Question about ViewSonic VP230mb 23.1" LCD Monitor
No power did not work out of the box
How do you test the power supply? the on switch doesn't lite. amber or green
I'm looking to get a power supply for a VP230mb lcd.
I'm in chicago and would like to install it myself.
Unless someone can recommned a reasonable local repair shop
Posted on Apr 24, 2008
Ds light green,dim green, amber then off when power is turned on
Sounds like you need to send it in for repair. I had sent my console to and they repaired mine at a great cost and got it back at the end of the week. Give them a try, they are cheaper than a manufacturer. Good luck!
May 04, 2013 | Nintendo DS Lite
Gateway 500C: Dead. green PSU lite doesn't lite when pressing test switch
Obviously your Power Supply Unit is dead. You just have to replace it.
Feb 17, 2013 | Gateway Computers & Internet
Hi Don
first thing to check would be all power leads and fuse to clear those areas from the list. Providing all of these are correct, it looks like either your power button has gone faulty of the power supply itself. I am not familiar with this particular machine, is it a normal tower sized machine? if so then a psu replacement is relatively cheap and easy, just make sure that the replacement has all of the connections that you require.
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Have a dell gx280, shut it down last night and this morning the normally green start up lite was flashing amber. after looking at some forum most replied with either replacing the mb or power supply which...
It's a pretty common issue with the 270 & 280. More times than not it is blown capacitors at the root of the problem. Replacing the caps is simple if you know how to solder very well & makes for an easy fix. Also, make sure you're pushing enough power through your supply.
Sep 18, 2017 | Dell OptiPlex GX280 PC Desktop
Blinking amber light.I changed 2 motherboards out and still blinking amber. Changed the CMOS battery, same thing blinking amber. Swapped memory and removed all pci cards, same thing. The motherboard has a...
I'm not clear about the blinking amber light you are referring to. Is it on the computer or the monitor.
I checked Dell's web site for the service manual for this computer model, & found this document:
If the blinking amber light is on the monitor, check the connection between it & the computer itself. Make sure the cable is not damaged & that it does not have any broken pins in the socket.
Dec 16, 2009 | Dell Dimension 8300 PC Desktop
Dell 4500 won't turn on,power light amber/green
Is the light more amber or more green? If you push the button and it goes amber, then you probably have a bad power supply. Try getting another power supply to test. If that doesn't solve the problem, then you probably have a bad motherboard.
Oct 22, 2009 | Dell Dimension 4500 PC Desktop
Yellow lite flashing on dell demenison, will not turn green!Clean tower and it work for a wile but it goes back to yellow or amber
I think that either there is a faulty connection on your power supply or the power supply itself is faulty and needs replacing. Good luck.
Oct 01, 2008 | Computers & Internet
ViewSonic VP230mb 23.1" LCD Monitor Logo
112 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
