Question about Motorola Mobility i776 Cell Phone
I776w call connection
When dialing either from contact list or direct dialing calls don't connect
What is fixed dailing number
If you turn on fixed dialing, you can only make calls to contacts that appear in your fixed dialing list.
You can make an emergency call when fixed dialing is turned on, even if the emergency number does not appear in your fixed dialing list.
If your wireless service plan includes SMS text messaging, you can also send SMS text messages to contacts that appear in your fixed dialing list.
Feb 24, 2011 | Computers & Internet
How do you set up speed dial on the LG OPTIMUS cell phone?
From the LG Optimus S Manual:
Assigning Direct Dialing Numbers
Speed dialing, as available in other feature phones, is
not available. However, you are able to directly save a
contact to your Home screen.
To set a contact as Direct dial:
1. Press (Home Key) >(Menu Key) > Add > Shortcuts > Direct dial.
2. Tap a contact from your Contact List. The contact
will be shown on the Home screen.
Direct Dial-
Simply tap the contact on the Home screen.
Jan 04, 2011 | LG Cell Phones
I have fax problem in my multi-function panasonic printer machine, all the power and rest functions are working other than fax, I am not getting the line dial tone when pressing monitor even the faxline is...
See Page 72 of the User Manual available here:
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Multifunction-Printers/How-To-Guides/model.KX-FLB801.H#ts
I cannot hear a dial tone.
The telephone line cord is connected to the [EXT] jack on the unit. Connect to the [LINE] jack (page 21).
L If you use a splitter/coupler to connect the unit, remove the splitter/coupler and connect the unit to the wall jack directly. If the unit operates properly, check the splitter/coupler.
L Disconnect the unit from the telephone line and connect a known working telephone. If the working telephone operates properly, contact our service personnel to have the unit repaired. If the
working telephone does not operate properly, contact your telephone company.
L The power cord or telephone line cord is not connected. Check the connections.
L If you connected the unit through a computer modem, connect the unit directly to a telephone line jack.
I cannot make calls. L The dialing mode setting may be wrong. Change the setting (feature #120 on page 22).
The unit does not ring. L The ringer volume is turned OFF. Adjust it (page 23).
Hope this is helpful. ;)
Dec 10, 2010 | Panasonic KX-FLB801 All-In-One Laser...
How do I get an extension on the main console to go directly to voice mail.
Hello Friend,
Click on this link(it may take few minutes to load according to Connection speed) and you will get Helping Guide for your Product...If you want to get Feature Codes ,then go to Page 9.OR to Call directly to another User's Voice mail/Transfer a Call directly to another User's Voice mail-See Page 13 for Detailed Information.
  • Press programmed Direct Voice Mail Button/Press Feature Button and Select Direct VM[DrcVM] OR Dial 56
  • Dial the Extension whose voice mail you want to Call/Transfer a Call;you can Use Programmed AUTO DIAL Button OR a Directory Listing too(See Page 11,14)
There is Possible to just Click on the Index data as you need... Hope This Lead you better Conclusion....Thanks for Contacting FixYa...
May 27, 2010 | Lucent Merlin Legend MLX-20L Phone
I have i-mate jama 8050, i can't make call from my mobile,my mobile can call only the contacts which are saved in sim,but not calling on the number which is not in contacts list, please help me,
Your mobile has been programmed to only make calls from your contacts. This is controlled in your settings menu under 'Fixed Dial'. (or similar command). You will need to change this setting.
I do not have a copy of the user guide for your phone but for most phones these are the directions:
When you turn on fixed dialing, you
can call only numbers stored in the
fixed dial list.
Turn fixed dialing on or off:
- > Settings > Security > Fixed Dial
Use the fixed dial list:
- > Settings > Tools > Dialing Services
> Fixed Dial
Jan 26, 2010 | i-mate Jama 101 Smartphone
Unable to dial directly from contact list
Turned the phone off and on again. Problem solved!
Nov 22, 2009 | Pantech Cell Phones
How do I delete contacts from my motorola i776w?
1. scroll down to the contact you want to delete.
2. press the menu button (it has a list on it)
3. scroll down to 'delete contact.' Press OK, then 'Yes'.
Oct 03, 2009 | Motorola Mobility i776 Cell Phone
When i dial a phone number from my contacts list it puts +86 in front of the number and wont connect
Hello, +86 is the extension to call in China!
You probably have to change your country code's setting for outgoing calls,
Can you check you rsettings here:
- Open Phone Log Screen
- Click menu "Options".
- Click Smart Dial;
And in general all your outgoing call settings related to region
Hope this helps
Jun 30, 2009 | RIM BlackBerry Curve 8310 Smartphone
Outgoing call does not connect when I dial the number
depends on the telephone exchange . Suggest switching to Tone signalling . MTDF - https://en.wikipedia.org/wiki/Pulse_dialing
Old technology- Pulse or Decadic Signalling - the line is broken by a relay contact or if even older a rotary dial manual switch contact - Dial a 9 you would break the line connection 9 times and send nine pulses.
Tone sends two frequency tones that encode the number that you selected and is a much faster dialing system and more modern method.
Oct 16, 2017 | GE 27906 Cordless Phone
How to transfer a call on Nortel Networks M3904
Use the Transfer feature to redirect a call to the appropriate person.
To use the Transfer feature to direct a call to a third party:
To return to the original call, if the transfer is incomplete:
1. Press the Transfer soft key. The other
party is on hold and a dial tone sounds.
The LCD indicator light flashes steadily.
2. Dial the DN to which the call is to be
transferred or use Personal Directory,
Redial List
, or Callers List to select a
number to dial.
3. When that number rings or a person
answers, press the Transfer soft key to
connect the calling party.
If the person called is not available,
press the line (DN) key (next to the LCD
indicator) to reconnect to the original
call.
Jun 23, 2009 | Nortel 2002 IP Phone
Motorola Mobility i776 Cell Phone Logo
64 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
