Question about Cell Phones
Battery wont charge temp error charging stop message samsung sph-m320 phone
PHONE DOES NOT HOLD A CHARGE, HAVE TO CHARGE EVERYDAY
If your phone is not holding a charge unfortunately you will need to get a battery replacement for it. If the phone is still under warranty you can contact Samsung directly for a replacement free of charge. If not, you may look for a new battery on sites such as Ebay or Newegg.com
Click here for samsung support
Regards,
G33k
May 12, 2011 | Samsung M320 Cell Phone
WHERE DO I BUY A SAMSUNG M320
http://www.samsung.com/us/mobile/cell-phones/SPH-M320ZSASPR-buy go here type in your zip code and a list of local retailers should pop up
Feb 03, 2011 | Samsung M320 Cell Phone
When trying to charge samsung sph-m320 phone display says no battery hooked up when there is a battery in phone. It is a replacement battery from a reputable reseller.
Check to make sure the battery is hooked up correctly and it is properly seated. If this fails then it indicates the detection circuits in the phone are not functioning, a new replacement is recommended.
Jan 01, 2011 | Samsung Lands Phones
Samsung c3053 won't turn on...
This is because of the battery problem
your mobile battery will not charge even you put in charge,it will show charging symbol then it turns off...
you have to chage the battery.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 25, 2010 | Samsung UpStage SPH-m620 Cellular Phone
Hey my samsung sph-m620 is only a year old and will only work while being charged .. it wont stay on otherwise! Does this mean my battery is dead if so can it be fixed and how much will it coast to fix it?
Well my UpStage Samsung only stays on for a few sec then cut off
and on again & says it's charging....HELP what going on with
my phone,and can it be fixed?
Thanks,Deborah
Feb 17, 2010 | Samsung UpStage SPH-m620 Cellular Phone
Samsung M320 wont pair with ilove i316 bluetooth
Try removing the battery and re-pairing after reinstalling the battery and turning on the Samsung M320.
I've written a short article on other bluetooth troubleshooting here: http://yourmonstersofmobile.com/how_to_for_cell_phones/pairing_your_bluetooth.html
Aug 09, 2009 | Samsung M320 Cell Phone
Charging the battery on Samsung Upstage sph-m620.
Well if it's new, then I would take it back to the store from where you bought it. It will be under warranty so, if something is wrong you should be able to get it swapped out with a working one.
Sep 12, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Wont turn on
The most likely problem is your battery. Unfortunately, it appears you battery needs to be replaced at this point.
KJ
Jun 23, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Phone wont charge (Samsung E635)
When I plug the charger into the phone it shows "charging' for a few seconds then says "pause by temp" and stops charging.
May 09, 2008 | GPS
Possible battery issues
if the samsumg unit hang on.... reprogrammed the unit to refresh the memory of the unit... it always happen when the memory of the phone is almost used...to much file or phothos or videos been save....another option if wont charge try to check your charger if okay ccheck your battery , if you notice your battery has bloated size then replaced it...also try look your battery locks if still fit to the battery terminal..
Feb 23, 2008 | Samsung SPH-a620/VGA1000
Cell Phones Logo
591 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
