Question about Mitsubishi Televison & Video
I have a mitsubishi 55 inch medallion hdtv 1080 tv and wont turn on timer light is blinking constantly tried reset button and still wont turn on
  • 497 Answers
These steps are general troubleshooting steps for a Projection Television.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
* If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
* If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
1. Turn off the television.
IMPORTANT: For a projection TV that uses an internal lamp, wait 5 minutes after turning off the TV to allow the lamp to cool before continuing with the following steps.
2. Unplug the TV power cord from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet.
NOTE: If the TV is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the TV.
5. Turn ON the television.
NOTE: If the TV does not turn on immediately, the fan may need to finish its cycle. This is part of the cooling process for some projection TVs and is normal operation. After the fan turns off, attempt to turn the TV on again.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
Good Luck!!!!!!!!!!!!!
Posted on Oct 03, 2009
Hdtv flashing green light for timer tv wont turn on
If the TV is a few years old the flashing green light means the bulb need to be replaced. That's why the TV will not show a picture. Check your owners manual on how to replace.
Mar 20, 2013 | Mitsubishi LT55164 Unisen Medallion 55...
I have a Mitsubishi Medallion HDTV 1080 55 inch that when I push the device button to change the input, it locks up the whole tv and I have to reset the system just to turn it off. How do I fix this...
You will most likely find, on the power supply board, a 5volt regulator that supplies the microprocessor. It is on a heatsink and is protruding perpendicular from the board on a heatsink. If you examine the copper side of the printed circuit board, there will be dry joints on the three pins making a bad connection. If you can, replace the regulator and your problems should be gone.
Hope this helps.
Nov 06, 2010 | Mitsubishi WS-55809 55" Rear Projection...
My mitsubishi tv wont come on and green timmer light blinks fast
Try the blinking light repair kit from http://www.tvrepairkits.com/xcart/home.php?cat=2658 . This kit has fuses and capacitors that are designed for your TV.
I hope this helps.
Apr 24, 2010 | Televison & Video
Light flashing and tv won't turn on
Hi there, I have a Mitsubishi HDTV 1080 and when I tried to turn it on the tv this morning it wouldn't turn on and the power light is flashing green. I pushed in the reset button but it just keeps flashing and still won't turn on.
Oct 05, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi 65 medallion hdtv 1080
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
this has how to fix the blinking light check out this forum for more on this type of stuff
http://forum.ecoustics.com/cgi-bin/bbs/show.pl?2/108250
Aug 27, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi 1080 HD Medallion
If the LED doesnt light. Check the fuses. the fuse many be blown. Unplug the set before you check the fuse.
Jun 14, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi Medallion HD 1080 model ws-48413
my mitsubishi medallion tv wont power on.
all I get is a blinking light. How can this be fixed
May 08, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Tv wont turn on
This problem very well could be a DM board problem. I have a how to fix file if this is indeed your sets problem. Leave your email and I will send it to you. Good Luck
Jun 15, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Open Questions:
Televison & Video Logo
98 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
