Question about Sony KP-43T70 43" Rear Projection Television
Kp-43t70 red out of adjustment
My red is somehow out of adjustment mor noticable on the bottom but it is showing a red second pic below the orginal and cant figure out what is wrong, just wornering if anyone has a solution for the problem it is rally anoying
  • bkalltheway Mar 07, 2008
    and exactly in the convergence intergated cicurits
  • 116 Answers
It seems, from your description, that the convergence circuit is failing. The usual components that fail are the convergence integrated circuits.
Posted on Mar 05, 2008
  • Paul Buscema Mar 07, 2008
    There are two "chips" or integrated circuits along an aluminum heat sink that have to be changed. The generic part # is STK392-150, the original Sony # is 8-749-014-37. The power/convergence board needs to be removed to unsolder and replace these two components.
Lamp part number
KP-43T70 is a CRT based rear projector and does not use a Lamp like newer LCD/DLP projectors. It uses 3 (Red, Green, Blue) glycol liquid cooled CRT's (like the picture tubes of yesteryear) to produce the image/light as opposed to a Lamp.
Nov 27, 2013 | Sony KP-43T70 43" Rear Projection...
Sony kp-43770 tv red and green colors will not align how do i correct this,i have used the focus button no success
convergence chips will need to be replaced and I think model number is not correct that was posted, kp-43t70 instead of kp-43770?
May 20, 2012 | Televison & Video
I have blue wavy lines on my screen when i play my xbox360 and ps3 on video 2 but not when im watching cable
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 14, 2010 | Sony KP-43T70 43" Rear Projection...
Poor picture quality, the picture is blurred and
You have problem with convergence. Have you tried adjusting in the users menu. This is a common problem in this type of TV, usually two convergence amp need to be replaced and sometimes sets of resistors are also to be changed.
Mar 02, 2010 | Sony KP-43T70 43" Rear Projection...
KP-51HW40 Sony 51" Fades to blue screen
The service manual on page 8 shows how to adjust the Red/Blue/Green screen voltages. To get to the adjustment board, take the front speaker grill off (two screws at the bottom left and right) and set it aside. No need to disconnect any wires. Then remove the plywood board with 4 screws that exposes the screen/focus adjustments. The top 3 adjustments are for focus, and you need not mess with these. The bottom 3 adjustments are for Red/Blue/Green screen voltage rough adjustments. My screen showed red lines, so I had to turn the bottom right adjustment with a philips head screwdriver just slightly until the red gun retrace lines where no longer visible.
Aug 26, 2008 | Sony KP-51HW40 51" Rear Projection...
Red Bowed Lines / Red Hue
I tried the solution that was posted for this problem and it worked!
Just remove the Low front panel by removing the two bottom screws that are covered by two screw covers, then remove the second panel (black) by removing the 4 screws then you'll notice a module with 6 adjustment knobs, get a small screw driver, and with the t.v. on, being carefull , and with somebody accross the room looking at the screen begin with the lower left knob and turn left very slowly and ask the person across the room to let you know if the screen is better or not, after this I had to adjust the green as well so, I adjusted the next knob over to the left. Do this adjustment carefully and try to remenber the original position of the knobs in case you have to go back.f
Good Luck,
Californian.
Jun 03, 2008 | Sony KP-57HW40 57" Rear Projection...
KP43t70 NO PICTURE SUDDENLY
SYMPTOMS
No power
RESOLUTION
Found IC601, F601, and R612 on the G Board defective.
Get the manual at http://fletchersite.com/contact.php
Oct 14, 2007 | Sony KP-43T70 43" Rear Projection...
Sony KP-43T70 green ghost problem
The cause of the problem can be that the CRT-s are getting weak. Life span of CRT is around 30000 hours of working time. Please calculate. If you need more info please advice.
Apr 03, 2007 | Sony KP-43T70 43" Rear Projection...
Sony KP-43T70
A steady red light is an indication of a power supply regulation problem.. Its not a job that can be done by a do-it your selfer or an end user. Sorry man those days are done. You should for your health and best interest, seek out a local TV repair peep to assist you with this repair.
Sep 13, 2006 | Sony KP-43T70 43" Rear Projection...
Sony KP-43T70 43" Rear Projection Television Logo
149 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
