Question about IBM ThinkCenter S50 (841741UGJ0F44SH06) PC Desktop
Cannot use internet and the comp goes into blue screen and dumping physical memory.then unable to shut down.comp tells of conflicting hard or soft ware but cannot get to remove it
  • IBM Master
  • 3,051 Answers
Hello there:
If you cant get the computer to uninstall this in the safe mode or if you cant even get to the safe mode yo are going have to use your system restore disk if you have one and use it to repair the windows version that you have if you dont have the restore disk you can repair the current version using the disk that you have bu putting the disk in and restarting the computer
once it starts lt it start and press any key when it asked than after that enter the f-8 key and do not say repair let it go into the install of your operating syste than it will show you your windows versiion that you have and then it wil ask you if you want to repair this version of windows now say yes and follow the screen it will repair it and reinstall the corrupted file '(s) ok
best regards michael
Posted on Oct 02, 2009
    Scholar:
  • 115 Answers
The blue screen means the hard drive is out of order. It is telling you that you have one large virus and it will not allow you to do anything until you fix it. Easiest way to fix is to reinstall your OS. This will reset the HD and hence, no more blue screen. Cheers.
Physical memory dumping when l start to play gta
providing the actual dump message will greatly increase the chances of a correct diagnostic of the problem. (yes the message actually tells us why it goes to physical mem dump) other than that i'd check the fans and fins for dust buildup (causes overheating)
Nov 02, 2013 | Rockstar Games Video Game Consoles & Games
once your computer take an BOD or blue screen of *****. it is an indicator that one of you perepherals was damage. in that case you only have to option the memory cards or the HDD. if some point you dont experience a hard time in booting it is not the HDD. maybe your memory cards was in defective state. sometimes good sometimes bad. try to chkdsk first or scan your HDD for posible bad cluster. and make a test also in your memory using some stress memory tester
Aug 21, 2017 | Intel Motherboard
A have a laptop toshiba l640. when i start the laptop within ten minutes a blue screen showing physical memory dumped is displayed. pls explain wat to do with it.
1. This problem is usually occur
a. When there is any hardware conflict
b. A newly install driver creates problem
C. Partitions of the hard Drive are deleted due to viral effect.
Solution:
You need to reinstall the windows.
Jul 08, 2011 | Computers & Internet
What do I do to stop my laptop from dumping physical memory? My laptop says this: STOP:0X000000D1 (0X6F19E728, 0X00000002, 0X00000000, 0XF7A59271) W22N51. SYS- ADDRESS F7A59271 BASE AT F79F0000, DATE STAMP...
You have either installed a faulty driver or unsuitble update or your Hard Drive,CD Rom or some other Hardware has failed, try starting in Safe Mode by pressing the F8 key several times right after starting your computer if you get in select the "last good known configurations" or "safe mode" itself and undo changes made before this happend. If all fails try to do a system restore from the safe mode entry.
Jul 07, 2010 | Toshiba Satellite A100-S8111TD Notebook
When closing computer , it goes into blue screen and dumping mem
r u using Windows Xp then Delete it and reinstall it and use best Antivirus or if other windows then do the same
Please Vote 4 me
Oct 02, 2009 | IBM ThinkCenter S50 (841741UGJ0F44SH06) PC...
This is not the problem of drivers it is the problem with the memory when one or more programmes try to occupy the same ram space at the same time if you want to get rid of this problem i suggest you to format your pc once and reload the os.
May 30, 2009 | Computers & Internet
Blue screen message, Dumping Physical memory.
It's really hard to say at this stage, and there's many more tests that you'll need to run in order to try and narrow down the cause of the problem(s). They could be anything from a potential virus infection causing conflicts, an incorrect video or audio driver being installed, to something corrupt within your windows OS, to potentially being something hardware related like your hard drive, or as you suspect, motherboard. You can try narrowing one of the major problems down, by backing up any personal data to CD/DVD or external hard drive, and then erasing the hard drive and reinstalling a fresh copy of windows and try reproducing the problem there. At this stage of the issue, it's all about trying to isolate where the fault is coming from, and this step will eliminate a lot of possibilities.
May 23, 2009 | Computers & Internet
Dell Dimension 4600 Blue Screen
Usually this blue screen appears due a hardware issue or drivers conflict.
1) Try to boot in safe mode (hit F8 after starting up) and select "Safe mode"
If you don't get access try doing this:
2) Run the OS CD and use the option Recover Console (R)
This will fix the problem.
3) If the problem continues, you will need to install the OS again.
Oct 07, 2008 | Computers & Internet
Computers & Internet Logo
47 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
