Question about Lite On DVD BURN LITEON|SHM-165P6S RAM BK R (SHM165P6SRTL) Burner
I can't get my movie maker Pinnacle studio 12 to work?
I can't get my movie maker Pinnacle studio 12 to read or detect my burner. It can play movies and in device manager it says it working properly. My DVD burner is a Liteon-DVDRW SHM-165P6S
Stonebraker
  • 167 Answers
SOURCE: error 41 cannot locate device
Is the drive appearing in My computer4.gif with a drive letter?
If it isn't:
1. click Start, point to Run, type diskmgmt.msc, and then click OK
2. If you see your drive listed without a letter, right click on it and assign it a new drive letter
Posted on Jan 04, 2008
  • 476 Answers
SOURCE: Can't import video into Windows Movie Maker
Best possible option is to get a good video card that has inputs for your vhs player both sound and video,
it will come with the software needed to edit your own and to add those extra special features then write to disk also.
a good burning software is from www.nero.com
Trials available for download,
There are plenty of good softwares available for home editting but for good results do yourself a favour and get good Audio/Video card first time ,
compare with friends before buying even go look at them in use to see if your happy,
You'll be glad if you get good results from the start,
Movie maker You will need to check out the help section and compare the specs with NEROsite info,
Hope this helps,
Let me know of the outcome thanks
Misterdj
Posted on Aug 29, 2008
  • 788 Answers
SOURCE: hooking up a Liteon 24X DVDrw burner
The SATA drive is to be used with a motherboard that supports SATA 1 or 2.
If you have a board that supports SATA, you should also have a power supply that supports SATA.
The 7 pin connector is for data. the other connector is for power.
Hope this has helped you.
P.S. Their are conversion kits for the power supply if yours does not support SATA but your board is something else all together.
Get back to me with the make a model number of the PC and I will check if you want.
Posted on Sep 15, 2009
  • 1019 Answers
SOURCE: It want burn any movies that are downloaded.
if it,s only downloaded movies, that won,t burn/Write.
I,d assume that the downloaded content, is Copyright Protected.
Other suggestions Are:- your CD/DVD Burner does not support the types of files, that are being downloaded. You could try a Video Converter Program. Or alternatively. Change your DVD Burning Software.
Mike @ compurepair.
Posted on Dec 01, 2009
jay767
  • 386 Answers
SOURCE: My LITE-ON DVDRW LH-20A1H ATA
Clean the upper/lower filters:
http://support.microsoft.com/default.aspx/kb/314060
Then, insert your windows install disk and boot.
Does it see that?
If not, your CD laser is gone.
Posted on Oct 29, 2010
Pinnacle studio ultimate 12
Does the player you are using for playback support the file format you saved it in? If not you will need a codec to view it.
Sep 02, 2014 | Pinnacle Studio Version 12 for PC
Pinnacle won't accept mpeg videos how do I convert so that it will support it.
I will recommend to use the windows movie maker to convert the video.
Import the video to the m=program that I mentioned. Then export it to avi or mpeg 2 format. Once your done, Import the video to the pinnacle studio program.
Jun 19, 2010 | Pinnacle Studio Ultimate 12 for PC
Pinnacle studio 12 .stx fil
Hi and welcome to Fix yah,
I would suggest to you to finished edit your project and after that click on make movie tab or the number 3 tab of your Studio then do this procedure.
Disc Type : DVD
Audio Compression : PCM
Video Quality : Automatic
Use Progressive Encoding : NOT checked
Always Re-encode Entire Movie: Checked
Burn Options: Create Disc Content and then burn.
Current Media : Should show what DVD Disc should be used.
Target Media: DVD 4.7 GB
Copies : 1
Write Speed: lowest possible
Let me know what happen.
Feb 14, 2010 | Pinnacle Studio Plus Version 11
When making / creating a DVD, how do you make the "Play" button work, so that the result of your movie you will select the "Play" button and your movie will play. Also how do you create chapters, but allow...
hi there,
you can find the manual here :
Pinnacle Pinnacle Studio Ultimate Version 11
and in other languages please look here :
ftp://ftp.pinnaclesys.de/Manual/Studio%2011/
I suggest to look under the word :
Scene detection ...............26
The Video Scenes section ....... 40
CHAPTER 9: DISC MENUS.... 175
Output to disc media ... 243
Have a nice computing
Hope that helps
IF NOT then try to return here
Please rate my answer
Dec 09, 2009 | Pinnacle Studio Ultimate Version 11
Make movie keeps timing out, render error
I have also been running into an MPEGENCODER.DLL error about 1/2 way through my 20 minute movie. I am able to Make Movie with a 6 minute version, but hitting this error time and time again. I have removed Virus protection and all unessential system tray loads; defragged drive; downloaded newest Windows drivers; downloaded newest NVIDIA drivers; running Win XP Pro SP3, Intel 3GHZ, 1GB RAM, 76GB/10K spin drive.
