Question about Acer Computers & Internet
I just upgraded memory from 512 to 2 gigs, but the computer only shows 1 gig. why?
    Problem Solver:
  • 15 Answers
The other 1 gig is not properly installed oropushed in all the way
Posted on Oct 02, 2009
I have a Gateway 838GM. It has 4 slots for RAM. It came with 1/2 gig RAM (2 sticks, 256 Megs each). I tried installing new RAM- 2 sticks, 1 gig each. If I replace the original 2 sticks, the computer...
Here are the specifications of the Gateway 838GM: You will have to replace the existing memory with thesesettings only: The machine comes with: 512 MB = 256 MB (removable) + 256 MB PC3200DDR SDRAM DIMMs. Supports Dual Channel DDR Nowyou can only upgrade to 4.0 Gig total. I would recommend going to this link and order the correct memory foryour computer I use them quite a bit. http://www.memorystock.com/memory/Gateway838GM.html Rob
Dec 01, 2010 | Computers & Internet
Trying to upgrade ram, only reading 512 instead of the gig i put in, can i reset jumpers or is there any other way. i don't have motherboard manual
you can only have the gig stick the board is older and can only utilize 1 gig at most take out the 512 and your gig will show up i promis
May 10, 2010 | EPoX EP-3WTM3 Motherboard
I have a vgn-b3vp (pcg-5b1m) sony laptop, can i upgrade the memory if it has 512 of none-removable memory and only 1 bank.
Yes, you can use the 1 bank and get higher graded memory, another 512 in the 1 bank would make 1gig, you can probable get as much as 2 gig in the bank to make a total of 2.5 gigs by buying a 2 gig memory stick.
Jan 27, 2010 | Sony VAIO VGN-B3VP Notebook
Problems with Foxconn 6100K8MA-RS Motherboard memory upgrade
This is an oldtime POST code memory error. Likely that ram is either installed wrong, bad RAM or the mobo doesn't like one of the memory sticks.
See http://www.computerhope.com/beep.htm.
You must count the beeps.
Mar 17, 2009 | Foxconn 6100K8MA-RS Motherboard
Upgraded Dell Dimension 3100 memory to 2 Gigs - Windows XP fails
Did you add the two sticks with the 512 or remove the 512 and add the two 1gb sticks? Try booting the machine with ONLY the 1gb sticks in.
Your machine supports 1gb modules but they can't be higher than 533MHz. Check that the memory you purchased was either PC3200 (400MHz) or PC4200 (533MHz) and is 1.8v. If you post the part number off of one of the modules I can look it up for you.
Feb 22, 2009 | Dell Dimension 3100 PC Desktop
Toshiba sattelite
The problem must be the amount of total memory. Maybe the board supports only 1 gig. Chek the manual.
Oct 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
Upgrading acer laptop RAM
You Can Actually Upgrade This To 2 Gig Memory.
Each Slot Will Take 1 A Gig Strip.
I,d suggest Buying another 256 mb Strip, To Put Into Slot 2.
Or Buy a 512mb ( Half Gig ) Which Will Give you 750mb With your Existing Strip Already In There. ** Recommend 1 Gigabyte Max** 2 gig of Ram in This Baby Would Probably Start Glowing.
You Can Buy DDR/266/333 In 256/512/1 Gig Strips. These Are Commonly Known As SD-RAM-Modules.
Mike @ Compurepair.
Feb 28, 2008 | Acer TravelMate 2500 Notebook
Ram upgrade
It's generally not a good idea to mix sizes as your more likely to get problems, but that said it probably should still work it's most likely your configuration consult your motherboard book as to what order you should install the memory you have.
Oct 30, 2007 | Intel Motherboard
Memory/Graphic problem
This might have something to do with DVMT or Digital Video Memory Technology. Basically, the amount of video memory is dependent on the amount of memory installed. I'm not very familiar with acer system BIOS but try to look for VIDEO under system BIOS and try to select any fixed video memory if possible. you can also try to disable DVMT.
Sep 30, 2007 | Acer Aspire 3680 Laptop
Computers & Internet Logo
24 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
