Question about Canon Elura 60 Mini DV Digital Camcorder
Elura 60 Zoom Problem
My Canon Elura 60 had the same zoom problem as the all others had. It just zoomed itself to maximum. I had to hold the zoom button to keep the position. Sometimes, it fixed by itself. Next time when I use it, the problem came back again. Randomly!. It seems that this is a very common problem for this family of camcorder elura 60, 65, 70... My comcorder is almost three years. Forget about Canon, buy another brand to replace.
  • 5 more comments
  • Anonymous Feb 21, 2008
    I too have the same zoom problem, is this common?, is there a solution?
  • SMSturbo Mar 02, 2008
    I have the exact same problem. My Canon Elura 60 just started zooming in to maximum zoom. I have found no solution yet.
  • cfrdog Sep 21, 2008
    I have an Elura 60 as well and it zooms to the T (slowly) but i have to hold it to stay put, its really annoying. I'm done with Canon products. They work great at first but don't last at all. Same for their crappy point and shoot cameras. Canon sucks.
  • Anonymous Nov 11, 2008
    This camera should be recalled! I too have the same problem...zooming full force constantly during video and photography. After reading the solution of dropping it on the floor to fix the jam, I tapped the bottom on a book and then the zooming issue was fixed and the video was instantly broken. It kept trying to eject the video when I powered it on and would do nothing until the video was ejected, but the video door was jammed. Piece of junk! I got so frustrated that I smacked the side of it with the palm of my hand and the video cassette came out. I'm going to buy a Sony. I never had any problems with the Sony I had previously to this Canon. Unfortunately I gave the Sony to a friend when I purchased the Canon thinking Canon was a better name.
  • Raven91 Nov 11, 2008
  • raymundo0888 Dec 31, 2008
    My Canon Elura 60 had the same zoom problem as the all others had. It just zoomed itself to maximum. I had to hold the zoom button to keep the position. Sometimes, it fixed by itself. Next time when I use it, the problem came back again. Randomly!. It seems that this is a very common problem for this family of camcorder.
    I took the advice listed and banged the base on something hard....Holy Cow...I worked...NO MORE ZOOM PROBLEM!!! THANKS.
  • leona3339 Feb 28, 2009
    Elura 65 Mini Dv Zoom problem. I've had the camera for almost 5 years now and I had this zooming issue only once. I banged it against book and it fixed itself! I think it rocks! I was so surprised it worked. I was alreadysearching for a new cam!
Guys, so weird but on another site it offered this suggestion: banged the base of your camera against something hard and it will become unstuck. So bang the base of your camera against something hard and it will work again, at least it works like it did but not sure for how long. Good luck. I can't believe that worked. Give it a try. I didnt hit it too hard either.
Posted on Sep 21, 2008
I tried the banging the sides but just against my hand and it freakin' worked. I can't believe a solution this stupid is the actual fix. Anyone who is reading this must know that I do not advocate anyone including myself hitting their sensitive equipment but lets face it, the camera was not working and would just sit. So I figured, what the heck do I have to lose? I works, and you do not have to hit it very hard at all. My camera has been working great ever since. THANKS TO EVERYONE WHO POSTED THIS CRAZY TECHNIQUE.
Posted on Jun 11, 2009
I wonder how many repair shops have made a killing out of people that had this problem? Tapping the bottom actually works. Thanks for the advise!
Posted on Apr 09, 2010
Unbelievable! I slighlty tapped the base on my desk (wood) and it worked. If the zoom indicator appears in the view finder, that means it is not working. When I tapped it slightly on my desk it disappeared, and the zoom began working.
Posted on Nov 15, 2009
Yes the hit on my desk fix mine too.
Posted on May 28, 2009
My dad banged it  against his leg after reading leonas suggestion, genius it worked
Posted on Jul 19, 2009
It really really works!!! Just with the base against my palm and hit three
time, the problem disappeared. So weird. (Remove tape and battery first
as somebody suggested)
Posted on Jul 05, 2009
Wow, this is wild. I recently turned my Elura 80 on for the first time in about a year. The camera took a good amount of time to zoom all the way out, and once I let go of the zoom, it would automatically zoom back in. I thought it was perhaps a setting on the camera until I researched it and came across this forum. When I read of people banging it against books or dropping it on the floor, I laughed it off, until I got frustrated enough to try it myself. Let me tell you- I took out the tape, turned off the camera and hit both sides as well as the bottom against a book. After turning the camera back on within SECONDS the problem was fixed. Good to know! My camera is fine after hitting it, and in perfect working condition.
Posted on May 17, 2009
Amazing! Banging on the base lightly (not too hard) actually freed it up and it seems to work. Thanks all.
Posted on Feb 16, 2009
Can't believe it, but following the advice here, I just gave it a good slap it on its base with the palm of my hand after removing the tape and battery and it worked.  Thanks all!