Jul 01, 2009 | Pinnacle Studio Plus 12 for PC
After burning the DVD once,
Several possible solutions.
1. If you are using DVD-R discs, your player probably does not support them. There are known compatibility issues with DVD-R discs. If your burner supports it, use DVD+R discs.
2. Try burning at the slowest possible speed. That can help your player pick up the disc better.
3. Did you remember to put a menu in the beginning of your movie? Even if you have the disc set to skip the menu when inserted, it still must exist for some DVD players to recognize it as a disc and play it.
May 31, 2009 | Pinnacle Systems Studio AV/DV Version 9...
File/Folder Permission Message in Pinnacle Studio 11 Plus
Hello welcome to FIxya!
Here you can check this procedure on how to open your files again.
"1) Check your Recycle Bin
2) Do a Folder/File Search for each of the Grey Folder Project names. This will display all Folders & Files with that Project Name. You are looking for an .stx File. If it's there, right-Click on Project Name / Open Containing Folder & Copy it to your My Projects Folder. Then you should have both the Grey Folder & .stx File for the same Project name, showing in your My Projects Folder.
If the Search doesn't display a .stx File, you can create a new one, by Opening a New empty Project, which will create a My Movie Grey Folder & a My Movie .stx File, Save to your My Projects Folder. Delete the My Movie Grey Folder & Rename the My Movie .stx File to the same name as your original Grey Folder."
So ...after finding my "lost" movie file, with its file name, under Documents\Pinnacle Studio\My Projects i then went through the following procedures using your great advice Colour;
  1. Make a copy of your found "lost" movie grey film icon file by right mouse clicking on your lost file and choosing "copy". Paste the copy into another folder in Documents where you can find it if need be
  2. Then go back to Documents\Pinnacle Studio\My Projects and right mouse click onto your grey film icon. Choose "rename". Then rename your "lost" grey film icon to a new file name but do not put .stc at the end of the file name, if you are operating VISTA and Pinnacle 12. This is important because Pinnacle 12 won't recognise the file later if you have .stc in the file name
  3. Open Pinnacle and go to the File Menu
  4. Click on New Project
  5. Open File Menu again and click on Save File as
  6. Give the file a name such as "Movie 7" and save it
  7. Close out of Pinnacle
  8. Open up Documents\Pinnacle Studio\My Projects and observe that you now have 2 new files there ...a grey film icon file saying Movie 7 AND a coloured Pinnacle icon file saying Movie 7
  9. Delete the grey icon file with the file name Movie 7
  10. Now give your coloured Pinnacle icon file the exact same rename as your precious "lost" renamed grey movie icon file, using the right mouse click on rename proceedure as explained in No.2 above.
  11. Close out of Documents file
  12. Now open up Pinnacle again
  13. Go to Menu and choose Open Project
  14. There you will see the coloured Pinnacle icon file with the new name of your "lost" movie file.
  15. Click onto its coloured Pinnacle icon, and watch your "lost" movie come into view again
Nov 16, 2008 | Pinnacle Studio Plus Version 11
Sense error
Every time i try to burn my home from windows to a Philips DVD-RW a message keeps popping up from my laptop saying that i need to place a DVD-RW cd in which i have done . The funny thing is that i edit my movie from my Pinnacle Studio 12 which i got last week, this was my 1st movie i burned well Pinnacle Studio did it for me really, it was so easy when i took the cd out of my hp pavilion laptop it played on my LITEON DVD Recorder & watched my movie clip on my tv, it worked fine but do you think i do this again NO SUCH LUCK i am really new to all this its so frustrating windows wont burn my move pinnacles not burning, what am i doing wrong, i ve got all new dvd-rw cds is there any one out there who can help me please :-(
Oct 05, 2008 | Computers & Internet
Using Windows Movie Maker
Windows Movie Maker is pretty picky about file formats. You might want to use Pinnacle Studio. This way once you plug your computer in and turn it on Pinnacle will capture the video for you which is something that Movie Maker was never designed to do.
Jul 04, 2008 | JVC Video Cameras
PV GS39 Win XP Movie Maker
I don't know if Windows XP Movie Maker can detect a firewire based video camera.
Do you have DVD burning software such as Nero in your computer? That has capture capability to it.
Pinnacle Studio will detect a firewire camera. It is reasonably priced and easy to use. In fact you can control your camcorder from Studio in case you need to rewind or fast forward the tape.
May 14, 2008 | Panasonic PV-GS39 Mini DV Digital...
Computers & Internet Logo
164 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Michael Vanidestine
Michael Vanidestine
Level 1 Expert
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
