overlapping.If they are over lapping then either you have a problem with the ribbon drive assembly on the machine or it is set for a multi-strike ribbon.
Nov 13, 2007 | Lexmark Wheelwriter 15 Series II...
Lexmark Wheelwriter 6 Series II Typewriter Logo
131 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
