Question about HP Business Notebook NX9110 Notebook
Lost dell config password - HP Business Notebook NX9110 Notebook
  • Anonymous Mar 05, 2009
    forgot my config password
    Novelist:
  • 188 Answers
What are you asking about? a software program or bios password or what?
Posted on Dec 21, 2007
Tip
Cisco 3925 Router Password Recovery
TheCisco 3925 router is part of a family of networking equipment produced byCisco, which has been a network equipment giant for many years. Used 3925routers are available on the Internet at reasonable prices, so acquiring one isnot difficult. However, if the password is unknown or lost, reconfiguration isimpossible until the password is reset or recovered.
Cisco has built in aprocedure for rescuing lost or forgotten passwords or entering new passwords.
ThingsYou'll Need: Serial to RJ-45 cable;Terminal emulation software
Instructions
1.Connect your computer to the router with the blue serial-to-RJ-45 cable thatcame with the router.
The 9-pin D-shell end connects to your computer's serialport, while the RJ-45 end connects to the console jack on the router.
The RJ-45end resembles a slightly larger telephone jack connector.
2.Turn on your computer and establish a terminal session to the 3925. You can use any terminal emulator, and many are freely available on the Internet.
Configure the session settings as follows:9600baud8data bitsNoparity1stop nonflowering controllable router's power cable into an electrical outlet, and as the 3925 boots, you should see the Cisco boot messages.
If you don't see any output on your computer's terminal session, check your settings on the session and restart itif necessary.
Press "Break" within 30 seconds of powering on the router to enter rommon (rom monitor) mode.
3.Type "confreg 0x2142" and press "Enter" at the "rommon1>" prompt. This will cause the router to boot from its internal flashmemory without loading the configuration into memory.
At the following"rommon 2>" prompt, type "reset" and press"Enter."
This will cause the router to reload and ignore thepreviously saved configuration file.
4.Respond "no" and press "Enter" when prompted for responsesto enter the initial dialog or basic management setup.
Type "enable"and press "Enter" at the following "Router>" prompt.This will put you into enable mode and display the "Router#" prompts.Copy the non-volatile memory into memory with the "copy start up-config running-config" command, followed by the "Enter" key. Type"sho run" at the prompt and press "Enter" to display the current configuration, including the passwords, some of which may be encrypted.
5.Type "config t" at the prompt and press "Enter." At the"Router(config)#" prompt, type "enable secret <pswd>"-- where "pswd" is the password -- and press "Enter." Atthis point, your enable password is reset. Press "Ctrl" +"z" to return to the "Router#" prompt.
6.Type "config t" at the "Router#" prompts and presses"Enter." At the "Router(config)#" prompt, type"config-register 0x02102" and press "Enter" to reset theboot register to its normal setting. Press "Ctrl" + "z" toleave configuration mode. Type "copy running-config startup-config"and press "Enter" to save your changes. Reboot the router and youshould be able to login with your password.
on Sep 05, 2011 | Computers & Internet
How do i configure the switch to allow web access through the serial port
If you can't find the manual on the Dell web site, there is a copy at: http://www.manualowl.com/m/Dell/PowerConnect-3548/Manual/188907
Did you use the command: ip http server ? See page 501 in the manual.
I would not recommend setting up a network switch with password-free access to the internet. You should at the very least limit access to a small subset of IP addresses (e.g. your network group's machines). The best practice is to use ssh communications or https with the web browser, otherwise anyone with a well-placed sniffer can read your clear-text traffic.
Sep 19, 2012 | Dell PowerConnect 3548
Forgot password on dell laptop with windows 7?
emm, forgot Windows 7 password?
There are some methods for you to reset it, just follow the info and have a try
Option 1: Use a password reset disk to reset lost password if you have created one before forgtting the password.
requirement: USB flash drive or floppy
time: a few minutes
Note: This password reset disk can be only created when you can log on with the lost windows password.
Option 2: use a freeware to crack lost windows admin password, then you can get back the password, like Ophcrack
requirement: download Ophcrack live cd,
time: more than i hour
Option 3; a high efficient and easy-to-use low affordable shareware, like Windows Password Recovery Tool, which can reset windows 7 password quickly and successfully.
Requirement: a bootable CD/DVD or USB flash drive.
Time: within a few minutes.
Visit http://www.windowspasswordsrecovery.com
Step 1: Download and install Windows Password Recovery Tool in any available computer.
Step 2: Burn a bootable CD/DVD to remove lost Windows password. (or USB Flash drive)
Step 3: BIOS settings
Step 4: Recover forgotten Windows password with the burned CD/DVD (or USB Flash drive)
good luck ~
Dec 02, 2011 | Dell Inspiron N5030 Notebook PC
Catalyst 5505 password lost
restart in romon mode and change confreg to 0x2142 and restart...take config backup frm startup config and copy to running config
Aug 16, 2010 | Cisco Catalyst 5505
Its not the bios password but the config/admin
follow the steps below:
1) just remove the jumper and fix it again.
or
1) remove the battery and fix it again.
Mar 13, 2009 | Dell Latitude 100L Notebook
Change password on Dell TrueMobile 2300 router
Hi, logon to your router using IE or whatever browser. Then follow these steps and let me know.
You are prompted for a Username and Password.
Type the username: admin
Type the password: admin
Click the OK button.
The Dell TrueMobile Setup Page appears.
Click the Advanced Settings tab.
A note appears stating that Dell provides the advanced features for your convenience only. Dell technical support representatives can not support the configuration options in the Advanced Settings portion of the setup program.
Click the Administration Settings button on the left side of the page.
Put a check in the box to the left of the Change Your Password setting under the section of the page titled Password Settings.
Type the password that you want to use in the New Password field.
Retype your password in the Retype Password field.
Click the Submit button.
Another window appears stating You have successfully submitted the settings to this device!
Click the Save and Restart button.
Your new password will be saved into the router settings.
Nov 29, 2008 | Dell TrueMobile 2300 Router (000001)
DWA 552 and 2WIRE HP1000
you dont have router protected (is not yours anymore).to gain control again, you can rest config. but you need your router manual nerby, to help you config. a previous internet provider config. and so on. to reset router config, you press a reset button on the back, until the lights is off/red. then config the router on the router website( writen on botton with default user and passw.(user: admin passw: admin or password) the wan config, Wlan,...
(Use a wpa2/wep encrption level on Wlan config.)
Note: change all router passw every 30 days, or less if necessary.
Jul 24, 2008 | 2wire HomePortal 100W (1000-400026-000)...
LOST PASSWORD
there are programs like PC beginner which will enable u to see and change the password
Nov 21, 2007 | Microsoft Windows XP Professional With...
HP Business Notebook NX9110 Notebook Logo
77 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
