Question about GE Ovens
GE Electric Oven Model KP62COK3 (1989)
What is the corrcet amount of "drift" for an electric oven? When the oven is set on 350, is it OK (normal) that it drifts between appox. 300 and 400?
Steve
aborcass
  • 2651 Answers
SOURCE: oven
F2 is aproblem with the oven sensor part number WB21X5301
Posted on Mar 16, 2008
SOURCE: kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Posted on Jul 20, 2008
  • 3 Answers
SOURCE: ge profile oven loc
hey - I figured it out! hold down the 9 and 0 at the same time for 3 seconds! or it might be another combination depending on your oven - it is probably the 2 keys that the messge is under
Yay!
Island2
Posted on Oct 03, 2008
jyackle5
  • 8197 Answers
SOURCE: magic chef manual
You can download it here but you need the right model #.
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=MCF
As for the temp adjust it is best if you get an repair man out to do that.
Good Luck
Posted on Dec 18, 2008
  • 19 Answers
SOURCE: F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
Posted on May 09, 2009
GE electric oven won't stay hot
Google GE electric oven Model number: ? Manual
Jan 15, 2018 | GE Ovens
GE free-standing electric range Pre-heat oven temp is about 50 degrees less than what is set (i.e. set digital display to 400 and over only reaches about 350). Is there an adjustment that can be made to...
We have a new GE Range and the signal beeps at about 100 degrees below the temp which we have set . The dealer replaced the sensor and the control circuit, but there was no change.
A service tech from GE came to our house and explained that the new ovens have a bottom heating element which is covered and therefore heats the lower part of the oven more slowly; but the exposed upper element heats more rapidly and the sensor is located near the upper element. We were advised to wait for about 15-20 minutes after the beep before placing the food in the oven. Judging from the number of comments found online, this seems to be a feature of newer ranges.
SnapDoc
Nov 08, 2010 | GE JKS05 Electric Single Oven
GE oven temperature is not true, and needs to be reset. Oven temp reads 350, but is actuallyonly 325. Can you help?
The temperature is within manufactures specifications.
By that I mean that the majority of manufactures allow a tolerance of + or - 10 % of the set temperature.
So, in your case, 10% of 350 degrees is 35 degrees, thereby showing that the actual temperature you are obtaining is well within the 10% allowance.
I hope this helps you .
Jan 03, 2010 | GE Profile JTP18 Electric Single Oven
GE ModelJTP14 oven, after 30 minutes at 350, the oven flashed a F2 code. Cooled and restarted the oven at 350, after 26 minutes it flashed F3. I have been remodeling and have taken the oven out of the...
check the codes for your particular model..they are included witht he wiring diagram that came with your oven. F2 likely means your control board (ERC) has an issue. I can't vouch for accuracy but here's another location with fault code listings http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#GE Range / Stove / Oven Fault Codes
You can try turning the circuit breaker off that feeds power to your oven ( in your house electrical panel) that might work. If it does not, unfortunately it might be indicating a need to replace the control board... good luck!
Jul 13, 2009 | GE JTP15 Electric Single Oven
I have a brand two month old GE 27" wall oven. It takes a very long time to pre-heat, sometimes up to 30 minutes for 350. Any ideas? Is this normal?
check your power connections, do you get 240 volts between red and black, 120v red/black to white? at outlet and in unit
Jul 05, 2009 | GE JKP30BMBB 27" Built-in Single Electric...
Have a GE Electric Cook Top oven with digital
Unplug the stove. plug back in and program a short clean cycle. If this does not fix it is eithe the selector switch or the electronic control. Verifying the switch contacts with a meter is the only way to be sure.
Eric
Jun 21, 2009 | Ovens
May 09, 2009 | GE JRP15 Electric Single Oven
Bottom oven gets extremely hot
It would appear you have a faulty thermostat that controls the temp. SUggest you get a new thermostat fitted.
Dec 08, 2008 | GE JTP27 Electric Double Oven
GE Profile JT952 Double Wall Oven doesn't heat up adequately
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 29, 2008 | GE Profile JT952 Electric Double Oven
Ovens Logo
53 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
