Question about HP Office Equipment & Supplies
H p copier wont grab have to assist by pushing the sheet inward.
I have to assist by pushing the sheet inward. seems like just a tension adjustment ?
    President:
  • HP Master
  • 990 Answers
Hello sir; You need to replace paper pick-up roller instead to push paper inward.
Posted on Oct 02, 2009
I recently switched to a Deskjet 5440 from a Dj 6980. The 5440 cannot seem to feed through envelopes, cards, and it won't properly feed the Avery 8.5x11 business card sheet. I had no problem with the 6980...
is there a wheel that comes down when you are calling for paper? ther is one that grabs the paper and transports it to the printer rollers. one way is to print a document and when it feeds push the paper into the unit and see if it grabs it
Mar 09, 2011 | HP Deskjet 5440 InkJet Photo Printer
How to put on serpentine belt
The tools required are:
1/2-inch drive ratchet
2 - 1/2-inch drive 8-inch extensions
1/2-inch drive socket set
Please follow these steps to replace the serpentine belt on your 1999 Chrysler 300M:
1. Open the hood and prop it in place.
2. Locate the serpentine belt adjustable idler pulley on the front of the engine. This adjustable idler pulley will be closest to the top of the engine. Position a metric socket onto the ratchet and loosen the bolt in the center of the serpentine belt idler pulley.
3. Now please loosen the push bolt on the side of the idler pulley. It is a 15mm size and the push bolt on the side of the tensioner is 13mm. Pull off the old belt.
4. Loosen the tensioner pulley for the AC belt. The same steps need to be followed for this as well.
5. Next slip the AC belt on the back of the crank pulley and route it as per the diagram under the hood.
6. Now you need to tighten up the idler pully and the push bolt until the belt play is within factory specifications, then tighten the hub bolt in the center of the pulley as well.
7. The same thing needs to be done for the serpentine belt as well. Just ensure that you tighten up the bolts and have the specified play in the belt. Check the belt tension by pushing inward on the belt.
8. Crank the vehicle for about 15-20 seconds. Then turn it off and again check the tension in the belt. Adjust as necessary. You need to have about half an inch of play in the belt.
If this doesn't work for you or in case you need any further assistance, please comment and let me know, and I will be happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this solution.
Thank you.
Jan 13, 2011 | 1999 Chrysler 300M
SAYS PAPER TO NARROW
You can adjust the manual paper width levers by grabbing the levels and pushing inward for smaller sized paper or outward for larger sized paper.
Jan 08, 2011 | HP PSC 2210 All-In-One InkJet Printer
I wont to calibrate the copier, but when i push the "sheet 1" bottom to print the first graduation print, this message apear "the operation has been "cleared" ? Sometimes its print the first pages, but...
You need to have Leter size or 11 x 17 in one of your paper trays. You need to go to additional funcations and go to adjustment & cleaning. Next go to Auto gradation adjust and choose a Full adjust and then follow the instruction. You will have to do this three times... Just follow the display and you should have No problem... Good Luck
Sep 22, 2010 | Canon imageRUNNER C3200 Copier
After a few months in storage, my saw will start, but the chain seems stuck - I can['t move it with my fingers, and when I gas up the engine, the chain doesn't move & the engine stalls. There's no...
Release the chain tension adjuster and push the bar inward to make sure it moves. This is an auto-set tension adjustment and should set itself so that the chain can be be moved by hand. The chain oil on the bar may have gelled enough to prevent chain movement. A spray of WD-40 around the chain perrimeter would probably loosen the chain as well. Hope this helps!
Aug 15, 2010 | Husqvarna 450 e-series 18" Chain Saw
How do I change the alternator belt on my1990 vw diesel jetta
as the alternator IS the adjuster for the tension of the belt,it is a simple task of undoing the alternator bolts/nuts and pushing it inwards to fit belt,then pull it outward to tension belt to correct tension...
Aug 14, 2010 | 1990 Volkswagen Jetta
How do I get my disc out of my Vivitar Vivicam 3615? I know where it is but can't seem to get the disc out of the camera.
If it is like most digital cameras nowadays, you will need to push the card inward. You will feel spring down, click, and then when you release it, it should come out slightly extended, enough so you can grab it with your fingers.
To insert, just place the card back in, push it inwards until the click, and then it will lock into place.
Good luck.
Jul 14, 2010 | Vivitar ViviCam 3615 Digital Camera
Feeder wont grab sheets
open the cover of the document feeder you there will find two rollers (blue and grey) clean these rollers with a cloth dampened with nail polish remover
Oct 06, 2009 | HP Laserjet M2727nf Multifunction Printer
Brother copier paper feed grabs 2-5 sheets at a
check the feeed rollers ateh seperation roller the one that seperates the pages is worn.. it has proberly worn the tread and if its sn=mooth or worn it wont stop multi feed
Jul 29, 2009 | Office Equipment & Supplies
My MP510 grabs way to many sheets of paper.
hi i am a Canon certified repair tech for this printer. it seems that your problem is due to a broken sheet feeder unit. what i ahve seem with some new machines is that a plastic shaft that controls ther seperation of the pages breaks. most of these problems occurs with new machine because they are shipped from place to place. if the unit is under a year old it is still under warrenty and can be brought to or shipped to a repair center. even if its not under warrenty any longer you should still call Canon at 1-800-OK-CANON and complain that it has been doing it since you bought it and they will locate the nearest repair center to your location for you. hope this helps.
Jan 01, 2008 | Canon PIXMA MP510 All-In-One InkJet...
21 people viewed this question
Seeker5211
Seeker5211
