My device when i push power it turns on a second then shuts off
  • Kimbo too May 11, 2010
    need more info, model no;s etc'.
    Problem Solver:
  • 5 Answers
Aside from any intrinsic problem with your receiver, the usual suspects are;
1) Shorts in the speaker wiring.
2) A rubbing loudspeaker voice coil.
Remove all input and output connections from your receiver and determine whether the unit remains on. If it does, check for the conditions indicated above.
Posted on Oct 04, 2009
What is the code for a GE remote
turn device on (tv etc)
hold power and device button until remote blinks
release both buttons
press power repeatedly until device shuts off
when device shuts off push device button on remote to save setting should blink again
press power test that remote operates device
Nov 10, 2016 | GE Televison & Video
Do someone have a vcr remote code for kaon ksc 570?
Turn device on (tv etc)
press power and test that remote operates device
Nov 10, 2016 | Televison & Video
After shutting down the Vostro 200 slim tower the power button turns from blue to amber and stays that way. I have to push the power button down for a few seconds to fully shut down. any idea why it does...
IT IS SLEEP MODE AND YOU HAVENT SET ANY DEVICES TO WAKE IT UP.JUST FIGURE OUT HOWE TO SET DEVICES TO WAKE FROM SLEEP OR CHANGE SLEEP TO ANOTHER SETTING .JUST GOOGLE IT AND YOU WILL FIND THE ANSWER YOU ARE LOOKING FOR.
Jun 27, 2012 | Dell Vostro 200 Desktop Computer
Push power button and timer button lights for a few seconds and then tv turns off model is Ws 55859
When it shuts down go to the set and press the menu and the Device/Input button both in together and hold for 6 seconds then count the two digit blink code from the power indicator. it will blink a two digit code which repeats several times.
Jul 23, 2011 | Mitsubishi WS-55859 55" Rear Projection...
Linving solutions cd,alarm clock, radio.I'm trying to find a free pdf download users instructions for the Living Solutions cd player,clock & radio combo.
follow the instructions below:
  1. Turn on the component you wish to sync to your universal remote--your television, DVD player, VCR or stereo.
  2. Point the remote at the device you are programming and press the corresponding device button on the remote. These buttons are labeled "TV," "VCR", "DVD," etc. Hold the device button for three to five seconds.
  3. Push the power button on the remote. This should turn on the device that you are syncing.
  4. Push the "Channel Up" or "Channel Down" button on your remote gradually until the device that you are programming shuts off.
  5. Press "OK" or "Enter" on the remote once the synced device turns off.
  6. Press the device button for the component you just programmed, and hit the power button while pointing the remote at the component. If programmed correctly, the device should turn on, and you should be able to control it with your Living Solutions Universal Remote.
Hope this helps,
Lucas
Jul 08, 2011 | Televison & Video
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
Need remote code for symphonic tv. Have living solutions giant remote
    Programming a Living Solutions Universal Remote
  1. Step 1 Turn on the component you wish to sync to your universal remote--your television, DVD player, VCR or stereo.
  2. Step 2 Point the remote at the device you are programming and press the corresponding device button on the remote. These buttons are labeled "TV," "VCR", "DVD," etc. Hold the device button for three to five seconds.
  3. Step 3 Push the power button on the remote. This should turn on the device that you are syncing.
  4. Step 4 Push the "Channel Up" or "Channel Down" button on your remote gradually until the device that you are programming shuts off.
  5. Step 5 Press "OK" or "Enter" on the remote once the synced device turns off.
  6. Step 6 Press the device button for the component you just programmed, and hit the power button while pointing the remote at the component. If programmed correctly, the device should turn on, and you should be able to control it with your Living Solutions Universal Remote.
Jun 30, 2010 | Symphonic ST420FF 20" TV
Model 255wt. How do I turn off when using battery
Just push the regular off button. It may take a time or two but hold the off button for about 5 seconds it will shut off then.
May 05, 2010 | Garmin nuvi 255W GPS Receiver
Turns on when I push the butten then shuts off
Try soft reset :
hold lap/reset and mode buttons for ten seconds, then release and wait 10sec, then hold start button for 10 seconds, device should start
Jan 11, 2010 | Garmin Edge 305 GPS Receiver
Brand New...Can't get it to stay on?
Make sure you have it connected to a power source properly. Push and release the power switch. (it is spring loaded) Don't push it to the lock position for now.
Jun 07, 2009 | Garmin nuvi 260W GPS Receiver
53 people viewed this question
 Grubhead
Grubhead
