Question about Kenmore Elite 45986 Front Load Washer
After a load is finished and drained properly, several hours later the washing machine has filled with water again. I then have to run a drain cycle to use it.
  • 291 Answers
This sounds like the valves that let the water in are leaking, just a little bit. Over several hours, they leak enough to be noticed.
You can have those valves replaced, or you could shut off the water going into the washer with the valves in your water supply. (the one's that are usually right next to where your hoses connect)
Posted on Oct 02, 2009
Testimonial: "thanks for this starting point!"
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
Mar 17, 2010 | Washing Machines
My washer won't drain near end of cycle. Motor
The problem will be on the main board or the power supply board of the machine might have some problem kindly the check the wire lines as well
i do not think that drain pump is having any problem
Dec 30, 2009 | Kenmore 42822 Front Load Washer
GE Washer does not drain or spin
Inspect the drain hose for kinks
Test the timer control
Test the lid switch (some models)
Inspect the water pump
Inspect the drive belt (belt drive only)
Inspect the motor coupler
Jul 15, 2009 | GE WDSR2080D Top Load Washer
Wash cycle not filling with water
Does the washed show an error?
Check all hoses in back. Remove them from washer and ensure water is coming from lines (drain into bucket).
Unplug washer for several minutes, then try again.
May 02, 2009 | LG WM2487H Front Load Washer
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
Whirlpool duet front loading washer
your inlet water valve is not closing and needs replacing, in mean time turn water off between washings.
Apr 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Pump turns on while filling
if it start draining while is filling the water. you need to ck the drain house. it is too long in the drain you need to pull it out little.
Feb 06, 2008 | Frigidaire FEX831CS Top Load Stacked...
Kenmore Elite 45986 Front Load Washer Logo
73 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
