Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
When I try to format it say that there is no disk found insert a disk and try again
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section
Posted on Oct 02, 2009
I have transcend 2GB pen drive. when i insert my pen drive in system it shows the removable disk icon in MyComputer window . when i click the removable disk it shows 'please insert disk' ...i cant open the...
may be the flash drive is locked...unlock the pendrive and then try again.
formatting can be done in other way.
goto run,type cmd,press enter,then type format f: in the cmd and press enter.this formats the drive
Sep 09, 2010 | Transcend Computers & Internet
Kingston 2 gb i cant format showing insert a disk and then try again i want format how
sir if you are using adaptor of memory card for connect it with pc then i think this error occurs so use card reader and then insert the memory card in it..........the right click on the removal disk and click format when you click on format then click quick format then o.k if this error occurs again then scan the device or go to device manager and then check whether the property of usb is enable or disable if error still continue then mail me at vicky.akon11@gmail.com i will help you again take care
Mar 26, 2010 | Kingston flash memory card - 256 MB -...
I am trying to copy photos to a cd-rw. i insert
Try another disk.
One problem with CD R/W is that some programs insist on formatting them. If you have "In-CD" running, shut it down and try again.
Dec 22, 2009 | HP Computers & Internet
Ican't get a self installed floppy disk drive to work with Vista.
Reverse the data ribbon direction in floppy side (data cables pink color side should be plugged opposite to power cables color side)
Sep 25, 2009 | Teac Floppy Drive 235HF Internal Floppy...
Sony 8 gbpen drive not formatted
can it be made to work on a win box? if it cannot then i suggest it may be fuct ! (failed under continuous testing)
Aug 28, 2009 | Sony 8GB Micro Drive (SUD8G) -24419 USB...
KINGSTON removable disk error
Find and check real free space go to my computer and right click your driver letter and click properties it will show what is real ammount of disk. For one 4GB file it must not be problem but for meny little file can take more space besider their sum of capacity is 4GB. At format check correct ammount of data "capacity" is 8GB (7.9) also file system for NTFS or FAT32. FAT cant bear 8GB.
Aug 04, 2009 | Computers & Internet
Can tot open pen drive
you format your pendrive
or
go for nearest transcend service centre
or
your your pendrive is out of order
Jul 31, 2009 | Transcend (589307) Media
PLEASE INSERT A DISK INTO DRIVE(H): (pendrive problem)
1)I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also )I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also
Feb 13, 2009 | Sony 8GB Micro Drive (SUD8G) -24419 USB...
Pendrive problem
opening pen drive, it shows 'please insert the disk' & it shows 0 bytes & while trying to format it shows the same message again , i am using 2 gb pendrive of trancend.
Oct 24, 2008 | Transcend (589307) Media
8gb trancend pen drive problem
you can solve this problem by just formatting your pen drive with this software
http://www.transcendusa.com/products/online_recovery.asp
Oct 18, 2008 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
88 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
