Question about Electronics - Others
Relay Lock Application missing, need it to decrypt files. HELP!
When I bought my flash drive a few years ago, it had a relay lock application on it so I could encrypt my files. It is a Staples Relay 256 MB flash drive. When I recently inserted it into the computer it said that there was a virus and that I could not open the relay lock application. Therefore, I have all of these encrypted files now with no way to open them. They were encrypted into .cef files. Can you tell me where to get this relay lock application or how to decrypt my .cef files. I need those files! Thanks a lot.
If you still have this problem, I can email you this mini-app (RelayLock.exe) - I just bought 10 of these flashdrives from China via Ebay, and there is one on each drive.
You will need to send your email address to clive@tuffrey.co.uk
Posted on Aug 26, 2010
2002 Toyota Camry power door lock failure in higher temperature
look in the fuse box which is under the dash or in the engine compartment drivers side for the voltage relay fuse possibly square that powers the door motors and door locks . corrosion around relay or just bad relay replace and try power key lock release again and see if that works or first go into each door at a time and probe wire that leads to each door lock actuator motor and if you are getting proper current with helper pressing key to activate motor and proper current is displayed start replacing motors if intermittent wrong current or no current at each door checking with home meeter probing motor wire while helper is pressing key fob relay is bad and needs to be replaced. That is all i got good luck ps if all fails from that point replace key fob controler
Jun 13, 2017 | Cars & Trucks
Flash MX 2004 configuration
there are few steps you can try
Create a fresh Login ID for your Windows OS
Login with new ID
Increase your Virtual Memory
remove the slack files in Temp folder, You can use ccleaner addition to disk clean up.
Secure the registry changes, (you may you use spybot tea timer)
Please let me know the details, like your current operating system, RAM, CPU, Exact version of your Flash MX
Good Luck
Mar 24, 2008 | Macromedia Flash MX
I will forgot my password of my sandisk u3
Unfortunately, you can NOT access your user data and applications on the device without a password.
If you think you are entering the correct password, ensure that CAPS lock or NUM lock is not turned on. You should try to type your password in another application (like word or email) to ensure that it is being entered correctly. This can help you see if CAPS lock, NUM lock, or a sticky key is causing the password to actually be entered incorrectly.
Password attempts
There's a set number of attempts before U3 locks your device and you have to reformat it.
Reformatting will delete all files and applications on the flash drive.
Password hint
If you set a hint when you enabled the password protection, click Hint in the log in window to display the hint you entered. If you did not set a hint or still can not remember your password you will have to reformat the drive.
It is recommended to keep a backup of all the data on your U3 device on your PC for safe keeping.
Jun 24, 2011 | Computers & Internet
My password protected scandisc cruzer usb stick is refusing to accept the correct password-any solution
Password attempts
Password hint
Jan 16, 2011 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
A few days a go my locks on my 2002 saturn started fluttering and making clicking sounds. I can only unlock my car with the key now and all the locks have to be unlocked and locked manually. Then a few...
Do you or your husban know how to trouble shoot automotive electrical systems , using a wiring diagram and a DVOM - digital volt ohm meter ? Do you know how to trouble shoot electronic control modules an circuitry ? The BCM - body control module controls the power locks , anti-theft system . The first step in diagnosing problems like this involve hooking of a scan tool that can pull BCM codes . No auto parts store can check these codes .
DOOR LOCKING/UNLOCKING
Door locking/unlocking, by remote keyless entry (RKE) or driver/all door lock switches, is controlled through the BCM.
When a driver door unlock has been requested, the BCM switches circuit 694 to battery voltage. This energizes the driver door unlock relay which supplies power to the driver door lock motor. Grounding is achieved through the closed contacts of the all-door lock relay. Grounding is also achieved through the windings of the all-door lock motors and the all-door unlock relay.
When an all-door unlock has been requested, the BCM switches circuit 194 to battery voltage. This energizes the door unlock relay which supplies power to the all-door lock motors. Grounding is achieved through the closed contacts of the door lock relay. Grounding is also achieved through the winding of the driver door lock motor and the driver door unlock relay.
When an all-door lock has been requested, the BCM switches circuit 195 to battery voltage. This energizes the door lock relay which supplies power to all-door lock motors. Grounding is achieved through the closed contacts of the door unlock relay and the BCM.
Lock/Unlock power application is limited by the BCM to 7 seconds to protect lock motors.
SECURITY SYSTEM
The passlock sensor is powered by circuit 1459. The passlock sensor is grounded by circuit 1835. Passlock sensor data is supplied to the BCM by circuit 1836.
The passlock sensor data supplied to the BCM is in the form of V-codes or voltage codes. When the proper ignition key is turned in the ignition switch, the correct V-code is supplied to the BCM. The BCM responds by sending a serial data password to the engine controller allowing the engine to run.
Under a tamper condition, a specific V-code is supplied to the BCM. The BCM will send a class II message to the PCM disabling the fuel injectors.
Electric Testing Techniques You Need to Know
ECM Inputs and Outputs Diagnosis
http://www.bbbind.com/free_tsb.html free wiring diagrams ! Enter vehicle info. year , make , model an engine size . Under system click on Body & Accessories , then under subsystem click on Body controls .Then click on the search button , then the blue link . You will see all inputs and outputs from the BCM . Check B+ voltage at the door lock switches . Check door lock fuse 20amp . Check door lock an unlock relays .
https://en.wikipedia.org/wiki/Body_control_module
Also test the starting circuit !
How to voltage drop test starter motor circuit
May 10, 2017 | 2002 Saturn S-Series
I have forgotten myy lock code as i changed it years ago, i managed to reset factory sttings but the lock code is still there!!! help?
You need reinstall your phone application from computer.then your phone security code become default i mean 12345. thanks
Feb 25, 2010 | Nokia N95 Cellular Phone
Diagnose keyless entry system of 1997 Cherokee
Before replacing any Relay. Try disconnecting the negative side of the battery for at least 2-minutes to de-energize the security system, re-setting itself. The reconnect the battery and try your security (and options) system again.
The only other big question that you will have to know: is this a factory installed security system or an aftermarket security system? This makes a difference in security systems, relays etc.
Dec 27, 2009 | 1997 Jeep Cherokee Country
Wanted folder lock for nokia E63
firstly you contact the software provider and say him to install the folder lock application. there are some files called (sis, nth) after installed in your cell you can lock your desired folder.
Jul 21, 2009 | Cell Phones
Anti lock brake light
abs relay some times go bad
Dec 05, 2008 | 1999 Oldsmobile Alero
Cant put songs in my player
u need to get into explorer and see. files must be their
using a application will relate to only those application files
Jun 01, 2008 | Electronics - Others
Electronics - Others Logo
743 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
