Question about Hunter 52" Ceiling Fan With Light And Remote Control
We have a ceiling fan, and all the sudden the fan won't turn on at all. We have a remote for it, my husband checked the wireing and it is getting power. Ehat could be the problem. It was working, now it's not...
    Sergeant:
  • 347 Answers
Check battery of remote control unit
Posted on Oct 02, 2009
My Hunter Douglas ceiling fan/light operates with a wall remote. It suddenly stopped working. When I tried out putting in a new battery the fan still does not work but the light turns on bright briefly,...
rats have gotten into your electrical wirings, probably gnawed the wires to fan totally and partially on the lights, might still find the dead rat on the wirings.
Mar 14, 2014 | Televison & Video
My Hampton Bay Brookedale ceiling fan worked fine for a while. Went to turn it on the other day and won't work. Ceiling fan remote seems to work (light goes on when buttons pressed) but fan or l
The light on the remote is a battery light. First mistake was buying a store brand fan which are mostly low-end parts. Try adding a different remote w/receiver.
Mar 02, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
My control won't activate the light on my Hunter fan. The light comes on via pull chain fine, and the control works the 3 speeds on the fan, but the light won't respond.
Check the wiring on your receiver to make sure the light wire is connected.You have to have the light on with the pull chain and then use the remote to turn it on/off.
Jan 06, 2013 | Hunter 52" Ceiling Fan With Light And...
Emerson ceiling fan remote won't work
Check the remote control for its infrared emission. Check its battery contacts for any rust or dust. Check it with fresh batteries.
Nov 05, 2012 | Emerson 44 Curva Sky Ceiling Fan In...
Ceiling fan won't turn on with remote or wall switch
it is a new fan? If so electrician needed..
If not try replacing batteries in remote.... its happened to me...
Oct 31, 2012 | Craftmade International Dryers
I have the Hampton Bay Ceiling Fan and Remote. Model UC7083T. My son was playing with the battery cover and i think he moved the switches. The problem is i don't know what their original position was....
You have to go inside the actual ceiling fan. If you look on the part right above the light, there should be 3 or 4 screws in the side, connecting the light setup to the body of the fan. Unscrew those screws and disconnect the wiring harness. Inside the now open fan wiring, you should see a little box, that is the remote receiver. Either on one of the sides of the box, or inside that box will be the code. It will look just like the code switches on the remote. Make sure they match up, clip the wiring harness for the light and the fan back together, screw those screws back in, and you should be good to go.
May 09, 2011 | Hampton Bay 24002 Ceiling Fan
Hunter fan wiring
sounds like one of your connections is loose. Im not sure if i completely understand your description of how you re-hoked up your fan. Please tell me how many wires your fan has and colors and how many wires you have on the sensor remote. (lots of times if you draw a wiring diagram on paper you can figure it out) Basically you should have power coming from ceiling to remote sensor. Then the remote sensor should throw the power to either the fan or the light, so there should be two seperate leads coming out of the remote sensor to control either the fan or the light independantly.
Oct 06, 2009 | Hunter Dryers
Remote Control Ceiling Fan Problem
OK, first off, there have been some problems with those remote units. That said, let me tell you what the wires should be doing and you can see if that is happening.
Normally they take a "Hot Wire" and attach it to the white wire that goes to the switch. It is hooked through the switch to the black wire to bring the "Hot" back up to the light/fan. The whites in the ceiling box are the neutral. A "Hot" and a neutral are required to make anything work. The copper is a ground, or added safety. It usually is attached to the same spot as the neutral in the breaker box, so it is not a big deal. If you have a hot going to the switch which works as the off/on valve, and back up to the box. The hot and a neutral make what ever you hook it to work. Now, if you have a remote, it uses a connection at ceiling box to turn it on and off. You can have a switch to turn the whole thing off and on, but if that switch is on, the remote is just a different way to turn it off.
If you have a way for the electricity to make the big circle, it should work, unless a part some where is not letting it through. I imagine in your situation it is the remote.
If this is new, you may want to see if you can get another, and take the remote part out (Up in the fan) and replace it. You would not have to re-assemble the whole fan. I have replaced several of these lately, and even put a different kind of remote on a few.
Nov 30, 2008 | Oasis Hunter 54' Ceiling Fan
Remote Code
I had the same problem. In my case it was easy to spot. Thehe battery cover of the remote was removed by my little    girls and she was able to tinker with the dip switch inside the remote. So  i played with them. I gues the dafault is all switches up and it worked. Hope it it helps
Oct 18, 2007 | Hampton Bay 24002 Ceiling Fan
Dryers Logo
112 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
