Question about Garden
Is it possible to start a featherlite plus weedeater with a drill
I have taken off the shaft and am able to get to the square shaped hole that would spin the shaft. can i put in a drill bit to start this?
  • 279 Answers
DO NOT DO THAT!!! If you are not able to repair your unit, buy a new one! Take it to a small engine clinic or something! Do not put yourself in danger....Lee
Posted on Oct 02, 2009
I have a featherlite simple 2 start weedeater 25cc
You need to check for fuel and fire first. Will it hit if you squirt a little carb cleaner down the carb?
Oct 15, 2014 | Garden
How can I start featherlite weedeater with poulan carburetor sst 25?
Your Poulan should have a green button on the side of it. Push and hold it. While most models have a green button, your may not. In that case, obtain the model number off the weedeater, go to Poulan.com/customer service and download the manual for your machine
Sep 01, 2014 | Poulan Recertified - Weed Eater...
Does poulan featherlite weedeater have a compression releif valve
It barely has a motor. No it has no need for compression relief.
Aug 11, 2012 | Poulan Featherlite Plus Gas Trimmer
My brother bought a Weedeater Featherlite Plus Fl26 and lost the operators manual. He says it is a Dual String weedeater and he has to have 2 strings, not 1 to make it work properly. I think it needs...
Well I have used this search engine called google. Though it seems to be unknown on this board I would go there www.google.com and do the following search" Weedeater Featherlite Plus Fl26 manual" This will create a number of hits or links. You click on one that has the company name in the url and find customer service or downloads. Click around and eventually you will find what you seek.
Spread the word about google, it saves a bunch of time instead of asking strangers to do google searches for you.
May 14, 2011 | Garden
Brand new featherlite weedeater runs hot, no power. Was fine for about 10 minutes. Has fresh 40:1 gas mixture that works fine on my grass blower. Seems like carb is out of adjustment, but of course,...
If it is a solid plug (brass) I would not recommend drilling this out. To my knowledge there is not an adjustment screw behind it. In my 23 years I have yet to drill any plugs from a featherlite trimmer. If there is a screw that can be adjusted it should be visible but may have limiter caps covering them or screws with special heads. Since this an EPA mandate it is suggested you have a qualified technician adjust this for you.
Feb 13, 2011 | Garden
Weedeater featherlite seized shaft
If you are talking about your crank shaft being stuck, there is nothing you can do that will work for the long haul. Usually what happens to cause this problem is running straight ( no oil added to fuel) gas to these 2 cylce engines. When you get a "lean seizure', the engine slowly loses power then quits. If you leave it alone for a while, the pull rope will be harder but it will start. The second tome it does this..........well your done. time to buy a new one. Sorry.
Nov 10, 2010 | Weedeater Featherlite Blower 18 Cc 150 Mph...
Trimmer starts but the spool wont turn anymore
you're trimmer could have one of two problems, One, if it has a clutch on the engine,( the way you would tell is if it doesn't spin when it idles. it has a clutch) Two, your trimmer would spin all the time, they use round flexable cables stamped square on both ends, which fit into square sockets one at the engine one at the trimmer head, so you're problem is either a worn out clutch, or, the cable is broken, or, one maybe both sockets have become rounded out. I hope this helps you out. Bob
Jul 31, 2010 | Poulan Garden
How to bore a perfect level 1/2 inch hole in wooden door
Some drills have a spirit level built in that help keep things reasonably square and level. I don't particularly trust them, but if you try using it while drilling on a piece of scrap and are happy with the results, it's no extra cost.
If you don't trust yourself to "eyeball it", you can buy a drill guide (see link). If you look at the link, you'll see that it has a flat reference surface you can put up against your door. The chuck on the guide slides up and down the guide posts, so if you set the angle on the posts to 90 degrees you can drill a nice perpendicular hole. I linked to Amazon, but I've seen them in local hardware stores.
Make sure you mark your center point so you can center the bit up properly.
A forstner style bit will cut nice smooth edges. It's pretty easy to stay square using one of them too, because the walls are square to the cutting face.
Whatever you decide, it's probably worth drilling a practice hole on some scrap. It's painful to goof up a door.
If this answer was helpful, please give it a vote. Thanks!
Jun 15, 2010 | Black & Decker Pivot Plus Cordless...
I am trying to repair the fuel intake on a featherlite weed eater
replaced fuel lines on sear weedeater and primer button still acts like it is suching against a vacume. push it in and it won`t release. this unit in same as my featherlite carb and tank. What do I look for line are not restricted, but car not drawing fuel?????
Jul 08, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
I am having the same problem with acceleration speed on my blower
If the units is like mine, the adv. shafts, hi & low are knurled around the sides. you must find something to slip over them, (almost Impossible).I have a thin hawksaw blade and i sawed a slot in the end of each shaft.Check your head bolts. Yours, Knowitnothing
Jul 04, 2009 | Poulan Featherlite Gas Blower, with Low...
Garden Logo
104 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
