Question about Samsung Sway SCH-U650 Cell Phone
Plaid screen ive also had this problem this is my second phone. try warming up the phone sometimes that helps and also turn it off plug it in and then turn it on and see if that helps. also try to camera that also works for me. i love phone, hate that the screen goes out- GOOD LUCK!!!!
Dryer timer works perfectly but the dryer itself wont turn on. Ive tried unplugging and plugging back in, tried circuit breakers, none of that makes it turn on. Lint screen is clean. What do i do?
try unplugging, while unplugged hold in on button for 15 seconds, then plug back in and see if that works. sometimes on some models, it does a reset
Aug 27, 2015 | Dryers
What is wrong with my Ipod 2? My son was waiting on a game to load and the screen went blank but it still lights up? It seems to be stuck on this screen. Can you help?
did you try to switch it of an then on?
Pressing the button on top of the screen on the left side for a few seconds till it says slide to switch of. Slide and wait till everything is dark (half a minute) Den switch on again, by pressing the same button sir again a few seconds. Wait again about half a minute.
May 22, 2014 | Apple iPod Touch 2 8GB 32GB 64GB Checkers...
Why wont my htc merge turn on?
Have you tired leaving it to charge overnight ? You could remove the battery for a while then try plugging it in and try to turn it on.
Nov 18, 2012 | HTC Merge 6325 Plastic Case - Plaid Design...
My iphone turned itself off and wont turn on, ive had it on charge but still wont turn on
try holding down the home and sleep/wake buttons until you see the apple logo cycle.
sometimes it has to be held for longer than 30 seconds.
Sep 12, 2010 | Apple iPhone Smartphone
My insignia flat screen has turned colors and bad focus. Almost like tartan plaid on top of the screen. Not an input issue, happens on all inputs
try to see if not the input but the setup on like 720p 1080i 1080p sometimes u can change the setup and it resets that happened to my westinghouse 37in
Dec 11, 2009 | Insignia 42" LCD Flat-Panel HDTV
My gps icon keeps blinking on g1
In home screen, press menu, and press settings. Press Security & location. Uncheck "Use wireless networks," and check "Enable GPS satellites." GPS should now work.
Sep 18, 2009 | HTC G1
Tv gone black and white
try letting it run for a little while sometimes it just needs time to warm up after not being used for awhile. unfortuntly i am not completly sure but i will look up more information on this.
Jan 03, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Nothing but plaid on my laptop
This may be a screen problem. In order to narrow it down, plug in an external monitor. If the monitor works correctly, then it's a problem with your screen. Somethings that you can try are: With the external monitor, go in and unistall the monitor drivers, disconnect the external, and restart the laptop. Check the connections no the screen. If it's not the driver or connections, then it will be the screen and will need replacing.
Jun 24, 2008 | Dell Latitude D610 Notebook
Lines through screen HELP!!!
You need reinstall the phone software it may be corrupted.............
May 26, 2008 | LG VX9400 Cellular Phone
Samsung Sway SCH-U650 Cell Phone Logo
279 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
