Question about Toshiba MK 3017GAP (HDD2159) 30 GB Hard Drive
I need to run an HDD2159 external of its computer.
The computer has died so I woukd like to get the info off its hard drive HDD2159 external of its computer. I have the USB Cable to SATA but I don't know which pins to connect to make it a slave drive.
Connecting the drive to the USB of my new computer caurer the drive to start up and stop over and over every 5 sec. Any ideas ?
  • Toshiba Master
  • 32,281 Answers
You cannot just connect the hard drive using a SATA to USB cable and connect it to the computer and expect to download data from this hard drive.
You need to connect the hard drive to an USB hard drive adapter which is then connected to a computer's USB port?
Leave the hard drive set as the master drive.
Posted on Oct 02, 2009
External Hard drive setup
You can run Disk Management (check the unallocated space if any):
Control Panel, Administrative Tools, Computer Management (please run as administrator; right click it), Disk Management.
Click on the hard drive info, right click, and you can do some actions (expand the volume is the one you need)
Mar 05, 2014 | Computers & Internet
I am trying to hook up a hard drive to my computer. The computer recognizes the fact that hardware has been added; however, it does not seems to recognize the hard drive itsself. It is a model number...
Test all leads that attach to your hard drive including electrical extensions, DE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they might be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs all electrical power and data to travel through every working device its and have an end so any faulty leads will end up with a computer error
make sure your ram and cmos battery are securely seated with no dust in sockets
hope this will help
Aug 28, 2011 | Toshiba MK 3017GAP (HDD2159) 30 GB Hard...
I have an seagate freeagent 500gig external hardrive and it fell off the counter and the part that connects to the cable for transfer data snapped off from the drive. I wiped my laptop and now I can't get...
there is,open the 500gb external case and take out the hard drive. go to your nearest computer shop and pick up an empty external hard drive case for internal drives.make sure its a sata drive,get your hard drive and put it in and reconnect it to your computer. those cases run around 80 bucks to you may need to look online for one to get a better deal
Mar 07, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
It makes noise when i use it and can not tell if it is storing anything
I would be very skeptical of storing anything on there. A noisy hard drive can often be an unhealthy one (ready to die).
My good friend had the same external hard drive (smaller size) and it died on him.
If you can, back up anything you need to another location.
Mar 07, 2011 | SimpleTech 1TB External USB 2.0 Hard Drive...
When I attempt to load data onto it..it never completes and it begins to vibrate and run hard until it ejects itself unproperly from the computer
The drive inside the MyBook is dead or in the process of dying. The drive needs to be returned to western digital for repair.
Feb 28, 2011 | Western Digital My Book Essential Edition...
My Emachine desktop PC S1642 will not start. The fan is on but not the hard drive or the monitor. I tried another monitor on it and the original monitor came up with a window (I forget what it said). I...
Sounds like the Hard Drive has gone on you. With the proper memory retrieving software one can take the HD out and get everything off of it. I would say your power supply has burned out but you said the fan runs so if it were your Power Supply then the fan would not run. I would either get on a friend's computer and search for tools or software that will allow you to retrieve your memory or a local repair shop should have all that is needed to get your HD's info.
I’m happy to help further over the phone at https://www.6ya.com/expert/phillip_293d34ebcf028794
Dec 13, 2009 | E-Machines eMachines Desktop PC
I can't seem to open my external acomdata hard drives. My computer doesn't recognize them and when they do open they will close in a few minutes.
Either the power-supply for the external drive is dying,
or the disk-drive inside the external case is dying.
Quick, make a "backup" of all the files on your ACOMDATA, before it totally "dies".
If it still is under warranty, exercise the warranty, and replace it.
Nov 13, 2009 | Iomega HDD External Desktop (32660) 80 GB...
External Hard Drive will not show up. Tells me to format it.
I have a Western External Hard Drive 320 and when I plug it in the computer will recognize it and allow me to access my files but after a short while if I go to click on a file t open it the WD 320 will click off for a minute and then reappear in the auto run mode.
Jun 20, 2009 | Western Digital Passport 320GB External...
Retrieving data off an external hard drive
You can and there is no need to install drivers, except the drive has any special features.
Apr 19, 2009 | Computers & Internet
Delete info from an external hard drive?
run diskmgmt.msc delete. then create then format .. also theres a tool called Wipedisk from www.thefreecountry.com/security/securedelete.shtml
Jul 21, 2008 | Maxtor Hard Drive
Toshiba MK 3017GAP (HDD2159) 30 GB Hard Drive Logo
438 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
