Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Is it proper for a double oven to be installed 3 inches from a refridgerator
  • mftaylor80 Oct 02, 2009
    When I bake a lot or use both ovens, my fridge starts to get warm even up to like 57 degrees and after I am long done with the oven it will go back to the proper temp. Is this normal
  • 146 Answers
Normally it is not recommended to place a refrigerator near an oven, that's what most people would agree with - however, I have an encased oven near my fridge and never had problems - Keep enough air flow at the back and sides of your unit to allow the heat from the condensers to dissipate properly - Of couse your oven will make your unit work longer, but sine you are not running your oven 24/7 I don't see the problem.
With modern refrigerators, the condensers are at the bottom with a fan blowing air on them so I wouldn't worry about it - Just make sure that your refrigerator is not exposed to excess heat, that your condensers are clean and that you have the proper clearence at the back and sides.
Posted on Oct 02, 2009
  • DarkStar2 Oct 02, 2009
    As I stated in my reply - it is not recommended to run a refrigerator next to an oven as also stated in your manual and by most manufacturers - however, depending on your setup and normal ambiant temp and clearance area around your fridge, you may not experience any problems.
    From my personal experience, I have not experienced ANY problems - I had an old 25 year old Kenmore fridge, never would the temps go that high - During hot summer months the compressor would run much longer, but cooling is maintained.
    My new GE unit is unaffected at all and compressor run times are the same. In both cases it has not impacted at all my cooling.
    Might want to check your door seals they might not be tight. Of course if you have very excessive heat dissipating around your unit's clearance area, this will affect its performance - which is why it is not recomended - this is a killer - In your case the heat is too excessive, obviously your compressor is being tortured, remember how your refrigerator cools - by the principle of removing heat and dissipating it - If your condensers cannot dissipate their heat, your unit will not cool fast enough and your compressor run-time will be continuous or very excessive, also putting higher pressure on the compressor as well - and your unit not able to dissipate heat faster than it can cool - result - cooling problems.
    #1) Those are unsafe temps - Temp variations like that is not good for your food!
    #2) you an extreme workload on your compressor and you are reducing its life cycle !
    #3) If you live in a hot area and your kitchen's ambiant temp is already hot - the oven will not help at all.
    My enclosed oven is even less than 3 inch from my refrigerator, however the heat rises up and the door opens sideways, heat escape to the left, away from unit.
    Any direct heat towards your refrigerator = a big no-no - your refrigerator in order to be able to cool has to remove heat - if you throw heat at it, it defeats the purpose - your unit will not function properly.
    I hope this helps !
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
www.kenmore.com/kenmore-elite-30inch-slide...electric-range...
Kenmore
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
www.kenmore.com/kenmore-elite-30inch...slide...electric/p-02...
Kenmore
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
I have Thermador double oven. It wouldn't heat up (top and bottom). I replace Control board and digital display. Now the bottom oven heats up but the top one still not working. Could you pleas
Double check each connector to be sure it is installed (aligned on pins) properly. Also check wiring diagram for a safety limit thermal switch. If it has one, push to reset it.
Jan 16, 2015 | Thermador SC302T Electric Double Oven
Dacor double oven, lower oven works fine, upper oven doesn't turn on at all
I had the same problem after auto-cleaning my oven just before Thanksgiving. The cause was overheating...and the tripping of a heat sensor switch.
The switch (reset button) is located about 3 inches behind the door locking mechanism.
Removing the front panel (4 screws) that the door lock sticks through exposes the switch. Just push the little red button & your are back in business!!
Nov 14, 2009 | Dacor ECD230 Epicure Electric Double Oven
Installing ge profile double oven not convection in new build trying to find out electrical requirements ( size breaker 50,60amp ?)
You must use a three-wire, single-phase A.C.
208Y/120 Volt or 240/120 Volt, 60 hertz
electrical system. If you connect to aluminum
wiring, properly installed connectors approved
for use with aluminum wiring must be used.
That means that you ned a double 40 amp breaker.
Good Luck
Jan 18, 2009 | GE Profile JT952 Electric Double Oven
Thermador c302 door hinges
487746 is the part number for the 30 inch model and
487747 is the part number for the 27 inch model if this is the parts you recieved then the should fit there should not be much difference
Jan 13, 2009 | Thermador C302U Electric Double Oven
Ge oven install
go ahead and wire the blk to blk and the red to the white as long as the data plat on the old oven say's 220 you should be ok
Dec 26, 2008 | GE Profile JTP56 Electric Double Oven
I have a frigidaire package heat pump,in heat mode it goes into defrost everytime it runs for a few minutes,no matter what the outdoor temp.is..it runs about five minutes or so and goes into defrost for...
That is usually caused by either lack of airflow through the outdoor coils. (Dirty coils, need cleaning)
Bad defrost board. (needs to be diagnosed with multimeter and extensive explinations and/or experience to be sure)
Low refridgerant, causing premature freeze up and in turn causing frequent defrost cycle. (Recharge to proper pressures with proper refridgerant type. Requires EPA certification for use of refridgerant, you would also need refridgerant guages, temperature reading device, and refridgerant.)
Dec 07, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Belling fan assisted ovens
no you can't connect a double oven to a 13a socket!!
needs a proper cooker outlet wired back to the consumer unit
Sep 29, 2008 | Belling XOU592 / XOU593 Electric Double...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
96 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
