Question about Maytag Generic 30 in. Range Hood
Range Hood ductwork.
My home was built in the late 60's. My range hood may or may not have been installed when the house was built. Whoever installed the duct work frankly did a messy job of it. The ducting is vented all the way through the roof. The duct work passes through a hacked up hole in the top of the cabinet above the hood into the attic then outside. I can open the cabinet and easily see the ragged hole the duct goes through, and can even put my hand through the hole and into the attic if I wanted. Is there a way I can tighten up the area? I'm concerned that a) I'm losing heating and cooling through this hole into the attic and b) that critters could potentially make their way into the kitchen from the attic. I have no problem with the inside of the cabinet looking awful, but I'd feel a little better if there were less hole there. I've thought about using plumbing foam such as Great Stuff, but I don't know how much heat that product can tolerate. I do not want to unwittingly create a fire hazard. Can I use Great Stuff, or is there a better product for the job?
(Note: I had to choose something similar under "What product is it about?" because my model isn't listed. It's not really about the range hood itself, though. My range is: Air Care Range Hood Model AC 1270R.)
  • 10,865 Answers
I would use regular rolled insulation and stuff as much as you can into that space. It is fire proof so you need not worry. Next, use construction adhesive and strips of plywood or other thin wood to fill in the void with a frame.
get a constructioin adhesive that has instant grab like DAP, available at home depot and most hardware stores.
Posted on Oct 02, 2009
  • 80 Answers
The range hood will give off only minimal heat from cooking. You should be fine with what you are using.
If you read the directions on the can of great stuff it will tell you everything it can be used on and what the temperature rating is.
  • lilleyen Mar 06, 2011
    If I was facing the same problem I would determine the duct dimensions (round or rectangular), and stuff the gaps with insulation as previously suggested and then frame it either with wood to match the cabinets or painted to match the walls.
    If it's rectangular, simple wood moulding of some type will suffice with mitered corners.
    If it's round ducting, determine the size, cut a circle out of whatever material you are using to make a wooden ring, (or have someone make it for you), then with a very thin bladed, saw slice this in two so you can put it around the duct work up against the ceiling, and glue it back together again so it looks like one piece. This will cover up the ragged hole and the insulation so it looks like a properly finished project.
What product can I use to replace a down draft venting system from a Jenair range when I have to install a range hood above a new range and wish to vent down and out of my house in the same place of the...
Short answer is if you have the vents already in there is a product to make use of these. I would recommend talking to an appliance dealer for your options on this one. I am sure they would steer you in the right direction.
Mar 01, 2015 | Range Kleen For Whirlpool Jenair Ranges
How to change the light in technika range hood
Safety is important when is comes to replacing a light bulb of a range hood. The first thing to remember is to turn off power and allow lights to cool before proceeding.
home light
Jun 03, 2012 | Kitchen Ranges
The light diffuser cover is broken. The model number of the range hood is HO60488. The range hood dates back to possibly the late 1950's when the house was built.
When faced with the total unavailability of replacement parts, its time to get creative, and make your own diffuser cover. Flat ones
can be easily made - find anything plastic that's semi-translucent (like a plastic milk bottle), and cut it with a utility knife.
I have also used a utility knife to cut a polystyrene diffuser cover
originally intended for a 2-ft x 4-ft suspended ceiling fluorescent light fixture.
In case the diffuser cover you make wants to burn when placed close to a light bulb, replace the bulb with a CFL (compact fluorescent) bulb, which run MUCH cooler than incandescent light bulbs.
Old lampshades can be cut and used, but may need to be ironed flat. The major advantage of lampshade material is that
it can be folded over at the edge once or twice, which will fill space - and possibly hold the cover where a plastic sheet might be too loose.
You'll know that your efforts have met with success when you can easily remove your ne diffuser cover to replace the light bulb.
Feb 20, 2011 | Venmar Kitchen Ranges
In winter, cold air blows back down and out through the fan.
Either a backdraft damper was never installed in the ductwork or the damper is stuck open...
Has it always been this way?? If so then the damper probably was never installed and you will need to have one installed to stop the air...
If it was good at the beginning and now is not then the damper is stuck open...you will need to find it and then get it working agian...
The dampers often are right at the outlet of the hood...if you take down the hood it should be right there...
heatman101
Feb 11, 2011 | Broan-NuTone Best By Broan EB12 External...
Range hood blower motor - rangemaster
I'm not sure if it a regular home range hood but if it is. Check the price of a new one. A regular home range hood cost around $100.00 and a fan motor runs around the same. If it a commercial type is another story. If commercial Heritage Food Service Equipment will have the motor.
Oct 01, 2009 | Kitchen Ranges
Can this be installed over an island?
Bring a focal point to your kitchen by having an island range hood, combining function and elegant form. A suspended hood is also an efficient way to vent
grease, odors and smoke to the outside from a island stovetop while you cook. You can install an island range hood in just a few hours with the right tools
and knowledge.
1.Wear safety glasses and work gloves. Turn off the electricity to your kitchen at the circuit panel. Cover the circuit breaker with a piece of electrical
tape to prevent people from turning the on switch while you are at work.
2.Lay work drop cloths on your cooktop and floor to catch dust and debris. Mark the duct opening with a pencil in the ceiling, where the island hood will be
installed. Be sure the opening is centered directly above your cooktop. Cut the opening using a hacksaw.
3.Go up to the roof, using a cat's claw and hammer to remove stucco, tiles, sheathing and insulation to make way for the steel venting duct. Drop a
plumb bob down the roof, making sure the line is straight down for the ductwork.
4.Follow the manufacturer's instructions for locations, installing 2-by-2 wooden blocks in the ceiling to hold the ductwork hangers.
5.Install the venting duct from the outside of the home, down to the location of the exhaust vents on the island hood. The ducts should easily slip into each
other. Secure all the duct sections with duct sealing putty, using a putty knife.
6.Screw a roof cap on the end of the duct at the roof. Seal any openings or gaps where the roof, ceiling and duct meet with silicon sealant. Let the sealant
dry, then paint with colors matched to the surrounds.
7.Place your hood upside-down on the floor, with the fan and filter facing upward. Locate and unscrew the metal electrical box cover on the island range
hood, to expose the wiring
8.Install the hood cover to the load-bearing ceiling frame with the package hardware through the four inside mounting corner flanges on the cover.
9.Measure what will be the distance from the bottom of your hood to the cooktop; it should not exceed 30 inches for exhaust efficiency. Have a helper hold
the hood in place while you attach the hood on the hood cover using the included screws. Use a level be sure the hood is level as mounted.
10.Connect the electrical wiring by consulting the manufacturer's suggestions or hire an electrician if you are not familiar with house wiring. Tuck the wires neatly in the hood electrical box and then replace the cover, after connecting the hood wires to the wall wiring.
11.Remove the electrical tape on the circuit breaker, turn on the electricity to your kitchen and test your island range hood.
May 26, 2009 | KitchenAid KHVU781RSS Stainless Steel...
Fan switch not work - Viking 3048SS brand new range hood
There is the on off switch and the blower control that controls the speed of the fan. It is more than likley the blower control that would need replaced.
There could also be a wire disconnected in the hood.
Aug 19, 2008 | Viking VWH3048 Kitchen Hood
Broan fan cat h 500 housing 115v 60 c 1.5a lr 31619
Customer Service: 800-558-1711
Technical Support: 800-637-1453
Oct 13, 2007 | Broan-NuTone Best By Broan BER02IS 48"...
Maytag Generic 30 in. Range Hood Logo
372 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