Posted on Jan 29, 2009
I try to find out why it need to be shaked like that, I thought that it was a bad contact ? but I'm not sure. What canon has to say about that ?
Posted on Sep 19, 2012
IF YOU KNCK HARD ON THE BASE OT THIS PIEACE OF SH-T IT SEEMS TO WORK. IT WORK FOR ME.
I too have the same issue on mine. Maybe you don't have the eject tape issue like I do. I concur with your assessment, don't buy any Canon Products in the future.
Posted on Jan 02, 2008
My canon elura 60 when open my video cam it zoom automatically and the zoom lever dont work.
The zoom assembly will need to be replaced. This repair should be done by an experienced technician. Unfortunately, there is no easy fix that you can do yourself.
Hope this helps you.
www.austintelstarservices.com
Jul 21, 2011 | Canon Elura 60 Mini DV Digital Camcorder
Zoom problem
The zoom is stuck. Smack the bottom of the camera with the palm of your hand. Worked like a charm for me.
Oct 23, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Zoom button of canon elura minin dv
I had a similar problem. Searching Google for a solution, I came across the old -- "if it doesn't work, smack it" trick:
Remove any tape in the camera.
Remove the battery.
With your hand holding the top of camera, hit it firmly with a book on the bottom. I used about a 200 page paperback.
I suspect it is a electro-mechanical switch that gets stuck in the "On" position, and a little jolt frees it up again.
I have done this twice in the last month, and it works great.
Aug 29, 2008 | Canon Elura 60 Mini DV Digital Camcorder
Zoom
My zoom problem was a combination of the software and hardware when it came to the neutral position for the zoom slider. When the camera is first turned on, if the physical zoom slider (hardware) is in the neutral position (you are not touching it) the camera software does nothing, but if you are pushing the physical zoom slider when you turn on the camera, the software resets the "zero zoom" position into memory. The solution to my problem was to push and hold the physical zoom slider towards the wide position and the software realize reset the "zero zoom" neutral position. This may take a few tries to get it right (if you over compensate, do the opposite and push the slider towards "T" when you turn it on), but I hope this will solve your problem and save you a few bucks.
Ryan
Jul 04, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Canon Elura 60 zooms by itself
Listen, I know it's a couple of years after this post but, try this: Remove cassette, push to close, close camera as if to use it, hold firmly in left hand, open hand slap it with your right hand once or twice, (I'm not joking) it worked the two times I had this problem. Problems with the zoom? Almost same process, push firmly on zoom button (to un-zoom) try doing this as your tapping it. These are last ditch efforts on an aging camera, it really has been a good one. I've put this poor thing through years of abuse, and it's held up pretty well. Good luck, Jeff S.
Oct 16, 2007 | Canon Elura 60 Mini DV Digital Camcorder
Canon elura 60 camcorder zoom is at its maximum and it is stuck .
 I have the same probelm how can i fix this.
Oct 15, 2007 | Video Cameras
Automatically zooming in
Hello:
I contacted Canon about this same issue in my Elura 65, and they said to send it to them, they would have their techs investigate the cause and then contact me with the costs to make the repairs. They said that if I didn't want them to repair the problem, after I found out the cost, that they would reassemble the camera and send it back.
Mine is out of warranty, even with buying it at Costco, who doubles the warranty time. In my researching the problem, I have found another person with the same problem who had it repaired for something like $175. I will weigh that against purchasing a newer model.
Someone else did reccommend wacking in on the top a few times, shutting if off and turning it back on, and that would often fix the problem. I don't want to take the chance of ruining an important shot that may not come around again, by having to Indian Leg Wrestle my camera to get it to work. Best wishes.
Oct 12, 2007 | Canon Elura 60 Mini DV Digital Camcorder
Zooming problem
I have the same problem. I have no fix in rec mode but if it happens during playback; press menu and select the zoom options. You don't have to pick any but just keep the menu displayed on the screen. I do this while recording the tape to my DVD recorder and it solves the locked zoom problem. The menu display does not get recorded.
This zoom problem is a big pain. We should start a class action suit against Canon. It started within a year of ownership with mine. I bought a Panasonic recently and haven't looked back.
Panasonic doesn't have the slick Canon marketing/packaging but it is a much better machine.
Aug 20, 2007 | Canon Elura 60 Mini DV Digital Camcorder
Canon Elura 60 - Zoom is on maximum and won't restore. I own Canon Elura 60 since last two years and now i'm facing problems with zoom. Zoom button does go to and fro but actual zoom doesn't take...
Hi There, did you find any resolution for this problem? If you could share any info about the problem, it will be really great. Even I have the same issue with my Elura 70. Thanks.. Pradeep
Nov 08, 2006 | Canon Elura 60 Mini DV Digital Camcorder
Canon Elura 60 Mini DV Digital Camcorder Logo
816 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
