Question about Sanyo STW0923H2 Air Conditioner Heat Pump
THE BOTTOM IS FULL W/WATER DONT KNOW IF THERE IS A DRAIN AND WERE IT IS THINKING ITS CLOGED WATER DRIPS ON FLOOR WHEN AIR CONDITIONER IS ON
    Problem Solver:
  • 4 Answers
I could not understand your problem. kindly write down more clearly
Regards
Usman
Posted on Oct 02, 2009
Summer rite window air conditioner
if its driping on the floor then yeah a pan is good all aircons have a drain cause they create water of the coil
Jun 29, 2013 | Heating & Cooling
Unit is leaking water from somewhere
Upper drip pan drains clogged, water overflowing onto the floor.
Remove the rear cover of the unit and clean it thoroughly wit a vacuum. Let the unit fully defrost. Use a can of Air duster (for pc's) with the little hose on to clear the drain holes in the upper drip tray. Clean dirty evaporator fins with windex and toothbrush, flush with water. Excess condensate should now drain into the bottom tank instead of overflowing ontot he ground. Be sure to drain the bottom tank thoroughly. With the unit cleaned it should now vent condensate out the warm air duct rather than letting it build up in the unit.
Jul 06, 2012 | Windchaser PAC9 Air Conditioner
I own 2 Haier air conditioners. Same model number, purchased at the same time. Plugged them in yesterday and one is collecting water in the bottom and shuts off. The only way to get it to come back on is...
Condensation occurs when warm, humid air is pulled across a cold fins of an air conditioner and blown out the front as cool, dry air.
What is happening with your air conditioner sounds to be normal operation - here's why:
The condensate usually drips onto the ground from traditional window air conditioner units or through a pipe to the ground from remote air handlers of split systems. Since yours has no place to drain away into soil or waste pipe, it is collected in a compartment that must be emptied, just like a dehumidifier. When the compartment is full, the unit shuts off - otherwise the compartment would overflow on the the flooring or carpet. This could be a very expensive repair if hardwood floors were damaged or carpeting were to become moldy. Even more so if the the space under yours were finished - like an apartment building or if you used this on the second floor of your home - and damage to the ceiling below were damaged.
You could operate the device if it were connected by a hose to a drain at or below the bottom of the connection point (a floor drain, shower drain, etc.) or if the unit were placed on a counter top and allowed to drain into a sink or other drain / waste pipe below the the hose connection point. The hose must not get higher than the connection point at the drain plug on the air conditioner to work properly.
I hope this helps and good luck.
Apr 25, 2011 | Haier HPR10XC6 Portable Air Conditioner
What could be wrong with my aircon unit? Water dripping sound
Your coils need cleaned, and change the filter too. make sure drain is not cloged also.
Jul 04, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Water leaks out all over the floor from the window air conditioner
you need to make sure of two things.
1) the AC is 'tilted backwards' just a little bit - to allow the water (condensate water from the evap coil) to drip from the bottom of the AC - out the 'condensate drain hole' - sometimes into a drain hose (usually rubber) or just through the hole to somewhere outside where it doesn't hurt anything.
2) make sure the - condensate drain hole, and drain hose - (if one is used) is clear and not clogged up - to allow the condensate water to drain.
hope this helps
Jun 26, 2010 | Haier hwr10xc6 Air Conditioner
Some water dripping on the bottom and freezes onthe bottom of the freezer and sometimes theres water on the floor.
The freezer drain is cloged.Drain is in the bottom of the freezer floor in the back you may have to remove back panel. Run wire or somthing down drain tube to clear clog.
May 16, 2010 | Freezers
SANYO MODEL STWO923H1 CANT FIND THE PAN DRAIN
find the drain outlet and use a wet vac to extracate the water from the pan Slime has appearently clogged the drainage tube Good Luck
Dave
Oct 02, 2009 | Heating & Cooling
Water building up on ps side floor board in 1996 jgc
Your water problem is caused by a cloged a/c drain. Under the hood on the pass. side firewall you can see a small tube coming out of the firewall (look towards the bottom). Take a coat hanger and try to clear out the drain, this will solve the problem. You should get a good amount of water come out.
Mar 09, 2009 | 1996 Jeep Grand Cherokee
Water leaking out on floor
there is a drain hole in the back/bottom of the freezer, check if the fridge is connected to a drain and water drains into the hole, looks as if it is cloged.that is a drain. Use a turkey baster with hot (not boiling) water to flush out the drain tube until water will flow out into the drain pan under the refrigerator. (where the air blown over it will cause it to evaporate)
Feb 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Goldstar Air conditioner
Tilt the unit toward the window opening and clear the drain holes in the back and bottom of the unit from debris.
Jun 09, 2008 | Goodman CKL36AR36 Air Conditioner
Sanyo STW0923H2 Air Conditioner Heat Pump Logo
128 people viewed this question
Top Sanyo Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Tim Whalen
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
