Question about Cameras
My camera is the fe-370 8 mega pixal. The permanent rechargable battery is fine. Camera wont turn on. Zoom lens is stuck on the on position. I think I might have gotten it wet. It just won't turn on now
  • 919 Answers
SOURCE: need opeion of FE-230 versus FE 370
http://www.dpreview.com/reviews/compare_post.asp?method=sidebyside&cameras=oly_fe230%2Coly_fe370&show=all
This is a link to a website that allows you to compare the two cameras side by side.
Posted on Apr 21, 2009
  • 919 Answers
SOURCE: olympus fe 370 xd card 2gb formatted memory
As long as the xD card was not formatted it is possible to recover the images that were accidently erased,lost or corrupted. You can go to the following website link and download an image recovery software program that is free of charge. http://www.z-a-recovery.com/ You want to download a program called Zero Assumption Recovery. It is a very simple program to use and many people have had much success in recovering lost images. Data recovery is a booming industry, and many appropriate services and software can be found by searching regional phone and business directories or the Internet for terms such as "image recovery" or "data recovery".
Posted on Jun 10, 2009
iwctoys
  • 126 Answers
SOURCE: FE-280 Lens Blurry Photos and no zoom turns off
You have a bad lens. Unless the camera is in warranty the cost of repairing the lens is higher than the value of your camera. The strange noise you hear is the lens motor trying to move the lens. One solution is to blow compressed air around the lens. Sometimes dust and dirt may jam the lens.
Posted on Jul 02, 2009
  • 11967 Answers
SOURCE: lens is stuck in full zoom position Olympus 7010 camera
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 10, 2009
  • 11967 Answers
SOURCE: camera will not close proper;y
Posted on Jan 18, 2010
Hx-1 zoom lens stuck in extended position
And you are sure, the battery does have enough power? because that could have caused the problem in the first place. But if it has enough power, you should check if anything could block the free movement of the lens barrel. Did you drop the camera, or bumped to anything, while the lens was out? When you don't see any damage on the outside, still it could be some damage on the inside, or a motor that won't work.
I should try to recharge the battery, and if after replacing the battery, the lens won't move, I should visit a service centre, or if a good photo shop is close by I would ask there with the camera in my hand, what they think of the problem.
Feb 08, 2014 | Sony Cyber-shot DSC-HX1 Digital Camera
Camera wont power up,zoom lens not moving
It may be problem with your battery, Please check by recharging or replacing.
May 30, 2011 | Olympus FE-230 Digital Camera
Camera stuck with lens out & wont turn on =/
This happens with many cameras, whatever you do, do not force the lens back. You will see this as a suggestion on some blogs. Doing it might further damage the camera lens and other parts.
Here is a repair place that is very reliable: http://www.teleplancamerarepair.com/Olympus_FE_FE-370
WHen sending it in make sure you cushion it so it doesn't get worse when shipping.
Jul 04, 2010 | Olympus FE-370 Digital Camera
My camera is stuck open and wont turn off or turn
i have the same problem. It does'nt work. Any suggestions ?
Apr 26, 2010 | Olympus FE-200 Digital Camera
My batteries run out on my samsung d1070 camera and now the zoom is stuck and the camera wont turn on it just beeps
I suggest that you place the camera in a safe place ware the extended lens will not be damaged, than remove and recharge the battery. After replacing the battery, the lens should automatically retract and you should be good to go. Hope that this helps, God bless...
Aug 16, 2009 | Cameras
Lens stuck in out position, screen shows zoom error. How can I fix the problem?
just take out the battery ....charge it ...and put it back....switch off and switch on the camera once....should work fine
May 15, 2009 | Fuji FinePix A345 Digital Camera
Fe-340 wont turn on
If the lens is stuck out, that either means impact or it got squished and messed up the lens mechanism. You can have that repaired.
Apr 20, 2009 | Olympus FE-340 Digital Camera
Same problem
your batteries are dead.
Oct 27, 2007 | Samsung Digimax S500 Digital Camera
Zoom lens
Oh I'd love to be able to see this one. OH well. What batteries are you using? If they are ordinary alkaline, then you should get a set of NiMH rechargable batteries. (As strong as you can find) If the problem continues, taale the camera into Nikon and send your friend the bill.
Apr 01, 2007 | Samsung Digimax A400 Digital Camera
Cameras Logo
15 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
