Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
How do i open the entire lid of washer to repair switch?
  • 5,911 Answers
The following link explains step-by-step how to replace the lid switch on Whirlpool top loader:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
Posted on Oct 02, 2009
Kenmore 11026012010
unplug lid switch and replace with a piece of wire.(properly insulated of course) i assume that since you know what a lid switch is, you also know to unplug the machine, and watch out for capacitors if opening up the washer .this was the problem with mine and i bypassed it also. just remember the washer will now function through the entire cycle with the lid open. safety is key. imagine what a spin cycle could do to an arm.
Apr 30, 2012 | Dryers
Washer loads with water but will not start to agitate --seems to be a switch in the cover---what do I need to do re the switch
<div class="solution-text"><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution"><span><span>The symptoms you describe are common for a lid switch malfunction.</span></span></span></div> <div class="solution-text"><span><span></span></span> </div> <div class="solution-text"><span><span></span></span> </div> <div class="solution-text"><span><span><span>If the model nuber you posted this question under is correct, the lid switch is mounted under the washer top casing, on the right hand side. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:<br /><br /><a href="http://www.fixya.com/support/r3557193-replacing_a_lid_switch" target="_blank">http://www.fixya.com/support/r3557193-replacing_a_lid_switch</a><br /><br /><br /><br />NOTE: If the washer is still full of water, you do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.<br /><br /><br />Replacement parts (if required) can be purchased at any of the following web sites:<br /><br />searspartsdirect.com<br />pcappliancerepair.com<br />appliancepartspros.com<br />repairclinic.com<br /><br /><br /></span></span>The part number for a replacement lid switch for this model washer is 3949247. The lid strike is 358684. These parts are listed as items 11 and 20, respectively, under the "Top and Cabinet" parts section.<br /><span></span></span></div> <div class="solution-text"><span><span></span></span> </div> <div class="solution-text"><span><span><span>For future reference : If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20. <br /><br />Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.</span></span></span> </div>
Aug 24, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
How do I replace the lid switch on my Kenmore Series 80 washing machine I have the part
Hi
To replace the lid switch in a Whirlpool-built direct drive washer you’ll need to open it up. This washer use plastic end caps to cover the console screws. Just remove the console end caps and the console retaining screws are right there. Once you've removed the console screws, flip the entire control console up and back to reveal the cabinet retaining braces. After the cabinet is pulled back from washer you’ll be able to see the lid switch. You can inspect whether the lid switch is disconnected or burnt, use a multimeter to check the continuity of the lid switch.
Please post back for any further assistance.
Daniel
Jul 30, 2010 | Washing Machines
My kenmore 110 will fill and rinse, but will not agitate, drain, or spin. I ran 2 tests before this post. Once the washer gets to the wash cycle, it just stops, I get nothing. I also don't hear any motor...
Check your lid switch. If the washer fills and agitates, but stops at the rinse cycle, or, if the washer fills, then stops and will NOT drain, this is a common symptom of a lid switch malfunction. The following link explains how to access and/or replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
repairclinic.com
The average price is about $20 - $30. Prices differ between these sites, so shop around for the best price.
This is a very simple repair, but if you have questions, please let me know. I hope this helps you.
NOTE: You do not need to drain the washer to replace the switch.
Nov 19, 2009 | Dryers
Kenmore 70 Series will not Rinse or spin
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
One way to check if the Lid Switch is bad is to by-pass it.
See GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Rather than removing the entire cabinet, just go through the process for removing the Console and up-plugging the lid switch.
Use a short piece of insulated wire and jumper the switch between the outer two contacts.
Lower the console and start the washer in the shortest cycle that you can.
After it fills part way, stop it and move the dial to the rinse cycle.
If it rinses and spins, the problem is in the switch which is basically held on by a couple of screws.
Of the washer still will not rinse or spin, the problem is likely in the timer.
Without knowing your model number, I couldn't tell you what a switch costs but it should be around $30.
If I'm correct in assuming that your model uses a switch with two screws, (check the Sears parts list for your washer under the Top and Cabinet category for the LID SWITCH) tightening the screws may solve your problem. The Diagram for the Top and Cabinet will show you where the screws connect.
Sep 24, 2009 | Kenmore 20722
Maytag top loading washer will not agitate
My rule of thumb: Take what you paid for the washer new and divide by number of years without repairs. That is your cost per year for the washer. If the repair will get you another year and is less than the number above do the repair. If you have done more than 2 major repairs in a year it is time to think new. eric
Aug 10, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Ultimate Care4 II washer fills with water and then just stops.
Try tightening up the screws on either side of the door before replacing the switch..
Mar 24, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Wont spin or drain.
Check your lid switch. It may be loose or not making good contact. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading as item number 11 (part number 3949247). For instructions on how to replace a lid switch, click on the following link:
You can by-pass the lid switch to drain the water by performing the following:
1. Unplug the washer and remove the console and case.
2. Unplug the lid switch connector from the timer and remove the entire lid switch assembly from under the washer case.
3. With the old lid switch assembly in hand, cut the square white connector plug off the end leaving about 2 to 3 inches of wire.
4. Clip the middle wire (green, or green and yellow) flush leaving the two black wires. Strip the wire ends and twist together using a wire nut or wire crimp. You have now made yourself a by-pass plug.
5. Plug the by-pass into the lid switch receptacle on the timer and place washer case back in place.
6. Plug unit back in and move the selector know to the final spin cylce. Pull the start knob and the washer should begin to drain.
It is strongly recommended that you DO NOT run the washer for exended periods of time with the lid switch by-passed as this is a designed safety feature of the washer. And, for your own safety, do not run the washer with the exterior case removed.
This is a simple and inexpensive repair. I hope this helps you. Let me know if you require further assistance.
Aug 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
How to open washer to check and fix lid switch
the lid switch can be changed without removing from closet for sure,you can remove the angular access panel between the2 units youll see 2 brass clips holding the cabinet to the top, slide the entire top toward you to remove. its located under there. there may be 2 screws across the rear of main top holding down as well but yea pulling out will get you kn more access to any component
Mar 14, 2008 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
176 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
