Question about LG RUMOR Cellular Phone
Rumor 2 keyguard - locked out
Rumor 2 keyguard - daughter used it - placed keyguard code - locked out of phone use
Blue lg rumor 2 security code forgot
Menu > Settings > More > Security > Enter Lock Code > Delete/Reset > Reset Phone
Where the default lock code is the last four Numbers associated with the phone.
Jan 02, 2012 | LG Rumor 2 Cell Phone
Tip
LG RUMOR lock code
if your phone is locked and you dont know the lock code, enter the last four digits of your wireless number. my daughter locked her's by pressing and holding the #key. she freaked because she didnt know the lock code. i entered the last four and unlocked phone.
on Jan 09, 2010 | Cell Phones
I put a lock code now I forgot. It and cantget in my phone.
Messages & Display Issues: The display on my phone reads "Locked" or "Keyguard"
  • If you see the word "Keyguard" on the display of your Kyocera phone, you may have activated the keyguard feature. Press button below "Keyguard," then press 123 or the "OK" key to unlock the Keyguard feature. The phone will display "Keyguard Disabled."
  • Some Kyocera phones also have the phone lock feature available. If the phone lock was activated, the default lock code is 0-0-0-0 (4 zeros). When your handset is programmed with a mobile number by your Mobile Service Provider, the default lock code will change to the last 4-digits of your mobile number. To change your handset lock code, you must go to the Security menu, then select Menu > Settings > Security > Current 4-digit lock code.
  • May 03, 2011 | Kyocera Jax Cell Phone
    Forgot my security code for keyguard lock on my nokia 5130-2 xpres music
    Use the default code which is 12345 or 00000, but if it does not work then you will need to send me the imei of the phone so i can help you out with a master code.
    thanks.
    Feb 21, 2011 | Nokia 5130 XpressMusic Red Unlocked Import...
    My LG Rumor 2 is block with a 4 number security code that my daughter wrote and does not remember, how can I unblock it.
    once i faced a similar problem with my motorola mobil. i got it to a mobile service expert and he used some software and found it out. some experts flash the phone and restore the phone to factory conditions. these are the options.
    Nov 04, 2010 | LG Rumor 2 Cell Phone
    Nokia 6301b Security Keyguard code unlock
    You can contact Your local cell phone shop that sells Nokia they will be able to tell you how to unlock the phone. If they can't do it over the phone it can be reset by a phone tech,
    Aug 06, 2009 | Nokia 1100
    Helo sir?
    hi u cant reset ur keyguard code again once u have entered a particular code... so better keep ur keyguard off... u can make phone lock
    Jan 24, 2009 | LG RUMOR Cellular Phone
    Changed keyguard code, need to reset it
    Try this 277634#*# it should open a hidden "engineering" menu and use the master reset there it will clear all pins and security code to default. Once done the security code is 0000
    Jan 07, 2009 | LG RUMOR Cellular Phone
    Envy 2 dials phone numbers accidentally- need to set key guard
    On the front keypad, press the ok button until you have the option to select contact list. Scroll down that list until you see keyguard settings. Press ok to enter keyguard settings and then go to option 2 - unlock options. Select two step unlock. This will force the user to press "ok" and then "clr" in order to dial out. This has resolved the problem for me...Good luck.
    Dec 03, 2008 | LG enV VX9900 Cellular Phone
    Keyguard
    if you just need to lock the phone temporarily just hold the pound button for about 3 seconds and it will turn on key guard without changing settings.
    Sep 19, 2008 | LG enV VX9900 Cellular Phone
    LG RUMOR Cellular Phone Logo
    387 people viewed this question
    Top LG Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Are you a LG Cell Phone Expert? Answer questions, earn points and help others
