Question about Taylormade r7 Draw Fairway Woods
Where is the taylor made r7 cgb max irons serial number located on the iron?
  • 21 Answers
I found this on dogpile: "For iron sets, the serial number can be found on the 5-iron or 7-iron. For iron sets, the serial number can be found on the 5-iron or 7-iron. "
Posted on Oct 02, 2009
NEED USER MANUAL FOR FRESH EXPRESS MAX
is this and iron or an juicer slicer type machine. I found a food processor from 2 companies but no iron, do y ou have a model number?
Feb 01, 2015 | Irons
WHERE IS THE SERIAL NUMBER ON THE PHILIPS GC4890/02
I remember reading a # stamped right on the prongs of the plug in. Let me know if that works!
Jul 10, 2014 | Philips Azur Gc4890/02 Steam Iron With...
How do I register mynew Philips Iron
If you do not have the registration card then you can do it on the Philips web site. You will need the serial number to do this which you can find on the iron.
May 14, 2014 | Philips Philishave HQ7782 Electric Shaver
Where is Weller WES51 SOLDERING STATION serial number located?
On the regulatory voltage and power consumption label which will be on the iron, and the base unit.
May 16, 2013 | Welding Tools
Will not send steam to the iron. Cleaned boiler cleaned reservoir. Help!! i love this iron.
Assuming the iron is hot???, move the variable steam control from min to max several times to clear possible blockage. Sounds like the steam valve is clogged.
Jul 04, 2010 | Rowenta DG-980 Iron
More height off the tee required and ball flight to the left
If you are using an iron club...never place the tee high...the higher the tee with an iron, the more draw or fade you will get. Keep the tees closer to the ground and take your stance back a little too...
Mar 16, 2010 | Taylor Instruments Taylor Made R7 Quad 9.5...
How do I adjust the R7 driver
I think the red are the heavier ones. For draw put the two red ones furthest away from you and the yellow two closest to you
Oct 07, 2009 | Taylor Instruments Taylor Made R7 Quad...
Taylor made r7 quad user manual
Here you go...you can find it at .....http://www.golf-finder.net/index2.php?option=com_content&do_pdf=1&id=294
Sep 18, 2009 | Taylor Instruments Taylor Made R7 Quad 9.5...
How to use the calc-clean button
Calc-Clean function
The Calc-Clean function removes scale and impurities.
To do so, set the steam control to position '0', set the temperature dial to 'MAX', and fill water tank up to the 'MAX' level. Then heat up the iron until the pilot light on the handgrip goes out.
Remove the mains plug from the wall socket and hold the iron horizontally over the sink. Then press and hold down the 'CALC CLEAN' button.
Move the iron forwards and backwards while boiling water/steam squirt from the holes in the soleplate to wash away impurities/scales.
When the water tank is empty, heat up the iron to dry it.
Finally move the iron to and fro on a piece of cloth to dry the soleplate. Repeat the process if necessary
May 05, 2009 | Philips HI-296 Iron
My husband threw away the opereating instructions for our iron.
SELF CLEANINGIt is important to “Self Clean” the iron at least every two weeksto remove scale, calcium, etc. The harder the water, the more often the iron should be self cleaned.1. Set the variable steam control dial to any steam position.2. Fill the water tank up to the “MAX” level.3. Stand the iron on its heel. Plug the iron into the electrical outlet.4.Press the electronic temperature control button until you get the “MAX” temperature setting on the display panel and wait until the iron heats up and temperature setting light stops flashing.5. Turn the variable steam control dial all the way to the right to the self-cleaning position and hold the iron horizontally over the sink (Fig. 8).6. Boiling water and steam will now be ejected from the holes in the soleplate. The impurities and scale are washed away with it. 7. Move the iron back and forth as this happens.8. If there is any water left in the water tank after the iron stops steaming, just empty the remaining water in a sink following the instructions for emptying the iron. 9.Turn the variable steam control dial to the “0” position when the water tank is empty.10.Place the iron back upright on its heel to cool down before storing.
Nov 23, 2008 | Euro-Pro Shark GI490 Iron
Taylormade r7 Draw Fairway Woods Logo
494 people viewed this question
Top Taylormade Sport & Outdoor - Others Experts
Are you a Taylormade Sport and Outdoor - Other Expert? Answer questions, earn points and help others
